Torizon IDE Installation Wizard for Windows - Early Access Feedback Thread
Dear Everyone,
The Torizon Team is happy to announce the release of an attended Installation Wizard to help easily setup VS Code for Torizon development on Windows.
Learn more about it in the blog post Next, Next, Install: The Easiest Way to Setup Your Windows PC for Embedded Linux and in the short video below:
This tool came to life after observing new customers do the setup manually in training sessions and customer calls. And, to close the feedback cycle and further increase your user experience, we look forward to feedback on the first implementation, available in Early Access.
  • How would you rate the new experience setting up a Windows machine for Torizon development?
  • What needs to be improved?
:warning: An issue was found with the Docker initialization configuration on the Torizon Development Environment for WSL. Unfortunately, is not possible to update without uninstall the old version and install it again. To uninstall it run the follow command from the VS Code pallet (Windows side):
After run the command, please go through the Torizon IDE Installation Wizard again.
Based on first feedback we added a banner:
This helps to set expectations and remember that this feature is still experimental. And always remember that your feedback is very important to us, so don’t be shy about leaving anything, bad or good, about the feature here.
Thanks,
I’m having some trouble installing the Torizon IDE extension in Visual Studio code for Windows and was hoping someone here might be able to help.
I followed the steps from a video I found online, but unfortunately, it’s not working as expected. I’ve made sure that my Visual Studio code is up to date, and I’ve tried reinstalling the extension a couple of times with no success.
Here’s a brief overview of what I did:
1.Downloaded the Visual Studios code and installed the Torizon IDE extension.
2. After the system verification tick box is selected then for installing WSL it restarts after that if I tried to install again it starts from system verification tick box and the cycle repeats.
Has anyone else faced this issue or has any insights on what might be going wrong? Are there any additional steps or troubleshooting tips that I might have missed?
Any help or suggestions would be greatly appreciated!
Thanks in advance!
Pankaj
Hey @pankaj_prasad
so, it seems that the wizard was not able to enable the WSL 2 on your system. Could you share the version of your Windows installation and the hardware that you have?
BR,
Hi @ Matheus Castello,
Thanks for the update. My system is running Windows 11 Pro, version 23H2. For hardware, I’m using the Verdin AM625 development board, version 1.1 A.
Pankaj Prasad
Installation of the .NET SDK inside Torizon WSL failed on a fresh install.
(executing “.conf/installDepsScripts/installDotnetSDK8.sh”)
Entered Torizon WSl and did a “sudo apt update” to get the package list for the first time and then it worked with the update script.
I am having trouble with the Torizon IDE installation Wizard too.
After clean install, it goes through System Verification, WSL Installed, Torizon WSL2 Installed, but runs into error on Configure Torizon on WSL2.
:cross_mark: ERROR
The system verification failed.
Please, try to reload the VS Code and try again.
If the problem persists, please, report the issue at https://community.toradex.com/.
What I see is a popup window that disappears quickly.
I think this is supposed to be a Welcome screen with username and password fields.
I can see that the WSL Torizon distribution is created via “wsl --list”.
When launching the Torizon WSL directly, I see this error
wsl
Welcome to the Torizon WSL 2 v0.0.18
Stack overflow.
at SlintDotnet.SlintDotnet._FnRun()
at SlintDotnet.SlintDotnet.Run()
at AppWindow.Window.Run()
at Program.$(System.String)
Error: User not added?
Bye!
Any ideas on how to fix this?
Thank you!
YS.
Hey @YTsa
sorry to hear that you are having issues. Could you please share the content of the follow command:
wsl --version
BR,
WSL version: 2.3.24.0
Kernel version: 5.15.153.1-2
WSLg version: 1.0.65
MSRDC version: 1.2.5620
Direct3D version: 1.611.1-81528511
DXCore version: 10.0.26100.1-240331-1435.ge-release
Windows version: 10.0.22631.4317
Hi @matheus.tx
I’ve already been using Ubuntu-22.04 in WSL2 with Torizon Extension since months, but now I’ve just tried this wizard to install Torizon for WSL2 as a linux distribution.
I followed the video here.
Everything is ok with the installation, and I can see mi Torizon SoMs connected.
