I have a new IMX8MP SoM and Mallow carrier card and have been unsuccessful in using any graphical containers. I have been trying to run this example: https://developer.toradex.com/torizon/application-development/use-cases/gui/web-browser-kiosk-mode-with-torizoncore/#imx8. When I try to run the following command to start Weston/Wayland, nothing happens on the ASUS FHD monitor that is hooked up via the HDMI port on the Mallow board.
docker container run -d --name=weston --net=host \
--cap-add CAP_SYS_TTY_CONFIG \
-v /dev:/dev -v /tmp:/tmp -v /run/udev/:/run/udev/ \
--device-cgroup-rule="c 4:* rmw" --device-cgroup-rule="c 253:* rmw" \
--device-cgroup-rule="c 13:* rmw" --device-cgroup-rule="c 226:* rmw" \
--device-cgroup-rule="c 10:223 rmw" --device-cgroup-rule="c 199:0 rmw" \
torizon/weston-imx8:4 \
--developer
Swapping out the -d for -it here is the output of the program.
Switching VT tty1 to text mode if currently in graphics mode
Switching to VT 7
SoC is: 'i.MX8MP'
SoC has GPU: true
SoC has DPU: false
g2d implementation: viv
Removing previously created '.X*-lock' entries under /tmp before starting Weston. Pass 'IGNORE_X_LOCKS=1' environment variable to Weston container to disable this behavior.
dos2unix: converting file /etc/xdg/weston/weston.ini to Unix format...
dos2unix: converting file /etc/xdg/weston-dev/weston.ini to Unix format...
00:00:00.000 [seatd/seat.c:39] Created VT-bound seat seat0
00:00:00.000 [seatd/seatd.c:194] seatd started
Date: 2024-12-11 UTC
[00:09:08.783] weston 12.0.4
https://wayland.freedesktop.org
Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
Build: 12.0.4
[00:09:08.783] Command line: weston -Bdrm-backend.so --current-mode -Swayland-0 --use-g2d
[00:09:08.783] OS: Linux, 6.6.23-7.0.0-g558ba3740880, #1-Torizon SMP PREEMPT Wed Sep 25 11:25:16 UTC 2024, aarch64
[00:09:08.783] Flight recorder: enabled
[00:09:08.783] Using config file '/etc/xdg/weston-dev/weston.ini'
[00:09:08.784] Output repaint window is 7 ms maximum.
[00:09:08.784] Loading module '/usr/lib/aarch64-linux-gnu/libweston-12/drm-backend.so'
[00:09:08.792] initializing drm backend
[00:09:08.792] Trying libseat launcher...
00:00:00.023 [seatd/server.c:145] New client connected (pid: 29, uid: 1000, gid: 1000)
00:00:00.024 [seatd/seat.c:170] Added client 7 to seat0
00:00:00.024 [seatd/seat.c:480] Opened client 7 on seat0
[00:09:08.794] [libseat/libseat.c:73] Seat opened with backend 'seatd'
[00:09:08.794] [libseat/backend/seatd.c:212] Enabling seat
[00:09:08.794] libseat: session control granted
[00:09:08.798] using /dev/dri/card1
[00:09:08.798] DRM: supports atomic modesetting
[00:09:08.798] DRM: does not support GBM modifiers
[00:09:08.798] DRM: does not support async page flipping
[00:09:08.798] DRM: supports picture aspect ratio
[00:09:08.799] Loading module '/usr/lib/aarch64-linux-gnu/libweston-12/g2d-renderer.so'
[00:09:08.949] event1 - gpio-keys: is tagged by udev as: Keyboard
[00:09:08.950] event1 - gpio-keys: device is a keyboard
[00:09:08.954] event0 - 30370000.snvs:snvs-powerkey: is tagged by udev as: Keyboard
[00:09:08.954] event0 - 30370000.snvs:snvs-powerkey: device is a keyboard
[00:09:08.961] event3 - LITEON Technology USB Multimedia Keyboard: is tagged by udev as: Keyboard
[00:09:08.961] event3 - LITEON Technology USB Multimedia Keyboard: device is a keyboard
[00:09:09.035] event4 - USB Optical Mouse: is tagged by udev as: Mouse
[00:09:09.035] event4 - USB Optical Mouse: device is a pointer
[00:09:09.039] event2 - audio-hdmi HDMI Jack: is tagged by udev as: Switch
[00:09:09.129] event2 - not using input device '/dev/input/event2'
[00:09:09.160] libinput: configuring device "gpio-keys".
