U-Boot SPL to Enable OPTEE on Colibri iMX8QXP
Can you provide any guidance in configuring U-Boot for SPL on the Colibri iMX8QXP? I am using the OpenEmbedded tdx-reference-multimedia-image 5.x.y reference image. I will share my current approach below. I was hopeful that perhaps you could point out what I might be misunderstanding or missing.
Why do I feel I need SPL U-Boot?
It appears to me that NXP requires SPL U-Boot in order to enable OP-TEE. Specifically in imx-mkimage, the soc.mak target for “flash” does not account for optee, but “flash_spl” does: https://source.codeaurora.org/external/imx/imx-mkimage/tree/iMX8QX/soc.mak?h=imx_5.4.70_2.3.0
This is consistent with Table 51 from the i.MX Linux User’s Guide: https://www.nxp.com/docs/en/user-guide/IMX_LINUX_USERS_GUIDE.pdf
I don’t know why this is a dependency based on my understanding of the boot flow on the i.MXQXP, but it appears that it is. And consistent with this guidance, NXP support for their imx8qxp_mek board uses SPL U-boot. I was hopeful that Toradex might have started with NXP support for the imx8qxp_mek when implementing the boot flow for the Colibri imx8qxp, and so perhaps could have some knowledge to share in regards to going back to SPL U-Boot…
What have I tried?
My basic approach has been an attempt to use NXP’s board support for their imx8qxp_mek as an example in order to enable SPL U-Boot.
  • Enable optee and uboot-spl in colibri-imx8x.conf
     IMXBOOT_TARGETS = "flash_spl"
    MACHINE_FEATURES += “optee”
    SPL_BINARY = “spl/u-boot-spl.bin”
  • I created the attached U-Boot patch based on NXP’s support for the imx8qxp_mek:
    Colibri iMX8QXP SPL_UBOOT Patch
  • I patched imx-atf in order to enable DEBUG_CONSOLE on Uart0
    • When I did this, I was able to see ATF output on SODIMM_36/SODIMM_38
    • When I tried to include optee using the imx-boot flash target (the one Toradex uses, not the spl target that I need to use), I confirmed that ATF attempted to set up the secure environment and give control to tee.bin at the proper expected address. This failed because tee.bin is not supported by the imx-boot flash target and so it was not loaded into memory. So this is what I expected.
    • When I tried to include optee using the imx-boot flash_spl (and my attached u-boot patch), I could see that tee.bin was being included in the imx-boot file. However, I saw no output from the ATF. I initially did not expect this as I thought ATF would get control directly from the SCFW prior to U-Boot being a factor. However, I now realize that this flow is different for SPL booting as shown in Figure 2 of the i.MX Porting Guide: https://www.nxp.com/docs/en/user-guide/IMX_PORTING_GUIDE.pdf I still don’t understand why NXP requires SPL for the TEE on the 8X, but at least it makes sense to me why I no longer see ATF output.
My Specific Questions
So anyway, I’m asking for any guidance that can be provided for running OP-TEE on the Colibri iMX8QXP.
Beyond that, I’d also appreciate any insight into what I need to do in order to boot the Colibri iMX8QXP using SPL U-Boot. If you can provide that guidance, then I expect I will be able to get OP-TEE running based on what NXP supports on their imx8qxpmek board.
Thanks,
Justin
Greetings @justin.mcdowell.s7,
Unfortunately we don’t have too much experience with OPTEE here at Toradex. So there’s not much documentation or guidance I can provide other than the existing NXP documentation.
As for SPL U-Boot part while it’s non-standard from how we build our software, but seems doable. Though I’ll need to consult internally with our development team to see if they have pointers on this topic. I’ll reply back with any information I’m able to get.
Just to clarify though since it wasn’t clear. When you integrated your flash_spl based imx-boot, how far did you get into the boot process? So you didn’t see the ATF output, then what happened? Did you ever get to U-Boot? Did the boot process just hang?
Also your U-Boot patch doesn’t actually lead to anything when I click on the link.
Thanks. I’m optimistic that if I get SPL U-Boot working, then I will be able to leverage what NXP has in order to get OPTEE working.
When I integrated my flash_spl based imx-boot, I did not see any console output (no ATF or U-Boot). So it appeared from the console that the boot process just hung.
