When using the torizoncore builder on my Azure VM I have an odd issue, most of the time it works fine, but sometimes I run into an ConnectionRefusedError when using the bundle command. It is hard to determine exactly what happens as it doesn’t happen very often. It is however an issue for me as the bundle command is part of our build pipeline, and it failing means the whole build fails.
I was able to capture debug logs of the issue occurring but when I ran the exact same command again afterwards it somehow worked.
c.pennings@terberg.com@aztamyocto:~/torizon-core-builder$ source tcb-env-setup.sh
You may have an outdated version installed. Would you like to check for updates online? [y/n] n
Setting up TorizonCore Builder with version 3.
Setup complete! TorizonCore Builder is now ready to use.
TorizonCore Builder internal status and image customizations will be stored in Docker volume named 'storage'.
Important: When you run TorizonCore Builder, the tool can only access the files inside the current working directory. Files and directories outside of the current working directory, or links to files and directories outside of the current working directory, won't be visible to TorizonCore Builder. So please make sure that, when running TorizonCore Builder, all files and directories passed as parameters are within the current working directory.
Your current working directory is: /home/c.pennings/torizon-core-builder
For more information, run 'torizoncore-builder -h' or go to https://developer.toradex.com/knowledge-base/torizoncore-builder-tool
c.pennings@terberg.com@aztamyocto:~/torizon-core-builder$ torizoncore-builder --log-level DEBUG bundle --platform=linux/arm/v7 docker-compose.yml --bundle-directory bundle --login-to docker
.io casperterberg *****
2024-10-10 10:21:48,398 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2024-10-10 10:21:48,398 - docker.utils.config - DEBUG - No config file found
2024-10-10 10:21:48,408 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /version HTTP/11" 200 826
2024-10-10 10:21:48,410 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/json?limit=-1&all=0&size=0&trunc_cmd=0&filters=%7B%22name%22%3A+%5B%22tcb_1728555707%22%5D%7D HTTP/11" 200 1741
2024-10-10 10:21:48,411 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/0f02b04e3d1360348b7ebcee9d4e68cbf03147e65ddf202eb32c100d85826445/json HTTP/11" 200 None
2024-10-10 10:21:48,411 - torizon.tcbuilder.backend.common - DEBUG - Current container ID (found by container name): 0f02b04e3d1360348b7ebcee9d4e68cbf03147e65ddf202eb32c100d85826445
2024-10-10 10:21:48,412 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/0f02b04e3d1360348b7ebcee9d4e68cbf03147e65ddf202eb32c100d85826445/json HTTP/11" 200 None
2024-10-10 10:21:48,413 - torizon.tcbuilder.cli.bundle - INFO - Creating Docker Container bundle...
2024-10-10 10:21:48,413 - compose.config.config - DEBUG - Using configuration files: /workdir/docker-compose.yml
2024-10-10 10:21:48,427 - torizon.tcbuilder.backend.bundle - DEBUG - Using DindManager
2024-10-10 10:21:48,427 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2024-10-10 10:21:48,427 - docker.utils.config - DEBUG - No config file found
2024-10-10 10:21:48,432 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /version HTTP/11" 200 826
2024-10-10 10:21:48,438 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/info HTTP/11" 200 None
2024-10-10 10:21:48,438 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2024-10-10 10:21:48,438 - docker.utils.config - DEBUG - No config file found
2024-10-10 10:21:48,442 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /version HTTP/11" 200 826
2024-10-10 10:21:48,444 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/json?limit=-1&all=0&size=0&trunc_cmd=0&filters=%7B%22name%22%3A+%5B%22tcb_1728555707%22%5D%7D HTTP/11" 200 1741
