I am using a Riverdi 800x400 LVDS Panel (RVT50HQLNWC00-B), connected over a Toradex DSI to LVDS Adapter to a Dahlia Carrier Board, which has a Verdin iMX8M Plus SoM.
The backlight of the panel turns on, but it seems to happen regardless of whether or not I enable the device tree overlay. Apart from this, I am unable to render anything on the display. Details on what I have tried are further below.
For a brief software outline, here is the tdx-info command:
root@verdin-imx8mp-15415341:~# tdx-info
Software summary
Bootloader: U-Boot
Kernel version: 5.15.148-6.6.0-devel-6.6.0-devel+git.23a8e831749d #1 SMP PREEMPT Thu Feb 29 20:25:21 UTC 2024
Kernel command line: root=PARTUUID=544250fc-02 ro rootwait console=tty1 console=ttymxc2,115200 consoleblank=0 earlycon
Distro name: NAME="TDX Wayland with XWayland"
Distro version: VERSION_ID=6.6.0-devel-20241113144437-build.0
Distro variant: -
Hostname: verdin-imx8mp-15415341
Hardware info
Toradex version: 0070 V1.1A
Serial number: 15415341
Processor arch: aarch64
I am building tdx-reference-multimedia-image with Yocto, creating a custom device tree overlay. It is based on:
verdin-imx8mp_dsi-to-lvds_panel-cap-touch-10inch-lvds_overlay.dts, the only changes being in the panel-lvds node. Below is the relevant section, I can add the entire overlay if needed.
&panel_lvds {
compatible = "panel-lvds";
backlight = <&backlight>;
data-mapping = "vesa-24";
height-mm = <64>;
width-mm = <108>;
panel-timing {
clock-frequency = <25000000>;
de-active = <1>;
hactive = <800>;
hback-porch = <8>;
hfront-porch = <8>;
hsync-active = <0>;
hsync-len = <4>;
pixelclk-active = <1>;
vactive = <480>;
vback-porch = <8>;
vfront-porch = <8>;
vsync-active = <0>;
vsync-len = <4>;
port {
panel_in_lvds: endpoint {
remote-endpoint = <&lvds_out_panel>;
If I add the native HDMI overlay and connect a monitor, the Weston desktop is rendered properly, so this likely rules out an issue with Weston itself. Regardless, here is the weston.ini file:
root@verdin-imx8mp-15415341:~# cat /etc/xdg/weston/weston.ini
[core]
#gbm-format=argb8888
idle-time=0
use-g2d=1
xwayland=true
repaint-window=16
#enable-overlay-view=1
modules=screen-share.so
[output]
name=LVDS-1
mode=800x480@60
transform=normal
#[shell]
#size=1920x1080
[libinput]
enable_tap=true
touchscreen_calibrator=true
calibration_helper=/usr/bin/toradex-save-touchscreen-calibration
#[output]
#name=HDMI-A-1
#mode=1920x1080@60
#transform=rotate-90
#[output]
#name=HDMI-A-2
#mode=off
# WIDTHxHEIGHT Resolution size width and height in pixels
# off Disables the output
# preferred Uses the preferred mode
# current Uses the current crt controller mode
[screen-share]
command=/usr/bin/weston --backend=rdp-backend.so --shell=fullscreen-shell.so --no-clients-resize --rdp-tls-cert=/etc/freerdp/keys/server.crt --rdp-tls-key=/etc/freerdp/keys/server.key
When building, I have enabled some config options for linux-toradex that seemed important, like the following:
CONFIG_DRM_PANEL_LVDS=y
CONFIG_DRM_FSL_IMX_LVDS_BRIDGE=y
CONFIG_DRM_LVDS_CODEC=y
I cannot attach files due being a new user, but if needed I can provide the entire kernel .config.
