I have followed the instructions here:
https://www.toradex.com/community/questions/16791/touch-for-capacitive-touch-display-7inch-parallel.html
The touch interface is connected via the adapter:
And the pinmapping is:
Adapter | Iris
X1 | X16
Pin 1 <-> Pin 5 (SDA)
Pin 2 <-> Pin 6 (SCL)
Pin 3 <-> Pin 7 (GND)
Pin 4 <-> Pin 38 (INT)
Pin 5 <-> Pin 39 (RST)
I have also tried connecting the 3.3V pin on the adapter but it makes no difference.
I apply the following patch:
diff --git a/arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi b/arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi
index 217ddf0..b180514 100644
--- a/arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi
+++ b/arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi
@@ -123,10 +123,11 @@
/* Atmel maxtouch controller */
atmel_mxt_ts: atmel_mxt_ts@4a {
compatible = "atmel,maxtouch";
+ pinctrl-0 = <&pinctrl_gpiotouch>;
reg = <0x4a>;
- interrupt-parent = <&gpio2>;
- interrupts = <15 IRQ_TYPE_EDGE_FALLING>;
- status = "disabled";
+ interrupt-parent = <&gpio1>;
+ interrupts = <9 IRQ_TYPE_EDGE_FALLING>;
+ status = "okay";
touch: touchrevf0710a@10 {
@@ -272,11 +273,11 @@
&pwm2 {
- status = "okay";
+ status = "disabled";
&pwm3 {
- status = "okay";
&pwm4 {
@@ -334,7 +335,7 @@
pinctrl_gpiotouch: touchgpios {
fsl,pins = <
MX7D_PAD_GPIO1_IO09__GPIO1_IO9 0x74
- MX7D_PAD_GPIO1_IO10__GPIO1_IO10 0x14
+ MX7D_PAD_GPIO1_IO10__GPIO1_IO10 0x74
Now, the problem. The touch controller is identified and it will (most of the times) register the first touch or two, but then it just stops. I have rebuilt the driver with debug on and started the kernel with the debug argument, and the following is the output:
root@colibri-imx7-emmc:~# modprobe -s atmel_mxt_ts
[ 44.888903] atmel_mxt_ts 3-004a: T37 Start:256 Size:130 Instances:1 Report IDs:0-0
[ 44.896533] atmel_mxt_ts 3-004a: T44 Start:386 Size:1 Instances:1 Report IDs:0-0
[ 44.903964] atmel_mxt_ts 3-004a: T5 Start:387 Size:11 Instances:1 Report IDs:0-0
[ 44.911422] atmel_mxt_ts 3-004a: T6 Start:398 Size:7 Instances:1 Report IDs:1-1
[ 44.918743] atmel_mxt_ts 3-004a: T68 Start:405 Size:73 Instances:1 Report IDs:2-2
[ 44.926255] atmel_mxt_ts 3-004a: T38 Start:478 Size:64 Instances:1 Report IDs:0-0
[ 44.933774] atmel_mxt_ts 3-004a: T71 Start:542 Size:200 Instances:1 Report IDs:0-0
[ 44.941373] atmel_mxt_ts 3-004a: T110 Start:742 Size:52 Instances:6 Report IDs:0-0
[ 44.948951] atmel_mxt_ts 3-004a: T7 Start:1054 Size:5 Instances:1 Report IDs:0-0
[ 44.956380] atmel_mxt_ts 3-004a: T8 Start:1059 Size:15 Instances:1 Report IDs:0-0
[ 44.963899] atmel_mxt_ts 3-004a: T15 Start:1074 Size:11 Instances:1 Report IDs:3-3