2024-10-10 10:21:48,445 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/0f02b04e3d1360348b7ebcee9d4e68cbf03147e65ddf202eb32c100d85826445/json HTTP/11" 200 None
2024-10-10 10:21:48,445 - torizon.tcbuilder.backend.common - DEBUG - Current container ID (found by container name): 0f02b04e3d1360348b7ebcee9d4e68cbf03147e65ddf202eb32c100d85826445
2024-10-10 10:21:48,446 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/0f02b04e3d1360348b7ebcee9d4e68cbf03147e65ddf202eb32c100d85826445/json HTTP/11" 200 None
2024-10-10 10:21:48,446 - torizon.tcbuilder.backend.bundle - INFO -
Starting DIND container
2024-10-10 10:21:48,446 - torizon.tcbuilder.backend.bundle - INFO - Using Docker host "tcp://127.0.0.1:22376"
2024-10-10 10:21:48,451 - urllib3.connectionpool - DEBUG - http://localhost:None "POST /v1.46/volumes/create HTTP/11" 201 182
2024-10-10 10:21:48,451 - torizon.tcbuilder.backend.bundle - DEBUG - Default platform: linux/arm/v7
2024-10-10 10:21:48,451 - torizon.tcbuilder.backend.bundle - DEBUG - Volume mapping for DinD: [{'Target': '/workdir/', 'Source': '/home/c.pennings/torizon-core-builder', 'Type': 'bind', 'ReadOnly': False}, {'Target': '/var/lib/docker/', 'Source': 'dind-volume', 'Type': 'volume', 'ReadOnly': False}]
2024-10-10 10:21:48,451 - torizon.tcbuilder.backend.bundle - DEBUG - Running DinD container: ports=None, network=host
2024-10-10 10:21:48,564 - urllib3.connectionpool - DEBUG - http://localhost:None "POST /v1.46/containers/create?name=tcb-fetch-dind HTTP/11" 201 88
2024-10-10 10:21:48,565 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/570bc0a78c48632d1ce9afd798226ca8b4d2b376dbd8cec98a505e24ffa4a9ed/json HTTP/11" 200 None
2024-10-10 10:21:48,682 - urllib3.connectionpool - DEBUG - http://localhost:None "POST /v1.46/containers/570bc0a78c48632d1ce9afd798226ca8b4d2b376dbd8cec98a505e24ffa4a9ed/start HTTP/11" 204 0
2024-10-10 10:21:50,685 - torizon.tcbuilder.backend.bundle - INFO - Connecting to Docker Daemon at "tcp://127.0.0.1:22376"
2024-10-10 10:21:50,685 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2024-10-10 10:21:50,685 - docker.utils.config - DEBUG - No config file found
2024-10-10 10:21:50,686 - urllib3.connectionpool - DEBUG - Starting new HTTPS connection (1): 127.0.0.1:22376
2024-10-10 10:21:50,686 - torizon.tcbuilder.backend.bundle - INFO - Stopping DIND container
2024-10-10 10:21:50,762 - urllib3.connectionpool - DEBUG - http://localhost:None "POST /v1.46/containers/570bc0a78c48632d1ce9afd798226ca8b4d2b376dbd8cec98a505e24ffa4a9ed/stop HTTP/11" 204 0
2024-10-10 10:21:51,769 - urllib3.connectionpool - DEBUG - http://localhost:None "DELETE /v1.46/volumes/dind-volume HTTP/11" 204 0
2024-10-10 10:21:51,769 - root - CRITICAL - An unexpected Exception occurred. Please provide the following stack trace to
the Toradex TorizonCore support team:
2024-10-10 10:21:51,787 - root - ERROR - Traceback (most recent call last):
File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 196, in _new_conn
sock = connection.create_connection(
File "/usr/local/lib/python3.9/dist-packages/urllib3/util/connection.py", line 85, in create_connection
raise err
File "/usr/local/lib/python3.9/dist-packages/urllib3/util/connection.py", line 73, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 789, in urlopen
response = self._make_request(
File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 490, in _make_request
raise new_e
File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 466, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 1095, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 615, in connect
self.sock = sock = self._new_conn()
File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 211, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7f9d282c3a60>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/local/lib/python3.9/dist-packages/requests/adapters.py", line 589, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 843, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.9/dist-packages/urllib3/util/retry.py", line 519, in increment
