Dear community!
I would like to ask you a question about loading a custom u-boot via uuu
into verdin-imx8mp
board. And yes, I wanted to use a custom variant (not via EasyInstaller). Let me introduce, how I started… .
I downloaded&unpacked the Verdin-iMX8MP_ToradexEasyInstaller_6.7.0+build.7.zip
as you guide on your webpage. I run sudo recovery/uuu -v -b emmc imx-boot-sd
and was expecting, that it will flash the bootloader, but nothing like that happened.
DDRINFO: start DRAM init
DDRINFO: DRAM rate 4000MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
DDR configured as dual rank
SEC0: RNG instantiated
Normal Boot
WDT: Started watchdog@30280000 with servicing (60s timeout)
Trying to boot from BOOTROM
Boot Stage: USB boot
Find img info 0x&4802a7a0, size 888
Need continue download 1024
Download 949984, Total size 951104
NOTICE: BL31: v2.6(release):lf_v2.6-g3c1583ba0a
NOTICE: BL31: Built : 11:00:38, Nov 21 2022
U-Boot 2022.04-6.7.0+git.7588eb559ca2 (May 28 2024 - 11:19:14 +0000)
CPU: i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 28C
Reset cause: POR
DRAM: 4 GiB
Core: 89 devices, 23 uclasses, devicetree: separate
MMC: FSL_SDHC: 1, FSL_SDHC: 2
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Model: Toradex 0058 Verdin iMX8M Plus Quad 4GB WB IT V1.1B
Serial#: 15380116
MISSING TORADEX CARRIER CONFIG BLOCKS
BuildInfo:
- ATF 3c1583b
Setting variant to wifi
Detect USB boot. Will enter fastboot mode!
Net: eth1: ethernet@30be0000, eth0: ethernet@30bf0000 [PRIME]
Fastboot: Normal
Boot from USB for uuu
Same situation happened with imx-boot-recoverytezi
. I tried to run the sudo recovery/uuu -v recovery
, but it haven’t flashed the bootloader either. Maybe because of missing DFU support? So I decided to follow some next “official” steps… .
So I decided to build an official image and use it like a basement. So I created a new directory and run repo init -u git://git.toradex.com/toradex-manifest.git -b scarthgap-7.x.y -m torizon/default.xml
Then source the environment via MACHINE=verdin-imx8mp source setup-environment build
and run bitbake imx-boot
and it failed during compilation!!!.
25154+1 records in
25155+0 records out
100620 bytes (101 kB, 98 KiB) copied, 0.0168229 s, 6.0 MB/s
./../scripts/dtb_check.sh imx8mp-evk.dtb evk.dtb imx8mp-verdin-wifi-dev.dtb
Can't find u-boot DTB file, please copy from u-boot
make[1]: *** [soc.mak:156: evk.dtb] Error 254
make: *** [Makefile:26: flash_evk_emmc_fastboot] Error 2
WARNING: exit code 2 from a shell command.
This is crazy, isn’t it? My expectation was just the reference and use it . So back to my problem, what I wanted to achieve. As I wrote at the begging I wanted to create a custom u-boot and flash it via uuu.
So I prepared my custom Ycoto layer setup and use u-boot sources from here: u-boot-toradex.git - U-Boot bootloader for Apalis and Colibri modules. I’ve just took verdin-imx8mp_defconfig
and imx8mp-verdin-wifi-dev.dts
and compile it. Then just run sudo uuu -v imx-boot-verdin-imx8mp-sd.bin-flash_evk
and tried to load it into board, but I failed again .
U-Boot SPL 2024.04-26afaf7655 (Sep 27 2024 - 09:41:12 +0000)
Normal Boot
WDT: Started watchdog@30280000 with servicing every 1000ms (60s timeout)
Find img info 0x4802a9a0, size 888
Failed to find node!, err: -1!
I started to loading the SPL U-boot, but it failed on Failed to find node!, err: -1!
which is pointing to
node = fdt_node_offset_by_compatible(fdt_addr, -1, "imx8m,mcu_rdc");
if (node < 0) {
printf("Failed to find node!, err: %d!\n", node);
ret = -1;
goto exit;
The funny thing is, why he is searching for such a node. The compatible string is part of imx8mp-evk-u-boot.dtsi
Last note, the same mechanism is working without any problems on NXP EVK board. I’ve just choose imx8mp_evk_defconfig
and imx8mp-evk.dts
U-Boot SPL 2024.04-e3fd706bd2 (Jul 17 2024 - 11:30:06 +0000)
Normal Boot
Find img info 0x48022fa0, size 888
NOTICE: Do not release JR0 to NS as it can be used by HAB
NOTICE: BL31: v2.10.0 (release):lf-6.6.23-2.0.0
NOTICE: BL31: Built : 10:04:22, May 29 2024
U-Boot 2024.04-e3fd706bd2 (Jul 17 2024 - 11:30:06 +0000)
CPU: i.MX8MP[8] rev1.1 1800 MHz (running at 1200 MHz)
CPU: Commercial temperature grade (0C to 95C) at 26C
Reset cause: POR
Model: NXP i.MX8MPlus LPDDR4 EVK board
DRAM: 6 GiB
TCPC: Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C2 0x50]
SNK.Power3.0 on CC1
PDO 0: type 0, 5000 mV, 3000 mA [E]
PDO 1: type 0, 9000 mV, 3000 mA []
PDO 2: type 0, 15000 mV, 3000 mA []
PDO 3: type 0, 20000 mV, 2250 mA []
Requesting PDO 3: 20000 mV, 2250 mA
Source accept request
PD source ready!
tcpc_pd_receive_message: Polling ALERT register, TCPC_ALERT_RX_STATUS bit failed, ret = -62
Power supply on USB2
TCPC: Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C1 0x50]
Core: 281 devices, 32 uclasses, devicetree: separate
Loading Environment from nowhere... OK
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc2(part 0) is current device
flash target is MMC:2
Net: eth0: ethernet@30be0000 [PRIME], eth1: ethernet@30bf0000
Fastboot: Normal
Boot from USB for mfgtools
So now the question is, what’s wrong. Is it a defconfig or DTB problem and how to fix it?
Many thanks for the support,
Andy
