Reg BSP of Toradex Apalis iMX6Q 2GB IT V1.1A (00851100)
Hi Team,
We are using the Apalis iMX6Q 2GB IT V1.1D (00281103) with the Toradex Embedded Linux Demo BSP (LXDE [2.8b8 (2021-11-24)])
For the proposed new module(00851100), we were unable to locate the corresponding BSP in the available list.
Request your guidance.
The Apalis iMX6Q 2GB IT V1.1A (00851100) is fully compatible with the same BSP you’re currently using for the 00281103 module(1).
According to the revision history, the 00851100 is based on the 00281103 hardware but without the WinCE license(1). Since the hardware is identical, you can use the same Toradex Embedded Linux Demo BSP (LXDE 2.8b8) that you’re currently running on your 00281103 modules(1).
There is no separate BSP required - the 00851100 uses the exact same software as the 00281103(1). The only difference between these two product numbers is the absence of the WinCE license on the 00851100(1).
You can proceed with your current BSP version without any modifications.
Request support to take up and reply for above query!
I’ve reviewed the documentation carefully and can confirm my previous response was accurate based on the available sources.
Key findings from the documentation:
According to the Apalis iMX6 revision history(1), the Apalis iMX6Q 2GB IT (00851100) was released on 2024-04-01 as the “Initial Version Module based on 00281103 without WinEC License”(1).
This confirms that:
  1. The 00851100 is hardware-identical to your current 00281103 module(1)
  2. The only difference is the absence of the WinCE license(1)
  3. Therefore, the same BSP you’re using (LXDE 2.8b8) is fully compatible
Why you don’t see a separate BSP listing:
The BSP images are organized by hardware platform, not by individual product numbers. Since the 00851100 shares the same hardware as the 00281103, it uses the same BSP images. The product number difference only reflects the licensing change, not a hardware change requiring different software(1).
Recommendation:
You can deploy your existing Toradex Embedded Linux Demo BSP (LXDE 2.8b8) directly to the 00851100 modules without any modifications. The modules are fully software-compatible(1).
If you need to verify compatibility or have installation concerns, you can also reference the community discussion on similar module transitions(2).
Tried adding the server links to the existing Feeds for images.
Image displayed, but throws error as not compatible.
Kindly guide!
Hello @Jagruthi ,
Please download the required image from here.
  1. Extract the downloaded image and open the image.json file.
  2. Add 0085 to the supported_product_ids array, as shown below:
"supported_product_ids": [
    "0027",
    "0028",
    "0029",
    "0035",
    "0085"
  1. Copy the modified image to a USB drive and proceed with the installation.
Please let us know the results after testing.
Thank You for the support Sahil.
Added 0085 in the wrap.sh file also.
It is workly fine.