Good!
Then I created the same Python 3 Console project as in the video.
I tried to debug it, but I can’t because of the following error:
 *  Executing task: pwsh -nop /home/vix/test/.conf/torizonPackages.ps1 aarch64
Applying torizonPackages.json ...
Applying to Dockerfile.debug ...
✅ Dockerfile.debug
Applying to Dockerfile ...
✅ Dockerfile
torizonPackages.json applied
 *  Executing task: DOCKER_HOST= docker compose --ansi never build --pull --build-arg SSHUSERNAME=torizon --build-arg APP_ROOT=/home/torizon/app --build-arg IMAGE_ARCH=arm64 --build-arg DEBUG_SSH_PORT=6502 --build-arg GPU=-imx8 test-debug
WARN[0000] The "DOCKER_LOGIN" variable is not set. Defaulting to a blank string.
WARN[0000] /home/vix/test/docker-compose.yml: the attribute `version` is obsolete, it will be ignored, please remove it to avoid potential confusion
#0 building with "default" instance using docker driver
#1 [test-debug internal] load build definition from Dockerfile.debug
#1 transferring dockerfile: 2.81kB done
#1 DONE 0.0s
#2 [test-debug internal] load metadata for docker.io/commontorizon/debian:3.3.1-bookworm
#2 DONE 4.8s
#3 [test-debug internal] load .dockerignore
#3 transferring context: 117B done
#3 DONE 0.0s
#4 [test-debug 1/8] FROM docker.io/commontorizon/debian:3.3.1-bookworm@sha256:d62ff0a4cc79fc27ea436ccbe38b8eeec1b2944d9114a923e58496676112720d
#4 DONE 0.0s
#5 [test-debug internal] load build context
#5 transferring context: 43B done
#5 DONE 0.0s
#6 [test-debug 7/8] RUN mkdir /var/run/sshd &&     sed 's@session\s*required\s*pam_loginuid.so@session optional pam_loginuid.so@g'         -i /etc/pam.d/sshd &&     if test torizon != root ;         then mkdir -p /home/torizon/.ssh ;         else mkdir -p /root/.ssh ; fi &&     echo "PermitUserEnvironment yes" >> /etc/ssh/sshd_config &&     echo "PermitRootLogin yes" >> /etc/ssh/sshd_config &&     echo "Port 6502" >> /etc/ssh/sshd_config &&     echo "PasswordAuthentication yes" >> /etc/ssh/sshd_config &&     echo "PermitEmptyPasswords yes" >> /etc/ssh/sshd_config &&     su -c "env" torizon > /etc/environment &&     echo "torizon:" | chpasswd -e
#6 CACHED
#7 [test-debug 3/8] RUN apt-get -q -y update &&     apt-get -q -y install     &&     apt-get clean && apt-get autoremove &&     rm -rf /var/lib/apt/lists/*
#7 CACHED
#8 [test-debug 6/8] RUN . /home/torizon/app/.venv/bin/activate &&     pip3 install --upgrade pip && pip3 install -r requirements-debug.txt &&     rm requirements-debug.txt &&     chown -R torizon:torizon /home/torizon/app
#8 CACHED
#9 [test-debug 2/8] RUN apt-get -q -y update &&     apt-get -q -y install     openssl     openssh-server     rsync     file     screen     python3-minimal     python3-pip     python3-setuptools     python3-venv     && apt-get clean && apt-get autoremove &&     rm -rf /var/lib/apt/lists/*
#9 CACHED
#10 [test-debug 4/8] RUN python3 -m venv /home/torizon/app/.venv --system-site-packages
#10 CACHED
#11 [test-debug 5/8] COPY requirements-debug.txt /requirements-debug.txt
#11 CACHED
#12 [test-debug 8/8] RUN rm -r /etc/ssh/ssh*key &&     dpkg-reconfigure openssh-server
#12 CACHED
#13 [test-debug] exporting to image
#13 exporting layers done
#13 writing image sha256:05a7ecb5363fa11fd281d07a0f31f0a94f2dcf662d691c9ec1e90cd3d9d14748 done
#13 naming to localhost:5002/test-debug:arm64 done
#13 DONE 0.0s
#14 [test-debug] resolving provenance for metadata file
#14 DONE 0.0s
 *  Executing task: DOCKER_HOST= docker compose --ansi never push test-debug
 Pushing localhost:5002/test-debug:arm64: 6b6184be22d2 Preparing
 Pushing localhost:5002/test-debug:arm64: f7cbadd5a280 Preparing
