I have noticed that u-boot comes with BSP 5.7.6 (reference multimedia image) produces an error before jumping to linux kernel for the internal mmc. The error can be seen in the following log:
U-Boot 2020.04-5.7.6+git.e72d2f7c00a1 (Mar 08 2024 - 14:31:38 +0000)
CPU: i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 50C
Reset cause: POR
DRAM: 4 GiB
MMC: FSL_SDHC: 1, FSL_SDHC: 2
In: serial
Out: serial
Err: serial
Model: Toradex Verdin iMX8M Plus Quad 4GB Wi-Fi / BT IT V1.1B, Serial# 15287933
Carrier: Toradex Dahlia V1.1C, Serial# 10952624
BuildInfo:
- ATF 2fa8c63
- U-Boot 2020.04-5.7.6+git.e72d2f7c00a1
Setting variant to wifi
flash target is MMC:2
Net: eth1: ethernet@30be0000, eth0: ethernet@30bf0000 [PRIME]
Fastboot: Normal
Normal Boot
MMC: no card present
switch to partitions #0, OK
mmc2(part 0) is current device
Scanning mmc 2:1...
Found U-Boot script /boot.scr
5964 bytes read in 7 ms (832 KiB/s)
## Executing script at 47000000
Loading DeviceTree: imx8mp-verdin-wifi-dev.dtb
88891 bytes read in 13 ms (6.5 MiB/s)
86 bytes read in 6 ms (13.7 KiB/s)
Applying Overlay: verdin-imx8mp_native-hdmi_overlay.dtbo
1860 bytes read in 11 ms (165 KiB/s)
Applying Overlay: verdin-imx8mp_lt8912_overlay.dtbo
1987 bytes read in 13 ms (148.4 KiB/s)
10717259 bytes read in 101 ms (101.2 MiB/s)
Uncompressed size: 25831936 = 0x18A2A00
Bootargs: root=PARTUUID=a5a15bf4-02 ro rootwait console=tty1 console=ttymxc2,115200 consoleblank=0 earlycon
## Flattened Device Tree blob at 44000000
Booting using the fdt blob at 0x44000000
Loading Device Tree to 00000000fdbba000, end 00000000fdbf2fff ... OK
Starting kernel ...
switch failed 1/183/0x2 !
switch failed 1/183/0x0 !
switch failed 1/183/0x1 !
unable to select a mode
device_remove: Device 'mmc@30b60000.blk' failed to remove, but children are gone
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.4.193-5.7.6+git.cf754d7aaa94 (oe-user@oe-host) (gcc version 9.5.0 (GCC)) #1 SMP PREEMPT Wed Jan 31 20:07:14 UTC 2024
The same error is not available with BSP 6.7.0 (reference multimedia image), here is the log for it:
U-Boot 2022.04-6.7.0+git.7588eb559ca2 (May 28 2024 - 11:19:14 +0000)
Reset cause: POR
DRAM: 4 GiB
Core: 89 devices, 23 uclasses, devicetree: separate
WDT: Started watchdog@30280000 with servicing (60s timeout)
In: serial
Out: serial
Err: serial
Model: Toradex 0058 Verdin iMX8M Plus Quad 4GB WB IT V1.1B
Serial#: 15287933
SEC0: RNG instantiated
BuildInfo:
- ATF 3c1583b
Fastboot: Normal
Normal Boot
Scanning mmc 2:1...
6010 bytes read in 1 ms (5.7 MiB/s)
## Executing script at 50280000
90278 bytes read in 1 ms (86.1 MiB/s)
118 bytes read in 1 ms (115.2 KiB/s)
Applying Overlay: verdin-imx8mp_hdmi_overlay.dtbo
2219 bytes read in 1 ms (2.1 MiB/s)
Applying Overlay: verdin-imx8mp_dsi-to-hdmi_overlay.dtbo
3652 bytes read in 1 ms (3.5 MiB/s)
Applying Overlay: verdin-imx8mp_spidev_overlay.dtbo
561 bytes read in 1 ms (547.9 KiB/s)
11675535 bytes read in 42 ms (265.1 MiB/s)
Bootargs: root=PARTUUID=4cbdc672-02 ro rootwait console=tty1 console=ttymxc2,115200 consoleblank=0 earlycon
Uncompressing Kernel Image
## Flattened Device Tree blob at 50200000
Booting using the fdt blob at 0x50200000
Loading Device Tree to 00000000ffac0000, end 00000000ffaf9fff ... OK
Starting kernel ...
[ 0.000000] Linux version 5.15.148-6.7.0+git.bfdbfb2c85fb (oe-user@oe-host) (aarch64-tdx-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Thu Jun 20 15:59:41 UTC 2024
Did you investigate this error before?
Is it harmful for the production?
Thank you.