[00:09:09.160] libinput: configuring device "30370000.snvs:snvs-powerkey".
[00:09:09.160] libinput: configuring device "LITEON Technology USB Multimedia Keyboard".
[00:09:09.160] libinput: configuring device "USB Optical Mouse".
[00:09:09.161] DRM: head 'HDMI-A-1' found, connector 38 is disconnected.
[00:09:09.273] DRM: head 'HDMI-A-2' found, connector 40 is connected, EDID make 'ACI', model 'ASUS VE278', serial 'J6LMTF110985'
Supported EOTF modes: SDR
[00:09:09.274] Registered plugin API 'weston_drm_output_api_v1' of size 40
[00:09:09.274] Registered plugin API 'weston_drm_virtual_output_api_v2' of size 48
[00:09:09.274] Color manager: no-op
[00:09:09.274] Module '/usr/lib/aarch64-linux-gnu/libgbm.so' already loaded
[00:09:09.274] Output 'HDMI-A-2' attempts EOTF mode: SDR
[00:09:09.274] Output 'HDMI-A-2' using color profile: built-in default sRGB SDR profile
[00:09:09.282] Output HDMI-A-2 (crtc 36) video modes:
1920x1080@60.0, preferred, current, 148.5 MHz
1920x1080@60.0 16:9, 148.5 MHz
1920x1080@59.9 16:9, 148.4 MHz
1920x1080@50.0 16:9, 148.5 MHz
1680x1050@59.9, 119.0 MHz
1280x1024@75.0, 135.0 MHz
1280x1024@60.0, 108.0 MHz
1440x900@59.9, 88.8 MHz
1280x960@60.0, 108.0 MHz
1152x864@75.0, 108.0 MHz
1280x720@60.0, 74.2 MHz
1280x720@60.0 16:9, 74.2 MHz
1280x720@59.9 16:9, 74.2 MHz
1280x720@50.0, 74.2 MHz
1280x720@50.0 16:9, 74.2 MHz
1440x576@50.0 4:3, 54.0 MHz
1440x576@50.0 16:9, 54.0 MHz
1024x768@75.0, 78.8 MHz
1024x768@70.1, 75.0 MHz
1024x768@60.0, 65.0 MHz
1440x480@60.0 4:3, 54.1 MHz
1440x480@60.0 16:9, 54.1 MHz
1440x480@59.9 4:3, 54.0 MHz
1440x480@59.9 16:9, 54.0 MHz
832x624@74.6, 57.3 MHz
800x600@75.0, 49.5 MHz
800x600@72.2, 50.0 MHz
800x600@60.3, 40.0 MHz
800x600@56.2, 36.0 MHz
720x576@50.0, 27.0 MHz
720x576@50.0 4:3, 27.0 MHz
720x576@50.0 16:9, 27.0 MHz
720x480@60.0 4:3, 27.0 MHz
720x480@60.0 16:9, 27.0 MHz
720x480@59.9, 27.0 MHz
720x480@59.9 4:3, 27.0 MHz
720x480@59.9 16:9, 27.0 MHz
640x480@75.0, 31.5 MHz
640x480@66.7, 30.2 MHz
640x480@60.0 4:3, 25.2 MHz
640x480@59.9, 25.2 MHz
640x480@59.9 4:3, 25.2 MHz
720x400@70.1, 28.3 MHz
[00:09:09.283] associating input device event1 with output HDMI-A-2 (none by udev)
[00:09:09.283] associating input device event0 with output HDMI-A-2 (none by udev)
[00:09:09.283] associating input device event3 with output HDMI-A-2 (none by udev)
[00:09:09.283] associating input device event4 with output HDMI-A-2 (none by udev)
[00:09:09.283] Output 'HDMI-A-2' enabled with head(s) HDMI-A-2
[00:09:09.283] Compositor capabilities:
arbitrary surface rotation: yes
screen capture uses y-flip: yes
cursor planes: yes
arbitrary resolutions: no
view mask clipping: yes
explicit sync: yes
color operations: no
presentation clock: CLOCK_MONOTONIC, id 1
presentation clock resolution: 0.000000001 s
[00:09:09.284] Loading module '/usr/lib/aarch64-linux-gnu/weston/desktop-shell.so'
[00:09:09.285] Loading module '/usr/lib/aarch64-linux-gnu/libweston-12/xwayland.so'
[00:09:09.319] Registered plugin API 'weston_xwayland_v1' of size 32