raise MaxRetryError(_pool, url, reason) from reason # type: ignore[arg-type]
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='127.0.0.1', port=22376): Max retries exceeded with url: /version (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f9d282c3a60>: Failed to establish a new connection: [Errno 111] Connection refused'))
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 223, in _retrieve_server_version
return self.version(api_version=False)["ApiVersion"]
File "/usr/local/lib/python3.9/dist-packages/docker/api/daemon.py", line 181, in version
return self._result(self._get(url), json=True)
File "/usr/local/lib/python3.9/dist-packages/docker/utils/decorators.py", line 44, in inner
return f(self, *args, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 246, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 602, in get
return self.request("GET", url, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/requests/adapters.py", line 622, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='127.0.0.1', port=22376): Max retries exceeded with url: /version (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f9d282c3a60>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/builder/torizoncore-builder", line 222, in <module>
mainargs.func(mainargs)
File "/builder/tcbuilder/cli/bundle.py", line 97, in do_bundle
bundle(bundle_dir=args.bundle_directory,
File "/builder/tcbuilder/cli/bundle.py", line 49, in bundle
bundle_be.download_containers_by_compose_file(
File "/builder/tcbuilder/backend/bundle.py", line 555, in download_containers_by_compose_file
dind_client = manager.get_client()
File "/builder/tcbuilder/backend/bundle.py", line 320, in get_client
dind_client = docker.DockerClient(base_url=self.docker_host, tls=tls_config)
File "/usr/local/lib/python3.9/dist-packages/docker/client.py", line 45, in __init__
self.api = APIClient(*args, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 207, in __init__
self._version = self._retrieve_server_version()
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 230, in _retrieve_server_version
raise DockerException(
docker.errors.DockerException: Error while fetching server API version: HTTPSConnectionPool(host='127.0.0.1', port=22376): Max retries exceeded with url: /version (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f9d282c3a60>: Failed to establish a new connection: [Errno 111] Connection refused'))
And immediately afterwards running the same command again:
c.pennings@terberg.com@aztamyocto:~/torizon-core-builder$ torizoncore-builder --log-level DEBUG bundle --platform=linux/arm/v7 docker-compose.yml --bundle-directory bundle --login-to docker.io casperterberg ***
2024-10-10 10:30:24,470 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2024-10-10 10:30:24,470 - docker.utils.config - DEBUG - No config file found
2024-10-10 10:30:24,476 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /version HTTP/11" 200 826
2024-10-10 10:30:24,477 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/json?limit=-1&all=0&size=0&trunc_cmd=0&filters=%7B%22name%22%3A+%5B%22tcb_1728556223%22%5D%7D HTTP/11" 200 1741
2024-10-10 10:30:24,478 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/e062d06acc82769a0393a9cd496bcdc8c22399a76a09079cf18cb3c53de5dd89/json HTTP/11" 200 None
2024-10-10 10:30:24,479 - torizon.tcbuilder.backend.common - DEBUG - Current container ID (found by container name): e062d06acc82769a0393a9cd496bcdc8c22399a76a09079cf18cb3c53de5dd89
2024-10-10 10:30:24,479 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/e062d06acc82769a0393a9cd496bcdc8c22399a76a09079cf18cb3c53de5dd89/json HTTP/11" 200 None
2024-10-10 10:30:24,480 - torizon.tcbuilder.cli.bundle - INFO - Creating Docker Container bundle...
