Torizon OS 7.8.0+build.60 (scarthgap release/60) removed from Artifactory?
On 2026-10-22 we based our custom Torizon OS image (Verdin iMX8M Plus, TorizonCore Builder) on the quarterly image published under
https://artifacts.toradex.com/artifactory/torizoncore-oe-prod-frankfurt/scarthgap-7.x.y/release/60/verdin-imx8mp/torizon/torizon-docker/oedeploy/torizon-docker-verdin-imx8mp-Tezi_7.8.0+build.60.tar
(sha256 f424d9eb15b5eb95f5e43d4d365a445437519cbc8ed6f774beaa560529f776ca).
Today that URL answers 404, the release/ folder ends at build 40 (7.7.0+build.40), and an Artifactory search for *build.60* finds nothing. The release matrix lists 7.7.0 as the latest Torizon OS 7, and the nightlies are still named 7.8.0-devel.
Three questions:
  1. Was 7.8.0+build.60 withdrawn on purpose? If so, why (a known issue we should be aware of on i.MX8M Plus)?
  2. Is a 7.8.0 or 7.8.1 quarterly planned, and when?
  3. Is there a way to get a notice when a published release is removed? We keep the tar locally, but we found out by chance.
Thanks.
I don’t have specific information in the available sources about the withdrawal of Torizon OS 7.8.0+build.60 or the reasons behind its removal from Artifactory.
However, I can provide some relevant context based on the documentation:
What I Can Confirm
The documentation indicates that Toradex maintains images on their artifacts server, and TorizonCore Builder can fetch images directly from there during build time(1). The configuration file supports specifying images with SHA-256 checksums for integrity verification(2).
Recommendations
  1. Check the Release Matrix: The Release Matrix page should list all officially supported releases. If 7.8.0+build.60 isn’t listed there, it may have been a pre-release or development build.
  2. Use Quarterly Releases: The documentation recommends downloading “a Torizon OS 7.x image, preferably the latest quarterly release for better stability”(1). Quarterly releases receive long-term support.
  3. Version Control Your Inputs: The documentation emphasizes version-controlling all build inputs and notes that “if you reference a certain quarterly or monthly release, you know that the exact referenced version will be available to you over the Internet (at least for a period of time)”(1).
For Your Specific Questions
I cannot answer your questions about the specific withdrawal, future 7.8.0/7.8.1 release plans, or notification mechanisms from the available documentation.
For answers about release availability, withdrawal reasons, and release schedules, I recommend:
I’m curious too since I saw it on the release matrix page at one point and toradex-manifest appears to be preparing/prepared for a final release tag.
Based on the available documentation, I cannot find any information about Torizon OS 7.8.0+build.60 or its withdrawal.
What the Documentation Shows
According to the Embedded Linux Release Matrix(1), the latest Torizon OS 7 Series release documented is 7.7.0 (released 07/2026) for all supported modules including Verdin iMX8M Plus. The matrix shows:
  • BSP: 7.7.0
  • Kernel: Downstream Toradex v6.6.142 based on NXP BSP L6.6.52_2.2.2
  • Yocto: 5.0 (Scarthgap)
  • U-Boot: Upstream Toradex 2024.07 based on DENX v2024.07
  • TF-A firmware: NXP lf-6.6.52-2.2.1
  • Release: 07/2026(1)
The documented quarterly releases in the 7.x series are:
  • 7.1.0 (February 2025)(2)
  • 7.2.0 (October 2025)(3)
  • 7.3.0 (documented in community forums)(4)
  • 7.5.0 (February 2026)(5)
  • 7.6.0, 7.6.1, and 7.6.2 (patch releases)(6)(7)
  • 7.7.0 (July 2026)(1)
No mention of 7.8.0 exists in any of the official documentation or release notes I have access to.
My Assessment
Since 7.8.0+build.60 does not appear in the official Release Matrix(1) or any quarterly/patch release announcements, it was likely either:
  • A pre-release/development build that was not intended for production use
  • Temporarily published but withdrawn before official release
For production systems, you should use officially documented quarterly releases from the Release Matrix(1). The current production release for Verdin iMX8M Plus is 7.7.0.
I cannot answer your specific questions about withdrawal reasons, future 7.8.x plans, or notification mechanisms as this information is not available in the documentation.
Greetings @unablesalt and @bw908,
Yes it was. That 7.8.0 release was not meant to be published in the first place. There were no issues with the actual OS itself as far as we know. But there were some internal process checks that failed which should have stopped the release from occurring.
Yes we still plan to do a proper 7.8.0 release. But, we are still fixing the internal process issues referred to above. We don’t have an exact time frame to share at this time other than “soon”.
This was a complete accident and not meant to occur, so we didn’t have a notice ready to send. In theory that local download you have should be “okay” to use. But keep in mind we will have a proper 7.8.0 binary release. I would just treat that download as a “unofficial” release similar to a nightly or monthly build.
Just to inform you both, we’ve recently released a statement on this mistaken release that you both have encountered. I recommend you read the statement for the full description: Torizon OS 7.8.0 Quarterly (7.8.0+build.60) was published prematurely
