Torizon IDE Installation Wizard for Windows - Early Access Feedback Thread
:warning: An issue was found with the Docker initialization configuration on the Torizon Development Environment for WSL. Unfortunately, is not possible to update without uninstall the old version and install it again. To uninstall it run the follow command from the VS Code pallet (Windows side):
After run the command, please go through the Torizon IDE Installation Wizard again.
Based on first feedback we added a banner:
This helps to set expectations and remember that this feature is still experimental. And always remember that your feedback is very important to us, so don’t be shy about leaving anything, bad or good, about the feature here.
Thanks,