[00:09:09.319] Registered plugin API 'weston_xwayland_surface_v1' of size 16
[00:09:09.319] xserver listening on display :0
[00:09:09.319] Loading module '/usr/lib/aarch64-linux-gnu/weston/screen-share.so'
[00:09:09.321] launching '/usr/lib/aarch64-linux-gnu/weston-keyboard'
[00:09:09.329] launching '/usr/lib/aarch64-linux-gnu/weston-desktop-shell'
[00:09:09.338] atomic: couldn't commit new state: Invalid argument
[00:09:09.338] repaint-flush failed: Invalid argument
could not load cursor 'dnd-move'
could not load cursor 'dnd-copy'
could not load cursor 'dnd-none'
It gives a vague error about an invalid argument that I can’t find anything about online.
The subsequent call to Chromium gives this output:
sudo docker run -it --rm --name=chromium -v /tmp:/tmp -v /var/run/dbus:/var/run/dbus -v /dev/galcore:/dev/galcore --device-cgroup-rule='c 199:* rmw' --security-opt seccomp=unconfined --shm-size 256mb torizon/chromium-imx8:$CT_TAG_CHROMIUM --virtual-keyboard --user-data-dir=/tmp https://www.toradex.com
[7:32:1211/002616.475456:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[7:32:1211/002616.476305:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[7:32:1211/002616.476455:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[7:32:1211/002616.476555:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[7:32:1211/002616.476647:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
*** stack smashing detected ***: terminated
[7:32:1211/002616.574887:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[7:32:1211/002616.776192:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[7:32:1211/002616.776323:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[7:7:1211/002616.967306:ERROR:gpu_process_host.cc(982)] GPU process exited unexpectedly: exit_code=134
[7:7:1211/002616.981898:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[7:75:1211/002617.064437:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[7:75:1211/002617.066216:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.UPower.GetDisplayDevice: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[7:75:1211/002617.067646:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.UPower.EnumerateDevices: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[7:7:1211/002617.070771:ERROR:gpu_process_host.cc(982)] GPU process exited unexpectedly: exit_code=134
[7:7:1211/002617.181840:ERROR:gpu_process_host.cc(982)] GPU process exited unexpectedly: exit_code=134
[7:7:1211/002617.181954:FATAL:gpu_data_manager_impl_private.cc(423)] GPU process isn't usable. Goodbye.
Trace/breakpoint trap (core dumped)
Software Summary
Software summary
Bootloader: U-Boot
Kernel version: 6.6.23-7.0.0-g558ba3740880 #1-Torizon SMP PREEMPT Wed Sep 25 11:25:16 UTC 2024
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/4c71f4b269116eb0916ec8ec0e61598a04c7107cb2167a9a135d502754692b96/0
Distro name: NAME="Torizon OS"
Distro version: VERSION_ID=7.0.0-build.1
Hostname: verdin-imx8mp-15207913
Hardware info
Toradex version: 0070 V1.1A
Serial number: 15207913
Processor arch: aarch64