 Pushing localhost:5002/test-debug:arm64: 41dc7bdcb7be Preparing
 Pushing localhost:5002/test-debug:arm64: 819ebf64c20f Preparing
 Pushing localhost:5002/test-debug:arm64: 929377a53df4 Preparing
 Pushing localhost:5002/test-debug:arm64: 59b3ae74375f Preparing
 Pushing localhost:5002/test-debug:arm64: cc2d578af58b Preparing
 Pushing localhost:5002/test-debug:arm64: bb95280742bd Preparing
 Pushing localhost:5002/test-debug:arm64: d5661228a6f6 Preparing
 Pushing localhost:5002/test-debug:arm64: 1f74cca9ef3c Preparing
 Pushing localhost:5002/test-debug:arm64: cf08845a6a01 Preparing
 Pushing localhost:5002/test-debug:arm64: e009595c7dc0 Preparing
 Pushing localhost:5002/test-debug:arm64: 6dc89911362e Preparing
 Pushing localhost:5002/test-debug:arm64: 0d7dccc6d0e7 Preparing
 Pushing localhost:5002/test-debug:arm64: 67ca54a26679 Preparing
 Pushing localhost:5002/test-debug:arm64: 3440d23a444f Preparing
 Pushing localhost:5002/test-debug:arm64: 5a49bdb65752 Preparing
 Pushing localhost:5002/test-debug:arm64: 2bd1a2222589 Preparing
 Pushing localhost:5002/test-debug:arm64: 6dc89911362e Waiting
 Pushing localhost:5002/test-debug:arm64: 0d7dccc6d0e7 Waiting
 Pushing localhost:5002/test-debug:arm64: 67ca54a26679 Waiting
 Pushing localhost:5002/test-debug:arm64: cc2d578af58b Waiting
 Pushing localhost:5002/test-debug:arm64: bb95280742bd Waiting
 Pushing localhost:5002/test-debug:arm64: 3440d23a444f Waiting
 Pushing localhost:5002/test-debug:arm64: d5661228a6f6 Waiting
 Pushing localhost:5002/test-debug:arm64: 1f74cca9ef3c Waiting
 Pushing localhost:5002/test-debug:arm64: 5a49bdb65752 Waiting
 Pushing localhost:5002/test-debug:arm64: cf08845a6a01 Waiting
 Pushing localhost:5002/test-debug:arm64: e009595c7dc0 Waiting
 Pushing localhost:5002/test-debug:arm64: 2bd1a2222589 Waiting
 Pushing localhost:5002/test-debug:arm64: 59b3ae74375f Waiting
 Pushing localhost:5002/test-debug:arm64: 6b6184be22d2 Layer already exists
 Pushing localhost:5002/test-debug:arm64: f7cbadd5a280 Layer already exists
 Pushing localhost:5002/test-debug:arm64: 41dc7bdcb7be Layer already exists
 Pushing localhost:5002/test-debug:arm64: 929377a53df4 Layer already exists
 Pushing localhost:5002/test-debug:arm64: 819ebf64c20f Layer already exists
 Pushing localhost:5002/test-debug:arm64: 59b3ae74375f Layer already exists
 Pushing localhost:5002/test-debug:arm64: cc2d578af58b Layer already exists
 Pushing localhost:5002/test-debug:arm64: bb95280742bd Layer already exists
 Pushing localhost:5002/test-debug:arm64: d5661228a6f6 Layer already exists
 Pushing localhost:5002/test-debug:arm64: 1f74cca9ef3c Layer already exists
 Pushing localhost:5002/test-debug:arm64: cf08845a6a01 Layer already exists
 Pushing localhost:5002/test-debug:arm64: 6dc89911362e Layer already exists
 Pushing localhost:5002/test-debug:arm64: e009595c7dc0 Layer already exists
 Pushing localhost:5002/test-debug:arm64: 67ca54a26679 Layer already exists
 Pushing localhost:5002/test-debug:arm64: 0d7dccc6d0e7 Layer already exists
 Pushing localhost:5002/test-debug:arm64: 3440d23a444f Layer already exists
 Pushing localhost:5002/test-debug:arm64: 5a49bdb65752 Layer already exists
 Pushing localhost:5002/test-debug:arm64: 2bd1a2222589 Layer already exists
 *  Executing task: DOCKER_HOST=192.168.137.129:2375 LOCAL_REGISTRY=10.10.10.17 TAG=arm64 GPU=-imx8 DEBUG_SSH_PORT=6502 DEBUG_PORT1=6512 DEBUG_PORT2= DEBUG_PORT3= docker compose --ansi never pull test-debug
 test-debug Pulling
 test-debug Warning Get "http://10.10.10.17:5002/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