Below is the output of several commands, which may clarify the context further, like modetest, kmscube and some relevant kernel logs.
root@verdin-imx8mp-15415341:~# modetest
trying to open device 'i915'...failed
trying to open device 'amdgpu'...failed
trying to open device 'radeon'...failed
trying to open device 'nouveau'...failed
trying to open device 'vmwgfx'...failed
trying to open device 'omapdrm'...failed
trying to open device 'exynos'...failed
trying to open device 'tilcdc'...failed
trying to open device 'msm'...failed
trying to open device 'sti'...failed
trying to open device 'tegra'...failed
trying to open device 'imx-drm'...done
Encoders:
id crtc type possible crtcs possible clones
34 33 DSI 0x00000001 0x00000001
Connectors:
id encoder status name size (mm) modes encoders
35 34 connected LVDS-1 108x64 1 34
modes:
index name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot
#0 800x480 60.98 800 808 812 820 480 488 492 500 25000 flags: nhsync, nvsync; type: preferred, driver
props:
1 EDID:
flags: immutable blob
blobs:
value:
2 DPMS:
flags: enum
enums: On=0 Standby=1 Suspend=2 Off=3
value: 0
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
6 non-desktop:
flags: immutable range
values: 0 1
value: 0
4 TILE:
blobs:
value:
CRTCs:
id fb pos size
33 38 (0,0) (800x480)
props:
24 VRR_ENABLED:
flags: range
values: 0 1
value: 0
Planes:
id crtc fb CRTC x,y x,y gamma size possible crtcs
31 33 38 0,0 0,0 0 0x00000001
formats: XR24 AR24 RG16 XB24 AB24 AR15 XR15
props:
8 type:
flags: immutable enum
enums: Overlay=0 Primary=1 Cursor=2
value: 1
32 zpos:
values: 0 0
value: 0
Frame buffers:
id size pitch
root@verdin-imx8mp-15415341:~# journalctl -u weston
Apr 28 18:52:14 verdin-imx8mp-15415341 systemd[1]: Starting Weston, a Wayland compositor, as a system service...
Apr 28 18:52:15 verdin-imx8mp-15415341 systemd[1]: Started Weston, a Wayland compositor, as a system service.
I do see some warnings regarding the regulators (see below) but I do not know how to address them and whether or not these are relevant. It is also a bit unexpected since the device tree overlay is heavily based on an “official” one.
root@verdin-imx8mp-15415341:~# dmesg | grep -i -e drm -e dsi -e sn65 -e regulator -e gpio
[ 0.320742] platform 32e80000.lcd-controller: Fixing up cyclic dependency with 32e60000.mipi_dsi
[ 1.324428] gpio-125 (CTRL_SLEEP_MOCI#): hogged as output/high
[ 1.335211] reg-fixed-voltage regulator-dsi-lvds: nonexclusive access to GPIO for regulator-dsi-lvds
[ 1.411117] at24 0-0050: supply vcc not found, using dummy regulator
[ 1.454575] i2c 3-002c: Fixing up cyclic dependency with 32e60000.mipi_dsi
[ 1.480376] at24 3-0050: supply vcc not found, using dummy regulator
[ 1.495414] at24 3-0057: supply vcc not found, using dummy regulator
[ 1.515883] imx8mq-usb-phy 381f0040.usb-phy: supply vbus not found, using dummy regulator
[ 1.657632] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[ 1.970084] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 2.861728] +V3.3_SW: Underflow of regulator enable count
[ 4.464338] systemd[1]: Starting Load Kernel Module drm...
[ 4.721490] [drm] Initialized vivante 1.0.0 20170808 for 40000000.mix_gpu_ml on minor 0
[ 5.846751] atmel_mxt_ts 3-004a: supply vdda not found, using dummy regulator
[ 5.877951] atmel_mxt_ts 3-004a: supply vdd not found, using dummy regulator
[ 5.904123] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.991509] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 5.999765] imx_sec_dsim_drv 32e60000.mipi_dsi: version number is 0x1060200
[ 6.011360] imx-drm display-subsystem: bound 32e60000.mipi_dsi (ops imx_sec_dsim_ops [sec_mipi_dsim_imx])
[ 6.036884] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 1
[ 6.292986] imx-drm display-subsystem: [drm] fb0: imx-drmdrmfb frame buffer device
If I stop the weston service and run kmscube, it swears it is rendering, but the display shows nothing.