I don’t know why you weren’t able to access the patch that I provided as an attachment. It seems to work for me. I will just paste the contents below. Thanks – any guidance will be appreciated.
diff --git a/board/toradex/colibri-imx8x/Makefile b/board/toradex/colibri-imx8x/Makefile
index 783d4fb5ba..bc474713b1 100644
--- a/board/toradex/colibri-imx8x/Makefile
+++ b/board/toradex/colibri-imx8x/Makefile
@@ -4,3 +4,4 @@
 obj-y += colibri-imx8x.o
+obj-$(CONFIG_SPL_BUILD) += spl.o
diff --git a/board/toradex/colibri-imx8x/colibri-imx8x-imximage.cfg b/board/toradex/colibri-imx8x/colibri-imx8x-imximage.cfg
index 1dcd13271d..766f840043 100644
--- a/board/toradex/colibri-imx8x/colibri-imx8x-imximage.cfg
+++ b/board/toradex/colibri-imx8x/colibri-imx8x-imximage.cfg
@@ -19,6 +19,4 @@ CONTAINER
 /* Add scfw image with exec attribute */
 IMAGE SCU mx8qx-colibri-scfw-tcm.bin
 /* Add ATF image with exec attribute */
-IMAGE A35 bl31.bin 0x80000000
-/* Add U-Boot image with load attribute */
-DATA A35 u-boot-dtb.bin 0x80020000
+IMAGE A35 spl/u-boot-spl.bin 0x00100000
diff --git a/board/toradex/colibri-imx8x/colibri-imx8x.c b/board/toradex/colibri-imx8x/colibri-imx8x.c
index 5bc4fba5b9..cddf5af51b 100644
--- a/board/toradex/colibri-imx8x/colibri-imx8x.c
+++ b/board/toradex/colibri-imx8x/colibri-imx8x.c
@@ -186,6 +186,9 @@ int board_init(void)
 	return 0;
+void board_quiesce_devices(void)
 /* todo: With that function in ther is no console output in linux, drop for now */
 #if 0
diff --git a/board/toradex/colibri-imx8x/spl.c b/board/toradex/colibri-imx8x/spl.c
new file mode 100644
index 0000000000..ffd19bcb93
--- /dev/null
+++ b/board/toradex/colibri-imx8x/spl.c
@@ -0,0 +1,64 @@
+ * Copyright 2018 NXP
+ * SPDX-License-Identifier:	GPL-2.0+
+#include <common.h>
+#include <dm.h>
+#include <spl.h>
+#include <dm/uclass.h>
+#include <dm/device.h>
+#include <dm/uclass-internal.h>
+#include <dm/device-internal.h>
+#include <dm/lists.h>
+#include <bootm.h>
+DECLARE_GLOBAL_DATA_PTR;
+void spl_board_init(void)
+	struct udevice *dev;
+	uclass_find_first_device(UCLASS_MISC, &dev);
+	for (; dev; uclass_find_next_device(&dev)) {
+		if (device_probe(dev))
+			continue;
+	board_early_init_f();
+	timer_init();
+#ifdef CONFIG_SPL_SERIAL_SUPPORT
+	preloader_console_init();
+	puts("Normal Boot\n");
+#endif
+void spl_board_prepare_for_boot(void)
+	board_quiesce_devices();
+#ifdef CONFIG_SPL_LOAD_FIT
+int board_fit_config_name_match(const char *name)
+	/* Just empty function now - can't decide what to choose */
+	debug("%s: %s\n", __func__, name);
+	return 0;
+#endif
+void board_init_f(ulong dummy)
+	/* Clear the BSS. */
+	memset(__bss_start, 0, __bss_end - __bss_start);
+	arch_cpu_init();
+	board_init_r(NULL, 0);
diff --git a/board/toradex/colibri-imx8x/uboot-container.cfg b/board/toradex/colibri-imx8x/uboot-container.cfg
index 0000000000..8165811818
--- /dev/null
+++ b/board/toradex/colibri-imx8x/uboot-container.cfg
@@ -0,0 +1,13 @@
+/* SPDX-License-Identifier: GPL-2.0+ */
+ * Copyright 2019 NXP
+#define __ASSEMBLY__
+/* This file is to create a container image could be loaded by SPL */