WARNING: Some service image(s) must be built from source by running:
    docker compose build test-debug
1 error occurred:
        * Error response from daemon: Get "http://10.10.10.17:5002/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
 *  The terminal process "/bin/bash '-c', 'DOCKER_HOST=192.168.137.129:2375 LOCAL_REGISTRY=10.10.10.17 TAG=arm64 GPU=-imx8 DEBUG_SSH_PORT=6502 DEBUG_PORT1=6512 DEBUG_PORT2= DEBUG_PORT3= docker compose --ansi never pull test-debug'" terminated with exit code: 18.
Can you help with this?
Hey @vix,
this sounds like some issue with your local network configuration. I do not know if you are using some VPN, but probably the extension automatically host IP detection is not getting the right one. Check if the 10.10.10.17 is the right IP, if not, set the follow configuration in your VS Code global settings.json:
"torizon.overwriteHostIp": "192.168.0.6"
Where you should change the 192.168.0.6 with your main interface IP address.
Let me know if this works,
BR.
Hi @matheus.tx
yes, you’re right.
My PC has multiple network interfaces and so adding "torizon.overwriteHostIp" is necessary in my case.
Do you think is possible adding this note to the documentation?
I can give you additional feedback:
  • if on Windows you’re logged with an user without administrative rights, the Wizard doesn’t work because it asks you the administrator password to install WSL (step 2), then it reboots. But then it asks again to install WSL, it asks for administrator password, it reboots and so on.
    • you must open a terminal for the user logged to windows, and run wsl --update from there
    • then the step 2 passes
  • the torizon VM has a user named castello inside the /home folder
    • nothing bad, I think it’s your home folder
Hi @matheus.tx
I have carried out the integration of Torizon IDE Extension step by step using the video. After clicking the CONNECT TO WSL 2 button, I am connected to WSL:Torizon. However, the Torizon IDE Extension is not installed here.
Can you tell me why and what is the best way to proceed?
NicoF
Without logs is hard to say. Could you uninstall the WSL Torizon development for WSL 2 and try again? But, before click on CONNECT TO WSL 2 check the output panel for the logs, then share it here.
BR,
Hey @matheus.tx
The output only shows:
Activating task providers all
The installation wizard shows the following error:
After reload, the wizard says all ok. After connecting to wsl there are still no extensions of docker and torizon installed.
In the output tab there should be a combobox with more options, and there should be Torizon. Switch to this option and see if there are any logs that help us.
BR,
Hello @matheus.tx
Here is the output:
Output_Torizon.txt (10.2 KB)
Best regards
NicoF
…just to extend my last reply: there is a similar problem with a “cd” command of the installation script:
“cd C:\Users<First name> .torizon ;”
It is also misinterpreted, as file name is not quoted.
The Torizon IDE Installation Wizard for Windows fails in my system, so I can not install the Torizon IDE.
The “WSL Installed” check is done. The error comes after, during the Torizon WSL2 installation.
From the outputs, it seems, the error is triggered at this step:
“rm C:\Users<My First name> .torizon*.tar”
Likely reason of the error: my Windows user name is taken from my first name and last name, and there is a space character between.
But the full file name mask (containing my user name with space) of an “rm” command does not have quote before-after, so the file name is parsed as two separate, not existing, file.
