I am working with the Apalis iMX8 module using the TDX Reference Multimedia Image (BSP 6.8.0) built with Yocto. My goal is to establish communication between Cortex-M4 and Linux using RPMsg.
I have downloaded the SDK for Cortex-M4 from the NXP website and built the rpmsg_lite_str_echo_rtos example application. The application is successfully loaded onto the Cortex-M4_0 processor, and the only output I see on the M4 side is:
RPMSG String Echo FreeRTOS RTOS API Demo...
However, on the Linux side, /dev/ttyRPMSG0 is not created. Running dmesg | grep rpmsg shows:
[ 0.397693] imx rpmsg driver is registered.
Do I need to modify the device tree or provide a device tree overlay to enable RPMsg on Linux? If so, where can I find a working example or the necessary modifications?
To enable RPMsg communication between the Cortex-M4 and Linux on your Apalis iMX8 module, you will indeed need to ensure that the device tree is configured to support RPMsg. This typically involves using a device tree overlay to allocate the necessary resources for RPMsg communication.
Here’s a step-by-step guide to help you:
Check for Existing Overlays: First, verify if there is an existing RPMsg overlay for your module. This overlay might be named something like rpmsg-imx8.dts.
Apply the Overlay: Use the fw_setenv command to set the fdt_overlays environment variable in U-Boot to include the RPMsg overlay. For example:
Replace <existing_overlays> with any other overlays you are currently using.
Reboot the Module: After applying the overlay, reboot your module to apply the changes.
Load the RPMsg Kernel Module: Once Linux has booted, ensure that the RPMsg kernel module is loaded by running:
modprobe imx_rpmsg_tty
Check dmesg Logs: Use dmesg | grep rpmsg to verify that the RPMsg driver is registered and functioning correctly.
If the /dev/ttyRPMSG0 device still does not appear, double-check the device tree overlay for any errors and ensure that the RPMsg example application on the Cortex-M4 is running correctly. Also, verify that the memory regions used by RPMsg are not being used by other parts of the system.
I hope this helps you get your RPMsg communication up and running!
Toradex AI Assistant
I was able to successfully run the rpmsg_lite_str_echo_rtos example on the Apalis iMX8 and could see data using cat /dev/ttyRPMSG30 &. However, when I modified the transmitted data from the received value to a hardcoded one, I stopped receiving anything on cat /dev/ttyRPMSG30 &. Interestingly, I can still see the received message in dmesg.
My ultimate goal is to run a CAN program on Cortex-M4 and transfer the CAN data to Cortex-A via RPMsg, so that a Qt application running on Linux can access this data.
How should I proceed to resolve this issue?
For working on CAN on the cortexM4 processor of apalis imx8:
1.Device Tree:
Do I need to modify the Linux device tree to use CAN from the M4 core, or is it accessible if unused by Linux?
2.Classical CAN:
The SDK only provides FlexCAN examples. Can it be configured for classical CAN (11-bit, no CAN FD)? If so, how?
3.CANL / CANH Pins:
Which physical pins correspond to CANL and CANH for use with M4? Which FlexCAN instance maps to which pins?
