To enable Secure Boot on your Apalis iMX6 module using U-Boot 2019.07, it’s important to address the error you’re encountering, where the u-boot.img file is missing. This issue may stem from a misconfiguration or incorrect file paths in your build setup.
Here are some steps to help you troubleshoot and resolve this:
Verify Configuration: Ensure that the CONFIG_SECURE_BOOT=y option is correctly set in your apalis_imx6_defconfig. This is crucial for enabling Secure Boot support in U-Boot.
Check File Paths: The error suggests that the build process cannot locate the u-boot.img file. Double-check that your build environment paths are correct and that the necessary files are being generated in the expected directories.
Dependencies and Tools: Confirm that all required tools and dependencies for building U-Boot are installed on your system, including the ARM GNU Toolchain for cross-compilation.
Build Process: Follow the standard procedure for building U-Boot:
Obtain the U-Boot source code from the appropriate repository.
Apply any necessary patches specific to your module.
Configure U-Boot using the correct defconfig for your module.
Compile U-Boot, ensuring no errors occur during the process.
Secure Boot Setup: Beyond resolving the compilation error, ensure your Secure Boot environment is correctly configured:
Generate and manage signing keys securely.
Configure the HAB (High Assurance Boot) settings according to NXP’s guidelines.
Sign the U-Boot binary and other necessary components.
By following these steps, you should be able to resolve the compilation issue and proceed with enabling Secure Boot on your device. If further issues arise, ensure that all configurations align with the specific requirements of your hardware and software environment.
Toradex AI Assistant