root@verdin-imx8mp-15415341:~# systemctl stop weston
[ 288.424495] audit: type=1701 audit(1651172464.836:22): auid=0 uid=0 gid=0 ses=2 pid=760 comm="weston" exe="/usr/bin/weston" sig=11 res=1
Warning: Stopping weston.service, but it can still be activated by:
weston.socket
root@verdin-imx8mp-15415341:~# kmscube
Using display 0xaaaae489d9d0 with EGL version 1.5
EGL information:
version: "1.5"
vendor: "Vivante Corporation"
client extensions: "EGL_EXT_client_extensions EGL_EXT_platform_base EGL_KHR_platform_wayland EGL_EXT_platform_wayland EGL_EXT_device_query EGL_EXT_device_drm EGL_EXT_device_drm_render_node EGL_KHR_platform_gbm"
display extensions: "EGL_KHR_fence_sync EGL_KHR_reusable_sync EGL_KHR_wait_sync EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_KHR_lock_surface EGL_KHR_create_context EGL_KHR_no_config_context EGL_KHR_surfaceless_context EGL_KHR_get_all_proc_addresses EGL_EXT_create_context_robustness EGL_EXT_protected_surface EGL_EXT_protected_content EGL_EXT_buffer_age EGL_ANDROID_native_fence_sync EGL_WL_bind_wayland_display EGL_WL_create_wayland_buffer_from_image EGL_KHR_partial_update EGL_EXT_swap_buffers_with_damage EGL_KHR_swap_buffers_with_damage EGL_EXT_pixel_format_float"
OpenGL ES 2.x information:
version: "OpenGL ES 3.1 V6.4.3.p4.398061"
shading language version: "OpenGL ES GLSL ES 3.10"
renderer: "Vivante GC7000UL"
extensions: "GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_half_float GL_OES_element_index_uint GL_OES_mapbuffer GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_rgb8_rgba8 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_depth24 GL_OES_depth32 GL_OES_packed_depth_stencil GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_fragment_precision_high GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_texture_stencil8 GL_OES_shader_image_atomic GL_OES_texture_storage_multisample_2d_array GL_OES_required_internalformat GL_OES_surfaceless_context GL_OES_draw_buffers_indexed GL_OES_texture_border_clamp GL_OES_texture_buffer GL_OES_texture_cube_map_array GL_OES_draw_elements_base_vertex GL_OES_texture_half_float GL_OES_texture_float GL_KHR_blend_equation_advanced GL_KHR_debug GL_KHR_robustness GL_KHR_robust_buffer_access_behavior GL_EXT_texture_type_2_10_10_10_REV GL_EXT_texture_compression_dxt1 GL_EXT_texture_format_BGRA8888 GL_EXT_texture_compression_s3tc GL_EXT_read_format_bgra GL_EXT_multi_draw_arrays GL_EXT_frag_depth GL_EXT_discard_framebuffer GL_EXT_blend_minmax GL_EXT_multisampled_render_to_texture GL_EXT_color_buffer_half_float GL_EXT_color_buffer_float GL_EXT_robustness GL_EXT_texture_sRGB_decode GL_EXT_draw_buffers_indexed GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_cube_map_array GL_EXT_multi_draw_indirect GL_EXT_draw_elements_base_vertex GL_EXT_texture_rg GL_EXT_protected_textures GL_EXT_sRGB GL_EXT_draw_buffers GL_EXT_unpack_subimage GL_VIV_direct_texture "
Rendered 121 frames in 2.004442 sec (60.365920 fps)
Rendered 242 frames in 4.008883 sec (60.365950 fps)
Rendered 363 frames in 6.013327 sec (60.365912 fps)
Rendered 484 frames in 8.017770 sec (60.365909 fps)
Rendered 605 frames in 10.022217 sec (60.365888 fps)
Rendered 726 frames in 12.026658 sec (60.365895 fps)
Rendered 847 frames in 14.031104 sec (60.365883 fps)
Rendered 968 frames in 16.035548 sec (60.365881 fps)
However, if I cancel kmscube I get the following and the backlight turns off:
[ 592.507357] sn65dsi83 3-002c: failed to lock PLL, ret=-110
If any further information is required, I can provide it. Thank you in advance.
