We are aiming to implement full Secure Boot Chain of Trust with U-Boot and an OS that is not linux on a apalis-imx6. To that aim we have started experimenting with U-Boot.
We are trying to modify and build U-Boot from source. Our main guide has been Build U-Boot From Source Code and we were able to build it without modifications.
Then following these guides and posts:
https://github.com/u-boot/u-boot/blob/master/doc/imx/habv4/guides/mx8m_spl_secure_boot.txthttps://github.com/u-boot/u-boot/blob/master/doc/imx/habv4/guides/mx6_mx7_spl_secure_boot.txthttps://community.toradex.com/t/enable-hab-on-apalis-imx6-raises-build-error-in-u-boot/20516
We were able to build U-Boot with HAB enabled and sign SPL and U-Boot images with NXP’s CST tool. We used the imx6_template.csf from the meta-toradex-security layer as a template for our own CSF script file.
We downloaded the Reference Minimal Embedded Linux Image , replaced the SPL and U-Boot binaries with the ones we built and flashed it to a board with Toradex Easy Installer. U-Boot and Linux booted OK.
We stopped U-Boot from booting and from the U-Boot console we executed the hab_status command. We got the following output:
Industrial temperature grade DDR3 timings.
Trying to boot from MMC1
hab fuse not enabled
Authenticate image from DDR location 0x177fffc0...
U-Boot 2022.07-00015-g8fca111e67 (Jul 22 2024 - 14:13:39 -0300)
CPU: Freescale i.MX6D rev1.6 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 32C
Reset cause: POR
DRAM: 1 GiB
PMIC: device id: 0x10, revision id: 0x21, programmed
Core: 113 devices, 19 uclasses, devicetree: separate
MMC: FSL_SDHC: 1, FSL_SDHC: 2, FSL_SDHC: 0
In: serial@2020000
Out: serial@2020000
Err: serial@2020000
Model: Toradex 0035 Apalis iMX6D 1GB IT V1.1B
Serial#: 10591417
SEC0: RNG instantiated
Net: eth0: ethernet@2188000
Apalis iMX6 # hab_status
Secure boot disabled
HAB Configuration: 0xf0, HAB State: 0x66
--------- HAB Event 1 -----------------
event data:
0xdb 0x00 0x24 0x42 0x69 0x30 0xe1 0x1d
0x00 0x04 0x00 0x02 0x40 0x00 0x36 0x06
0x55 0x55 0x00 0x03 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x01
STS = HAB_WARNING (0x69)
RSN = HAB_ENG_FAIL (0x30)
CTX = HAB_CTX_ENTRY (0xE1)
ENG = HAB_ENG_CAAM (0x1D)
We were expecting to get:
No HAB Events Found!
What could be the problem?
Regards.
