Verdin iMX8MP Q 4GB WB IT V1.0B
Dahlia V1.1A
19V/3.42A Barrel Jack Power
Native HDMI Out to Monitor
Debug USB-C to USB Host
DRP USB-C to USB Host
(Ubuntu 20.04 Host)
Summary
Under certain conditions, opening a UART connection to the USB debug port will cause the board to power down and go into an unrecoverable state.
Steps to Reproduce
Note: This is not the only scenario where this has been observed, but it is the easiest to reproduce
Plug in the cables mentioned in the environment setup
Boot to recovery mode
Load Tezi
On host, open a UART connection to DEBUG port on carrier board e.g screen /dev/ttyUSB0
Since Verdin iMX8M plus software is in a beta stage we recommend to use a latest nightly build as it stated here. However I’ve tested 5.3.0 version and it has no issue with debug serial port as well.
Are you sure you are opening the debug port but not the FDTI JTAG or FTDI GPIO (power/reset control) ? When you plug your dev machine to Dahlia X18 connector you will have 4 COM ports on your dev machine. The last one is a debug. Please refer to Dahlia board schematic for details.
