To address the issue of reading the SoM temperature on your Apalis iMX6Q after upgrading to BSP version 5, you’ll need to ensure that your device tree is correctly configured to enable the temperature sensor. The temperature sensor on the i.MX 6 series is typically accessed through the Industrial Input/Output (IIO) framework, with readings available under the sysfs path /sys/bus/iio/devices/iio:device0/in_temp8_input.
Here are the steps you can follow:
Verify Device Tree Configuration:
- Ensure the thermal sensor node is correctly defined in your device tree. Look for a node under the
thermal-zonessection that references the appropriate sensor. It might look something like this:thermal-zones { cpu-thermal { polling-delay-passive = <1000>; polling-delay = <5000>; thermal-sensors = <&thermal_sensor>; ... }; }; - Make sure the
thermal-sensorsproperty points to the correct sensor node.
Check Kernel Configuration:
- Confirm that the necessary kernel modules for IIO and thermal management are enabled, such as
CONFIG_THERMALandCONFIG_IIO.
Recompile and Deploy:
- After making changes to the device tree, recompile it and deploy the updated binary to your device.
Test the Temperature Reading:
- Once the device tree is correctly configured and deployed, check the temperature reading using:
cat /sys/bus/iio/devices/iio:device0/in_temp8_input
If the issue persists, double-check the device tree bindings and ensure all necessary drivers are loaded at boot. This should help restore the temperature reading functionality on your Apalis iMX6Q module.
Toradex AI Assistant