2024-10-10 10:30:24,480 - compose.config.config - DEBUG - Using configuration files: /workdir/docker-compose.yml
2024-10-10 10:30:24,485 - torizon.tcbuilder.backend.bundle - DEBUG - Using DindManager
2024-10-10 10:30:24,485 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2024-10-10 10:30:24,486 - docker.utils.config - DEBUG - No config file found
2024-10-10 10:30:24,486 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2024-10-10 10:30:24,491 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /version HTTP/11" 200 826
2024-10-10 10:30:24,496 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/info HTTP/11" 200 None
2024-10-10 10:30:24,496 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2024-10-10 10:30:24,496 - docker.utils.config - DEBUG - No config file found
2024-10-10 10:30:24,501 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /version HTTP/11" 200 826
2024-10-10 10:30:24,502 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/json?limit=-1&all=0&size=0&trunc_cmd=0&filters=%7B%22name%22%3A+%5B%22tcb_1728556223%22%5D%7D HTTP/11" 200 1741
2024-10-10 10:30:24,503 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/e062d06acc82769a0393a9cd496bcdc8c22399a76a09079cf18cb3c53de5dd89/json HTTP/11" 200 None
2024-10-10 10:30:24,503 - torizon.tcbuilder.backend.common - DEBUG - Current container ID (found by container name): e062d06acc82769a0393a9cd496bcdc8c22399a76a09079cf18cb3c53de5dd89
2024-10-10 10:30:24,504 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/e062d06acc82769a0393a9cd496bcdc8c22399a76a09079cf18cb3c53de5dd89/json HTTP/11" 200 None
2024-10-10 10:30:24,504 - torizon.tcbuilder.backend.bundle - INFO -
2024-10-10 10:30:24,504 - torizon.tcbuilder.backend.bundle - INFO - Using Docker host "tcp://127.0.0.1:22376"
2024-10-10 10:30:24,510 - urllib3.connectionpool - DEBUG - http://localhost:None "POST /v1.46/volumes/create HTTP/11" 201 182
2024-10-10 10:30:24,510 - torizon.tcbuilder.backend.bundle - DEBUG - Default platform: linux/arm/v7
2024-10-10 10:30:24,510 - torizon.tcbuilder.backend.bundle - DEBUG - Volume mapping for DinD: [{'Target': '/workdir/', 'Source': '/home/c.pennings/torizon-core-builder', 'Type': 'bind', 'ReadOnly': False}, {'Target': '/var/lib/docker/', 'Source': 'dind-volume', 'Type': 'volume', 'ReadOnly': False}]
2024-10-10 10:30:24,510 - torizon.tcbuilder.backend.bundle - DEBUG - Running DinD container: ports=None, network=host
2024-10-10 10:30:24,596 - urllib3.connectionpool - DEBUG - http://localhost:None "POST /v1.46/containers/create?name=tcb-fetch-dind HTTP/11" 201 88
2024-10-10 10:30:24,597 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/29163f294f150b6debfa7eba4aa383c9913b318bf5f002fca7c06c67b2b72b4d/json HTTP/11" 200 None
2024-10-10 10:30:24,700 - urllib3.connectionpool - DEBUG - http://localhost:None "POST /v1.46/containers/29163f294f150b6debfa7eba4aa383c9913b318bf5f002fca7c06c67b2b72b4d/start HTTP/11" 204 0
2024-10-10 10:30:27,703 - torizon.tcbuilder.backend.bundle - INFO - Connecting to Docker Daemon at "tcp://127.0.0.1:22376"
2024-10-10 10:30:27,703 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2024-10-10 10:30:27,703 - docker.utils.config - DEBUG - No config file found
2024-10-10 10:30:27,704 - urllib3.connectionpool - DEBUG - Starting new HTTPS connection (1): 127.0.0.1:22376
2024-10-10 10:30:27,769 - urllib3.connectionpool - DEBUG - https://127.0.0.1:22376 "GET /version HTTP/11" 200 861
2024-10-10 10:30:27,769 - torizon.tcbuilder.backend.bundle - INFO - Attempting to log in to registry 'docker.io' with username=casperterberg
2024-10-10 10:30:27,769 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2024-10-10 10:30:27,769 - docker.utils.config - DEBUG - No config file found
2024-10-10 10:30:27,769 - docker.auth - DEBUG - Looking for auth entry for 'docker.io'
