We are pleased to announce the Torizon OS 7.5.0 quarterly release for Toradex’s System on Modules.
Torizon OS is our operating system that powers Torizon, a DevOps platform that simplifies the development and maintenance of embedded Linux software. Torizon OS is designed to be used out-of-the-box on devices requiring high reliability, allowing you to focus on your application instead of building and maintaining an operating system.
Torizon uses software containers, making it simple to add functionality to your system in a way that is both secure and easy to maintain. Torizon supports hardware acceleration in containers and graphical user interfaces.
Updates and Highlights
Torizon OS
- Distro updates:
- Bug fixes:
- Fixed an issue that made the build of the Yocto SDK fail for Torizon Minimal
- Fixed splash screen not working on the native LVDS interface of Apalis iMX8QM
- Fixed splash screen not working on any video interface on Verdin iMX95
- Fixed splash screen not working on any video interface on SMARC iMX95
- Fixed an issue that prevented devices from being updated via Torizon Cloud, due to Aktualizr reporting “Current versions in storage and reported by OSTree do not match”
- Fixed boot problem on Apalis iMX6 and the Apalis Evaluation Board, by disabling the CONFIG_KERNEL_THUMB2 for this machine
- Updates from BSP 7.5.0:
- Please also note that Torizon OS is built on top of the Toradex BSP Layers for the Yocto Project. Read the BSP Layers and Reference Images for Yocto Project release news to learn more.
Common Torizon
- Distro updates:
- Added NXP i.MX 93 FRDM Board to meta-toradex-torizon. Get started on the NXP page Getting Started with FRDM-IMX93
- Added Synaptics Astra SL2619 to meta-toradex-torizon. Get started on the page Synaptics Hardware Support
- Bug fixes:
- Fixed build issue for x86 due to upstream builds moving from LZ4C to LZ4 kernel compression
- Fixed fw_printenv and fw_setenv commands not available for x86
- Fixed fw_printenv and fw_setenv commands not available for BeagleY-AI
- Fixed a TI container’s incompatibility issue due to an incompatible driver DDK version on Texas Instruments EVMs and SKs on Common Torizon
Get started with Common Torizon on supported hardware.
Debian Packages and Containers
Full release notes are published in the Torizon Containers repository: Torizon Containers Release Notes.
Highlights
- Containers:
- Added support for the sl1680 platform, targeting the Luna SL1680 SBC
- Added hardware-accelerated graphics rendering (GPU/OpenGL ES) for Luna SL1680
- Added new .NET 10 containers for Torizon
- Bumped .NET to 8.0.22 on the .NET 8 containers for Torizon
Intended Use
The Torizon OS 7.5.0 Quarterly Release is a production-grade release.
Therefore, if you are in production with TorizonCore 5, Torizon OS 6 or earlier Torizon OS 7 releases, we recommend moving to this quarterly release. Learn more in the Torizon Upgrade Notes.
Hardware Support
A quarterly release is a production release, intended to be used in a production environment only with volume products, as long as they are supported by Torizon OS. We run a set of tests to validate them. Learn more about our release types from our Embedded Linux Support Strategy.
- Volume products: Aquila AM69, Verdin AM62, Verdin iMX8M Plus, Verdin iMX8M Mini, SMARC iMX8M Plus, Apalis iMX8, Apalis iMX6, Colibri iMX6ULL 1GB, Colibri iMX6DL, and Colibri iMX7D 1GB, and Colibri iMX8X
This release is intended to be used in production for these modules. - Sample products: Verdin iMX95, Verdin AM62P, and SMARC iMX95
Due to the hardware status of the sample products, this downstream-based release is intended for evaluation and development.
Aquila AM69 support depends on the hardware revision as detailed in the dedicated article on developer center. - Community products: Astra Machina SL1680, and Astra Machina SL2610 Dev Kit from Synaptics; i.MX 93 FRDM Board from NXP; AM62L EVM, AM62P EVM, and AM62 EVK from Texas Instruments; BeagleY-AI from the BeagleBoard Foundation; Generic x86_64
For more details click here: Torizon OS 7.5.0 Quarterly Release
