SPI not working at iMX6ULL
Continuing the discussion from SPI not working iMX6ULL:
I have a Colibri iMX6ULL 512 MB WB IT V1.1A
First I used bitbake -c devshell virtual/kernel
then modified
the imx6ull-colibri-eval-v3.dtsi as follows:
&ecspi1 {
	mcp2515: can@0 {
		compatible = "microchip,mcp2515";
		pinctrl-names = "default";
		pinctrl-0 = <&pinctrl_can_int>;
		reg = <0>;
		clocks = <&clk16m>;
		interrupt-parent = <&gpio2>;
		interrupts = <4 IRQ_TYPE_EDGE_FALLING>;
		spi-max-frequency = <10000000>;
		vdd-supply = <&reg_3v3>;
		xceiver-supply = <&reg_5v0>;
		status = "disabled";
        spidev0: spidev@0 {
                compatible = "toradex,evalspi";
                reg = <0>;
                spi-max-frequency = <23000000>;
Then make dtbs
Then bitbake -f -c compile virtual/kernel
Then executed bitbake tdx-reference-minimal-image
The image was installed with the easy installer
There is no SPI devices under /dev/
If I check: ls /sys/bus/spi/devices/ there is
spi0.0
I checked: zcat /proc/config.gz | grep -i spidev
CONFIG_SPI_SPIDEV=m
How to enable SPI correctly?
To enable SPI on your Colibri iMX6ULL module and ensure the spidev device appears under /dev/, please follow these steps:
  1. Device Tree Configuration:
    • You’ve modified the imx6ull-colibri-eval-v3.dtsi file. Ensure the mcp2515 node is set to status = "disabled"; and the spidev0 node is set to status = "okay";. This is important because the MCP2515 SPI CAN controller might block access to the spidev interface if enabled.
  2. Rebuild the Device Tree:
    • After making changes, run make dtbs to rebuild the device tree blobs.
    • Ensure the updated device tree is compiled and included in your build by executing bitbake -f -c compile virtual/kernel followed by bitbake tdx-reference-minimal-image.
  3. Deploy the Updated Image:
    • Use the Toradex Easy Installer to flash the updated image onto your module. Verify that the correct device tree is being used by checking the boot logs or the /boot directory on your device.
  4. Verify SPI Device:
    • After booting the updated image, check for the presence of the spidev device by listing the contents of /dev/. You should see a device like /dev/spidev0.0 if everything is configured correctly.
    • Additionally, verify the SPI bus by checking /sys/bus/spi/devices/ to ensure the spidev device is registered.
  5. Troubleshooting:
    • If the spidev device still does not appear, double-check the device tree changes and ensure they are correctly applied.
    • Review the kernel configuration to ensure CONFIG_SPI_SPIDEV is set to m (module) or y (built-in).
    • Check the boot logs (dmesg) for any errors related to SPI or device tree loading.
By following these steps, you should be able to enable SPI and access the spidev interface on your Colibri iMX6ULL module.
Toradex AI Assistant
SPI on Colibri IMX6ULL.