+BOOT_FROM SD 0x400
+SOC_TYPE IMX8QX
+CONTAINER
+IMAGE A35 bl31.bin	0x80000000
+IMAGE A35 u-boot.bin	CONFIG_SYS_TEXT_BASE
diff --git a/configs/colibri-imx8x_defconfig b/configs/colibri-imx8x_defconfig
index 61c17a0b0a..5be3a40781 100644
--- a/configs/colibri-imx8x_defconfig
+++ b/configs/colibri-imx8x_defconfig
@@ -1,15 +1,31 @@
 CONFIG_ARM=y
+CONFIG_SPL_SYS_ICACHE_OFF=y
+CONFIG_SPL_SYS_DCACHE_OFF=y
 CONFIG_ARCH_IMX8=y
 CONFIG_SYS_TEXT_BASE=0x80020000
+CONFIG_SPL_GPIO_SUPPORT=y
+CONFIG_SPL_LIBCOMMON_SUPPORT=y
+CONFIG_SPL_LIBGENERIC_SUPPORT=y
 CONFIG_SYS_MALLOC_F_LEN=0x8000
 CONFIG_ENV_SIZE=0x2000
 CONFIG_ENV_OFFSET=0xFFFFDE00
 CONFIG_DM_GPIO=y
+CONFIG_SPL_LOAD_IMX_CONTAINER=y
+CONFIG_IMX_CONTAINER_CFG="board/freescale/imx8qxp_mek/uboot-container.cfg"
+CONFIG_SPL_MMC_SUPPORT=y
+CONFIG_SPL_EFI_PARTITION=n
+CONFIG_SPL_DOS_PARTITION=n
+CONFIG_SPL_DM_SEQ_ALIAS=y
+CONFIG_SPL_SERIAL_SUPPORT=y
+CONFIG_SPL_DRIVERS_MISC_SUPPORT=y
+CONFIG_USE_TINY_PRINTF=y
 CONFIG_BOOTAUX_RESERVED_MEM_BASE=0x88000000
 CONFIG_BOOTAUX_RESERVED_MEM_SIZE=0x08000000
 CONFIG_TARGET_COLIBRI_IMX8X=y
 CONFIG_SNVS_SEC_SC=y
 CONFIG_NR_DRAM_BANKS=3
+CONFIG_SPL=y
+CONFIG_SPL_TEXT_BASE=0x100000
 CONFIG_IMX_BOOTAUX=y
 CONFIG_IMX_VSERVICE_SHARED_BUFFER=0x90400000
 CONFIG_DISTRO_DEFAULTS=y
@@ -19,6 +35,10 @@ CONFIG_OF_SYSTEM_SETUP=y
 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri-imx8x/colibri-imx8x-imximage.cfg"
 CONFIG_BOOTDELAY=1
 CONFIG_LOG=y
+CONFIG_SPL_BOARD_INIT=y
+CONFIG_SPL_SEPARATE_BSS=y
+CONFIG_SPL_POWER_SUPPORT=y
+CONFIG_SPL_POWER_DOMAIN=y
 # CONFIG_DISPLAY_BOARDINFO is not set
 CONFIG_DISPLAY_BOARDINFO_LATE=y
 CONFIG_BOARD_EARLY_INIT_F=y
@@ -50,6 +70,9 @@ CONFIG_BOOTCOUNT_LIMIT=y
 CONFIG_BOOTCOUNT_ENV=y
 CONFIG_CLK_IMX8=y
 CONFIG_CPU=y
+CONFIG_SPL_OF_CONTROL=y
+CONFIG_SPL_DM=y
+CONFIG_SPL_CLK=y
 CONFIG_USB_FUNCTION_FASTBOOT=y
 CONFIG_FASTBOOT_BUF_ADDR=0x82800000
 CONFIG_FASTBOOT_BUF_SIZE=0x08000000
@@ -82,15 +105,19 @@ CONFIG_DM_PCI=y
 CONFIG_PHY=y
 CONFIG_CDNS3_USB_PHY=y
 CONFIG_PINCTRL=y
+CONFIG_SPL_PINCTRL=y
 CONFIG_PINCTRL_IMX8=y
 CONFIG_POWER_DOMAIN=y
 CONFIG_IMX8_POWER_DOMAIN=y
 CONFIG_DM_REGULATOR=y
+CONFIG_SPL_DM_REGULATOR=y
 CONFIG_DM_REGULATOR_FIXED=y
 CONFIG_DM_REGULATOR_GPIO=y
+CONFIG_SPL_DM_REGULATOR_FIXED=y
 # CONFIG_REQUIRE_SERIAL_CONSOLE is not set
 CONFIG_DM_SERIAL=y
 CONFIG_FSL_LPUART=y
+CONFIG_SPL_TINY_MEMSET=y
 CONFIG_DM_THERMAL=y
 CONFIG_IMX_SCU_THERMAL=y
 CONFIG_USB=y
@@ -99,6 +126,11 @@ CONFIG_USB_XHCI_HCD=y
 CONFIG_USB_CDNS3=y
 CONFIG_USB_CDNS3_GADGET=y
 CONFIG_USB_GADGET=y
+CONFIG_SPL_DM_USB_GADGET=y
+CONFIG_SPL_PHY=y
+CONFIG_SPL_USB_GADGET=y
+CONFIG_SPL_USB_SDP_SUPPORT=y
+CONFIG_SPL_SDP_USB_DEV=1
 CONFIG_USB_GADGET_MANUFACTURER="FSL"
 CONFIG_USB_GADGET_VENDOR_NUM=0x0525
 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5
diff --git a/include/configs/colibri-imx8x.h b/include/configs/colibri-imx8x.h
index 5e59835c0f..b040eca5ac 100644
--- a/include/configs/colibri-imx8x.h
+++ b/include/configs/colibri-imx8x.h
@@ -9,6 +9,34 @@
 #include <linux/sizes.h>
 #include <asm/arch/imx-regs.h>
+#ifdef CONFIG_SPL_BUILD
+#define CONFIG_SPL_MAX_SIZE				(192 * 1024)
