Verdin iMX8M Plus 出力画像が歪む
Verdin iMX8M Plusを使用しているお客様から画像出力が乱れる(歪む)事象があるとのこと
再現をしたいが、付帯設備等環境を合わせられない
SoMの全体の評価、ストレステストを実施したいが、そのようなデバックツールは提供されているか?
提供していない場合、具体的なテストの方法を教えていただきたい。
If you’re experiencing image distortion issues with the Verdin iMX8M Plus module, there are several methods you can use to evaluate and stress test the system, even if you cannot exactly replicate the customer’s environment. Here are some steps you can take:
  1. Performance Benchmarking: Run a variety of applications to assess system performance and stability. This can help determine if the distortion occurs under specific workloads.
  2. System Resource Monitoring: Monitor CPU and memory usage to observe how the system behaves under high load conditions. This might indicate if resource constraints are contributing to the distortion.
  3. Error Log Analysis: Check system error logs for any anomalies or errors that could be related to the image distortion.
  4. Environment Simulation: Attempt to simulate the customer’s environment as closely as possible, using similar hardware configurations and software settings, to see if the issue can be reproduced.
  5. Custom Test Scripts: Create scripts to simulate specific workloads and monitor the system’s response. This can help identify the conditions under which distortion occurs.
  6. Stress Testing: Apply continuous data streams to the system to monitor for output anomalies, which can help in reproducing the image distortion issue.
By following these steps, you can conduct a thorough evaluation of the Verdin iMX8M Plus and potentially identify the root cause of the image distortion. If the issue persists, consider further software adjustments based on your findings.
Toradex AI Assistant
https://www.toradex.com/computer-on-modules/verdin-arm-family/ti-am62
Cortex-M hello_world example for Verdin iMX8M-Plus strange behavior.
