Use TCB to include Cortex-M firmware
After a TorizonCore image has been built using TCB, the firmware for Cortex-M can be manually added following the instructions from @hfranco.tx here:
  • unzip TorizonCore image
  • move Cortex-M binary inside TorizonCore image folder
  • edit the image.json to copy the binary when Toradex Easy Installer is going to install the image
  • edit u-boot-initial-env-sd to automatically start the auxiliary core
I would like seein TCB improved so that it can be configured to handle these tasks automatically.
And annd new fields to tcbuild.yaml to configure this behavior.
Hi @vix,
Thank you for your interest and also for your comment here.
I will forward your request to our TorizonCore team and keep you updated on any news.
Thanks!
Hiago.
Hi @vix,
The ticket for the feature request was created internally with the TorizonCore team. Because it just got created, we don’t have any prioritization or timeline that I can share now, but I will update you on any news.
Thanks!
Hiago.
Thanks @hfranco.tx
I missed one customization to u-boot-initial-env-sd:
  • fdt_high=0xffffffffffffffff
    as you explained here.
Hi @vix !
Was this thread solved?
If yes, could you please mark the most suitable message as the Solution? :slight_smile:
Hi @vix,
Thanks, we are aware of this issue as well, probably will be discussed in a different ticket. Thanks for also pointing this out.
Hiago.