+#define CONFIG_SYS_MONITOR_LEN				(1024 * 1024)
+#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
+#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR		0x1040 /* (32K + 2Mb)/sector_size */
+ * 0x08081000 - 0x08180FFF is for m4_0 xip image,
+  * So 3rd container image may start from 0x8181000
+#define CONFIG_SYS_UBOOT_BASE 0x08181000
+#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION		0
+#define CONFIG_SPL_LDSCRIPT		"arch/arm/cpu/armv8/u-boot-spl.lds"
+#define CONFIG_SPL_STACK		0x013fff0
+#define CONFIG_SPL_BSS_START_ADDR      0x00130000
+#define CONFIG_SPL_BSS_MAX_SIZE		0x1000	/* 4 KB */
+#define CONFIG_SYS_SPL_MALLOC_START	0x82200000
+#define CONFIG_SYS_SPL_MALLOC_SIZE     0x80000	/* 512 KB */
+#define CONFIG_SERIAL_LPUART_BASE	0x5a060000
+#define CONFIG_MALLOC_F_ADDR		0x00138000
+#define CONFIG_SPL_RAW_IMAGE_ARM_TRUSTED_FIRMWARE
+#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
+#endif
 #define CONFIG_REMAKE_ELF
 #define CONFIG_SYS_FSL_ESDHC_ADDR       0
After discussion with the team here’s what I got. So as you know we currently use the flash target when compiling the boot container. This is based off of what NXP does in their 5.4.70_2.3.0 which is the current release we’re based off of in our most recent BSP at the time.
That being said the team’s not very familiar with the flash_spl target. Also we couldn’t find any i.MX8/8X machine in the 5.4.70_2.3.0 release that makes use of the flash_spl target. This leaves us with very little reference to draw off of.
Unfortunately, this means I don’t have much information to provide you regarding SPL on the i.MX8X.
Thanks for following up. I see now that you are right about flash_spl not being supported by 5.4.70_2.3.0. When I saw that the board support in u-boot for the imx8qxp_mek accounted for SPL configuration, I incorrectly assumed that flash_spl was a supported target.
Does Toradex have any plans to migrate to a newer release of the NXP BSP in the near-term?
The flash_spl target is supported in the latest NXP BSP (hardknott - 5.10.35_2.0.0) when MACHINE_FEATURES include optee: meta-freescale/conf/machine/include/imx8x-mek.inc at hardknott · Freescale/meta-freescale · GitHub
I may have my work cut out for me as I need to consider what else I may need to leverage from NXP’s new recipes (especially related to optee and dependencies), since it would seem that they might not have really supported optee in 5.4.70 if they weren’t actually supporting the flash_spl target…
We do plan to always continually progress our BSP as long as NXP releases new versions of their BSP. However, I can’t give any guarantees on when we’ll be moving BSP versions and to what version we’ll be moving to. There’s just too many variables involved for me to give even a rough timeline of when.
All I can say is to keep an eye out for when the Toradex BSP moves major versions, this usually indicates large shifts in the underlying BSP. For example when we move to a new NXP BSP version.
Since I posted a patch that didn’t work, I figured I’d circle back and post an initial patch that does work to enable the SPL boot.
