Yes, I tested the tdx reference minimal image and it does boot. However, there are some differences to our setup.
- It uses devicetree
imx6ull-colibri-wifi-eval-v3.dtb, we use one based on imx6ull-colibri-wifi-iris-v2.dtb
- In our original attempt the U-Boot was still based on 5.7.0 bsp
I have tried updating U-Boot to bsp 6.4.0, but that brought up another issue: our u-boot environment is located on a ubi partition and the new u-boot fails to load it with many ecc errors. I think the issue is that the ubifs in the 6.4.0 version has crc16.c added.
We are using mender, which sets the u-boot environment in the ubi. This was working fine with previous version. We’ll contacting them as well, to see if they have any solutions.
Is there any reason the u-boot from 5.7.0 would not work with bsp 6.4.0 kernel? It would simplify things since it does work with mender. I noticed that load addresses were changed.
As for kernel boot problems, we’ll try things like removing changes from our devicetree (we have not changed kernel code). Are there anything else we should be trying?
Mender creates a tezi package which writes the u-boot environment with image that is just zeroes. Is there a way to create the environment
This is the image.json that mender creates:
"config_format": "2",
"autoinstall": true,
"name": "Image Based on Toradex Embedded Linux Reference Minimal Image (development)",
"description": "Minimal image without graphical interface that just boots",
"version": "Mender kirkstone",
"release_date": "2023-12-01",
"prepare_script": "prepare.sh",
"wrapup_script": "wrapup.sh",
"marketing": "mender-tezi-metadata/marketing_mender_toradex.tar",
"icon": "mender-tezi-metadata/mender_toradex_linux.png",
"supported_product_ids": [
"0036",
"0040",
"0044",
"0045"
"mtddevs": [
"name": "u-boot1",
"content": {
"rawfile": {
"filename": "u-boot-nand.imx",
"size": 1
"name": "u-boot2",
"content": {
"rawfile": {
"size": 1
"name": "u-boot-env",
"content": {
"rawfile": {
"filename": "uboot.env",
"size": 1
"name": "ubi",
"content": {
"rawfile": {
"dd_options": "bs=8M",
"filename": "image-colibri-imx6ull.ubimg.gz"
The uboot.env is just zerofilled data. Should we adjust these options?
U-Boot ubi errors:
CPU: Freescale i.MX6ULL rev1.1 900 MHz (running at 396 MHz)
CPU: Commercial temperature grade (0C to 95C) at 42C
Reset cause: POR
DRAM: 512 MiB
Spread Spectrum pll initialized
Core: 79 devices, 17 uclasses, devicetree: separate
NAND: 512 MiB
MMC: FSL_SDHC: 0
Loading Environment from UBI... ubi0 error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 0:0, read 64 bytes
ubi0 error: ubi_io_read: error -74 (ECC error) while reading 2048 bytes from PEB 0:2048, read 2048 bytes
ubi0 error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 1931:0, read 64 bytes
ubi0 error: ubi_io_read: error -74 (ECC error) while reading 2048 bytes from PEB 1931:2048, read 2048 bytes
ubi0 error: ubi_io_read: error -74 (ECC error) while reading 22528 bytes from PEB 4:4096, read 22528 bytes
ubi0 error: ubi_io_read: error -74 (ECC error) while reading 22528 bytes from PEB 5:4096, read 22528 bytes
ubi0 error: vtbl_check: bad CRC at record 2: 0x7efdbff7, not 0x040000
Volume table record 2 dump:
reserved_pebs 397
alignment 1
data_pad 0
vol_type 1
upd_marker 0
name_len 4
name data
crc 0x040000
reserved_pebs 397
alignment 1
data_pad 0
vol_type 1
upd_marker 0
name_len 4
name data
crc 0x040000
ubi0 error: process_lvol: both volume tables are corrupted
ubi0 error: ubi_attach_mtd_dev: failed to attach mtd4, error -22
UBI error: cannot attach mtd4
UBI error: cannot initialize UBI, error -22
UBI init error 22
Please check, if the correct MTD partition is used (size big enough?)