2024-10-10 10:30:27,769 - docker.auth - DEBUG - No entry found
2024-10-10 10:30:29,135 - urllib3.connectionpool - DEBUG - https://127.0.0.1:22376 "POST /v1.40/auth HTTP/11" 200 48
2024-10-10 10:30:29,135 - torizon.tcbuilder.backend.bundle - INFO - Fetching container image casperterberg/hello-world:latest
2024-10-10 10:30:29,135 - docker.auth - DEBUG - Looking for auth config
2024-10-10 10:30:29,135 - docker.auth - DEBUG - Looking for auth entry for 'docker.io'
2024-10-10 10:30:29,135 - docker.auth - DEBUG - Found 'docker.io'
2024-10-10 10:30:29,135 - docker.auth - DEBUG - Found auth config
2024-10-10 10:30:30,255 - urllib3.connectionpool - DEBUG - https://127.0.0.1:22376 "POST /v1.40/images/create?tag=latest&fromImage=casperterberg%2Fhello-world&platform=linux%2Farm%2Fv7 HTTP/11" 200 None
Pulling from casperterberg/hello-world
2d3d56bba6ab: Pull complete
Digest: sha256:d4d5c6c7728f837602dfefe67da7aae5e318b75ac89b045ea38611e9a998d1b3
Status: Downloaded newer image for casperterberg/hello-world:latest
2024-10-10 10:30:30,722 - urllib3.connectionpool - DEBUG - https://127.0.0.1:22376 "GET /v1.40/images/casperterberg/hello-world:latest/json HTTP/11" 200 1630
2024-10-10 10:30:30,722 - torizon.tcbuilder.backend.bundle - INFO - Saving Docker Compose file
2024-10-10 10:30:30,723 - torizon.tcbuilder.backend.bundle - INFO - Exporting storage
2024-10-10 10:30:30,723 - torizon.tcbuilder.backend.bundle - INFO - Storing container bundle into "bundle"
2024-10-10 10:30:30,723 - torizon.tcbuilder.backend.bundle - DEBUG - Volume mapping for tar container: [{'Target': '/mnt', 'Source': '/home/c.pennings/torizon-core-builder', 'Type': 'bind', 'ReadOnly': False}, {'Target': '/var/lib/docker/', 'Source': 'dind-volume', 'Type': 'volume', 'ReadOnly': True}]
2024-10-10 10:30:30,723 - torizon.tcbuilder.backend.bundle - DEBUG - tar command: ['tar', '--numeric-owner', '--preserve-permissions', '--directory=/var/lib/docker', "--xattrs-include='*'", '--create', '--file', '/mnt/bundle/docker-storage.tar', 'overlay2/', 'image/']
2024-10-10 10:30:30,809 - urllib3.connectionpool - DEBUG - http://localhost:None "POST /v1.46/containers/create?name=tcb-build-tar HTTP/11" 201 88
2024-10-10 10:30:30,811 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.46/containers/a3442572220f14d341b60e3059544790ed7527160150ccd77e95e6f123e28c46/json HTTP/11" 200 None
2024-10-10 10:30:31,170 - urllib3.connectionpool - DEBUG - http://localhost:None "POST /v1.46/containers/a3442572220f14d341b60e3059544790ed7527160150ccd77e95e6f123e28c46/start HTTP/11" 204 0
2024-10-10 10:30:31,171 - urllib3.connectionpool - DEBUG - http://localhost:None "POST /v1.46/containers/a3442572220f14d341b60e3059544790ed7527160150ccd77e95e6f123e28c46/wait HTTP/11" 200 None
2024-10-10 10:30:31,467 - urllib3.connectionpool - DEBUG - http://localhost:None "POST /v1.46/containers/a3442572220f14d341b60e3059544790ed7527160150ccd77e95e6f123e28c46/stop HTTP/11" 304 0
2024-10-10 10:30:31,479 - urllib3.connectionpool - DEBUG - http://localhost:None "DELETE /v1.46/containers/a3442572220f14d341b60e3059544790ed7527160150ccd77e95e6f123e28c46?v=False&link=False&force=False HTTP/11" 204 0
2024-10-10 10:30:31,479 - torizon.tcbuilder.backend.bundle - DEBUG - compression_command: ['xz', '-3', '-z', 'docker-storage.tar']
2024-10-10 10:30:31,494 - torizon.tcbuilder.backend.bundle - INFO - Stopping DIND container
2024-10-10 10:30:32,570 - urllib3.connectionpool - DEBUG - http://localhost:None "POST /v1.46/containers/29163f294f150b6debfa7eba4aa383c9913b318bf5f002fca7c06c67b2b72b4d/stop HTTP/11" 204 0
2024-10-10 10:30:33,581 - urllib3.connectionpool - DEBUG - http://localhost:None "DELETE /v1.46/volumes/dind-volume HTTP/11" 204 0
2024-10-10 10:30:33,582 - torizon.tcbuilder.cli.bundle - INFO - Successfully created Docker Container bundle in "bundle"!