The main thing that I was missing when I tried this a few weeks ago is that the SPL just uses a subset of the device tree (in order to keep small), and the nodes relevant to what the SPL needs to do must be tagged with the ‘u-boot,dm-spl’ (or ‘u-boot,dm-pre-reloc’) property in order to be included in this smaller device tree. This is made clear in the u-boot doc/README.SPL, so once I realized that, the rest of the effort went pretty smoothly.
Once I patch u-boot-toradex in order to support SPL on the colibri-imx8x, I added the following to my machine conf file:
UBOOT_MAKE_TARGET = "u-boot.bin"
ATF_PLATFORM = "imx8qx"
MACHINE_FEATURES += "optee"
SPL_BINARY = "spl/u-boot-spl.bin"
IMX_BOOT_SOC_TARGET = "iMX8QX"
With these modification, OPTEE works as I hoped!
Anyway, here is my initial version of the u-boot-toradex patch that works to enable SPL:
diff --git a/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi b/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi
index 46b996f3b3..d5a4e458e5 100644
--- a/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi
+++ b/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi
@@ -22,26 +22,26 @@
                dr_mode = "peripheral";
                chipidea,usb = <&usbotg1>;
-               u-boot,dm-pre-proper;
+               u-boot,dm-spl;
 &{/imx8qx-pm} {
+       u-boot,dm-spl;
 &mu {
+       u-boot,dm-spl;
 &clk {
+       u-boot,dm-spl;
 &iomuxc {
+       u-boot,dm-spl;
 &{/regulators} {
@@ -49,71 +49,75 @@
 &{/mu@5d1c0000/iomuxc/colibri-imx8x} {
+       u-boot,dm-spl;
 &pinctrl_usdhc1 {
+       u-boot,dm-spl;
 &pinctrl_usdhc2_gpio {
+       u-boot,dm-spl;
 &pinctrl_usdhc2 {
+       u-boot,dm-spl;
+&pinctrl_lpuart3 {
+       u-boot,dm-spl;
 &pd_lsio {
+       u-boot,dm-spl;
 &pd_lsio_gpio0 {
+       u-boot,dm-spl;
 &pd_lsio_gpio1 {
+       u-boot,dm-spl;
 &pd_lsio_gpio2 {
+       u-boot,dm-spl;
 &pd_lsio_gpio3 {
+       u-boot,dm-spl;
 &pd_lsio_gpio4 {
+       u-boot,dm-spl;
 &pd_lsio_gpio5 {
+       u-boot,dm-spl;
 &pd_lsio_gpio6 {
+       u-boot,dm-spl;
 &pd_lsio_gpio7 {
+       u-boot,dm-spl;
 &pd_dma {
+       u-boot,dm-spl;
 &pd_dma_lpuart0 {
+       u-boot,dm-spl;
 &pd_dma_lpuart3 {
+       u-boot,dm-spl;
 &pd_conn {
+       u-boot,dm-spl;
 &pd_conn_usbotg0 {
@@ -133,87 +137,87 @@
 &pd_conn_sdch0 {
+       u-boot,dm-spl;
 &pd_conn_sdch1 {
+       u-boot,dm-spl;
 &pd_conn_sdch2 {
+       u-boot,dm-spl;
 &gpio0 {
+       u-boot,dm-spl;
 &gpio1 {
+       u-boot,dm-spl;
 &gpio2 {
+       u-boot,dm-spl;
 &gpio3 {
+       u-boot,dm-spl;
 &gpio4 {
+       u-boot,dm-spl;
 &gpio5 {
+       u-boot,dm-spl;
 &gpio6 {
+       u-boot,dm-spl;
 &gpio7 {
+       u-boot,dm-spl;
 &lpuart3 {
+       u-boot,dm-spl;
 &usbmisc1 {
+       u-boot,dm-spl;
 &usbphy1 {
+       u-boot,dm-spl;
 &usbotg1 {
+       u-boot,dm-spl;
 &usbotg3 {
        phys = <&usbphynop1>;
+       u-boot,dm-spl;
 &usbphynop1 {
        compatible = "cdns,usb3-phy";
        reg = <0x0 0x5B160000 0x0 0x40000>;
        #phy-cells = <0>;
+       u-boot,dm-spl;
 &usdhc1 {
+       u-boot,dm-spl;
        /delete-property/ assigned-clock-parents;
 &usdhc2 {
+       u-boot,dm-spl;
 &wu {
+       u-boot,dm-spl;
@@ -4,3 +4,4 @@
index 5bc4fba5b9..d2726f57e3 100644
@@ -2,6 +2,7 @@
  * Copyright 2018-2021 Toradex
 #include <common.h>
 #include <cpu_func.h>
 #include <env.h>
@@ -102,6 +103,15 @@ int board_early_init_f(void)
        setup_iomux_uart();
+/* Dual bootloader feature will require CAAM access, but JR0 and JR1 will be
+ * assigned to seco for imx8, use JR3 instead.
