I’m trying to get spidev working on a Colibri IMX6ULL. I’ve patched imx6ull-colibri-eval-v3.dtsi which results in:
&ecspi1 {
mcp2515: can@0 {
compatible = "microchip,mcp2515";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_can_int>;
reg = <0>;
clocks = <&clk16m>;
interrupt-parent = <&gpio2>;
interrupts = <4 IRQ_TYPE_EDGE_FALLING>;
spi-max-frequency = <10000000>;
vdd-supply = <®_3v3>;
xceiver-supply = <®_5v0>;
status = "disabled";
spidev0: spidev@0 {
compatible = "toradex,evalspi";
reg = <0>;
spi-max-frequency = <23000000>;
However, when I boot the image I don’t have a /dev/spidev. I have a /sys/bus/spi/devices/spi0.0 though.
dmesg | grep spi shows:
[ 13.927919] platform 2008000.spi: deferred probe pending
I’m using a Colibri Evaluation Board V3.2B. The BSP is 6.2
What am I doing wrong?
Regards, Ron
adrian
2
I have the same issue, everything works fine with BSP3 but not BSP6
I do not have the ‘deferred probe’ issue .. i have found this is usually when a pin is being used for something else already
I have also tried to enable SPI3
&ecspi3 {
status = “okay”;
spidev2: spidev@2 {
compatible = “toradex,evalspi”;
reg = <0>;
num-chipselects = <0>;
status = “okay”;
but get the following error when building the dtb file
Warning (spi_bus_reg): /soc/bus@2000000/spa-bus@2010000/spidev@2: SPI bus unit address format error, expected “0”
adrian
3
I have taken a look at the example overlay and changed my device tree to
&ecspi1 {
#address-cells = <1>;
#size-cells = <0>;
status = “okay”;
spidev@0 {
/* Use compatible "rohm,dh2228fv" to bind spidev driver */
compatible = "rohm,dh2228fv";
reg = <0>;
and ‘spidev0.0’ appeared in /dev
The interface then worked
I still have an issue trying to get SPI2 to work thou
Hi @rondegroot ,
Just to be sure, is your Colibri iMX6ULL the eMMC version? If it is then you can apply a device tree overlay to enable SPIDEV:
If it isn’t you can take a look at our spidev overlay source file and change the device tree based on it (the master branch should be good for BSP 6):
Lucas Akira
Thanks,
compatible = “rohm,dh2228fv”; did solve my issue.
Regards, Ron
Glad I was able to help!
Lucas Akira
