Using IEEE802.11/agb with a single antenna
I’m planning to use WiFi in the following environment, but am I correct in understanding that if I use only one antenna, I can only use IEEE802.11/agb?
・Dual-Band Wi-Fi/Bluetooth PCB Antenna 100mm
・Colibri imx6ULL
・Toradex Minimalimage
Hello!
Using a single antenna with your Colibri iMX6ULL module does not restrict you to only using the IEEE802.11/adb standards. The choice between single and dual antenna configurations primarily influences the performance and stability of your WiFi connection rather than the specific WiFi standards you can utilize.
In general, dual antennas are recommended for optimal performance because they support Multiple-Input Multiple-Output (MIMO) technology, which can enhance throughput and connection stability. However, a single antenna setup is still capable of supporting various WiFi standards, including IEEE802.11a/b/g/n/ac, depending on the capabilities of the WiFi module you are using.
Therefore, if you choose to use a single antenna, you may experience reduced performance compared to a dual antenna setup, but you are not limited to using only certain WiFi standards. Make sure your antenna is properly connected and configured to maximize the performance of your wireless connection.
iMX6ULL Wi-Fi and BT problems.