+#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_DUAL_BOOTLOADER)
+       sc_pm_set_resource_power_mode(-1, SC_R_CAAM_JR3, SC_PM_PW_MODE_ON);
+       sc_pm_set_resource_power_mode(-1, SC_R_CAAM_JR3_OUT, SC_PM_PW_MODE_ON);
+#endif
        return 0;
@@ -186,12 +196,12 @@ int board_init(void)
        return 0;
-/* todo: With that function in ther is no console output in linux, drop for now */
-#if 0
        const char *power_on_devices[] = {
-               "dma_lpuart3",
+               /* UART3 - Debug console */
+               "PD_UART3_RX",
+               "PD_UART3_TX",
                /* HIFI DSP boot */
                "audio_sai0",
@@ -200,7 +210,6 @@ void board_quiesce_devices(void)
        power_off_pd_devices(power_on_devices, ARRAY_SIZE(power_on_devices));
-#endif
 void detail_board_ddr_info(void)
--- /dev/null
@@ -0,0 +1,64 @@
+#include <dm.h>
+#include <spl.h>
+#include <bootm.h>
+                       continue;
+       timer_init();
+#endif
+       return 0;
+#endif
+       arch_cpu_init();
index 0000000000..dd9593962f
--- /dev/null
@@ -0,0 +1,14 @@
+/* BOOT_FROM SD 0x400 */
+BOOT_FROM EMMC_FASTBOOT 0x400
+SOC_TYPE IMX8QX
+CONTAINER
index 61c17a0b0a..221043e060 100644
@@ -1,15 +1,32 @@
 CONFIG_ARM=y
 CONFIG_ARCH_IMX8=y
 CONFIG_DM_GPIO=y
+CONFIG_IMX_CONTAINER_CFG="board/toradex/colibri-imx8x/uboot-container.cfg"
+CONFIG_SPL_BANNER_PRINT=y
+CONFIG_SPL=y
@@ -19,6 +36,11 @@ CONFIG_OF_SYSTEM_SETUP=y
 CONFIG_BOOTDELAY=1
 CONFIG_LOG=y
+CONFIG_SPL_WATCHDOG_SUPPORT=y
@@ -50,10 +72,17 @@ CONFIG_BOOTCOUNT_LIMIT=y
 CONFIG_CLK_IMX8=y
 CONFIG_CPU=y
+CONFIG_SPL_DM=y
+CONFIG_SPL_CLK=y
+CONFIG_FASTBOOT=y
+CONFIG_CMD_FASTBOOT=y
+CONFIG_FASTBOOT_UUU_SUPPORT=y
 CONFIG_FASTBOOT_FLASH=y
+CONFIG_FASTBOOT_USB_DEV=1
 CONFIG_MXC_GPIO=y
 CONFIG_DM_PCA953X=y
 CONFIG_DM_I2C=y
@@ -82,15 +111,19 @@ CONFIG_DM_PCI=y
 CONFIG_PHY=y
 CONFIG_PINCTRL=y
 CONFIG_DM_SERIAL=y
 CONFIG_FSL_LPUART=y
 CONFIG_DM_THERMAL=y
 CONFIG_USB=y
@@ -99,6 +132,11 @@ CONFIG_USB_XHCI_HCD=y
 CONFIG_USB_CDNS3=y
 CONFIG_USB_GADGET=y
+CONFIG_SPL_PHY=y
@@ -107,3 +145,4 @@ CONFIG_SDP_LOADADDR=0x80400000
 CONFIG_PANIC_HANG=y
 CONFIG_OF_LIBFDT_OVERLAY=y
 # CONFIG_EFI_LOADER is not set
+CONFIG_AHAB_BOOT=y
index f9eece3646..b34660dc5d 100644
@@ -9,8 +9,38 @@
+#define CONFIG_SERIAL_LPUART_BASE      0x5a090000
+#endif
+#define CONFIG_BOARD_EARLY_INIT_F
 #define USDHC1_BASE_ADDR                0x5B010000
 #define USDHC2_BASE_ADDR                0x5B020000
Hi @justin.mcdowell.s7,
Thank you for coming back and sharing your findings. This is very helpful for anyone else hoping to implement something similar.