[ 44.971503] atmel_mxt_ts 3-004a: T18 Start:1085 Size:2 Instances:1 Report IDs:0-0
[ 44.979002] atmel_mxt_ts 3-004a: T19 Start:1087 Size:6 Instances:1 Report IDs:4-4
[ 44.986516] atmel_mxt_ts 3-004a: T25 Start:1093 Size:39 Instances:1 Report IDs:5-5
[ 44.994123] atmel_mxt_ts 3-004a: T40 Start:1132 Size:5 Instances:1 Report IDs:0-0
[ 45.001646] atmel_mxt_ts 3-004a: T42 Start:1137 Size:13 Instances:1 Report IDs:0-0
[ 45.009232] atmel_mxt_ts 3-004a: T43 Start:1150 Size:15 Instances:1 Report IDs:6-6
[ 45.016850] atmel_mxt_ts 3-004a: T46 Start:1165 Size:12 Instances:1 Report IDs:7-7
[ 45.024451] atmel_mxt_ts 3-004a: T47 Start:1177 Size:28 Instances:1 Report IDs:0-0
[ 45.032055] atmel_mxt_ts 3-004a: T56 Start:1205 Size:45 Instances:1 Report IDs:8-8
[ 45.039642] atmel_mxt_ts 3-004a: T61 Start:1250 Size:5 Instances:6 Report IDs:9-14
[ 45.047243] atmel_mxt_ts 3-004a: T65 Start:1280 Size:23 Instances:3 Report IDs:15-17
[ 45.055021] atmel_mxt_ts 3-004a: T70 Start:1349 Size:10 Instances:20 Report IDs:18-37
[ 45.062880] atmel_mxt_ts 3-004a: T72 Start:1549 Size:85 Instances:1 Report IDs:38-38
[ 45.070631] atmel_mxt_ts 3-004a: T77 Start:1634 Size:2 Instances:1 Report IDs:0-0
[ 45.078154] atmel_mxt_ts 3-004a: T78 Start:1636 Size:12 Instances:1 Report IDs:0-0
[ 45.085755] atmel_mxt_ts 3-004a: T79 Start:1648 Size:4 Instances:3 Report IDs:0-0
[ 45.093273] atmel_mxt_ts 3-004a: T80 Start:1660 Size:11 Instances:1 Report IDs:39-39
[ 45.101053] atmel_mxt_ts 3-004a: T92 Start:1671 Size:130 Instances:1 Report IDs:40-40
[ 45.108891] atmel_mxt_ts 3-004a: T93 Start:1801 Size:28 Instances:1 Report IDs:41-41
[ 45.116667] atmel_mxt_ts 3-004a: T95 Start:1829 Size:5 Instances:1 Report IDs:0-0
[ 45.124186] atmel_mxt_ts 3-004a: T96 Start:1834 Size:8 Instances:1 Report IDs:0-0
[ 45.131702] atmel_mxt_ts 3-004a: T97 Start:1842 Size:10 Instances:4 Report IDs:42-45
[ 45.139460] atmel_mxt_ts 3-004a: T98 Start:1882 Size:5 Instances:1 Report IDs:0-0
[ 45.146979] atmel_mxt_ts 3-004a: T100 Start:1887 Size:54 Instances:1 Report IDs:46-63
[ 45.154851] atmel_mxt_ts 3-004a: T104 Start:1941 Size:11 Instances:1 Report IDs:0-0
[ 45.162536] atmel_mxt_ts 3-004a: T108 Start:1952 Size:75 Instances:1 Report IDs:64-64
[ 45.170374] atmel_mxt_ts 3-004a: T109 Start:2027 Size:9 Instances:1 Report IDs:65-65
[ 45.178155] atmel_mxt_ts 3-004a: T111 Start:2036 Size:18 Instances:2 Report IDs:0-0
[ 45.185844] atmel_mxt_ts 3-004a: T112 Start:2072 Size:5 Instances:1 Report IDs:66-66
[ 45.193637] atmel_mxt_ts 3-004a: T113 Start:2077 Size:3 Instances:1 Report IDs:0-0
[ 45.311480] atmel_mxt_ts 3-004a: T6 Config Checksum: 0x654801
[ 45.317255] atmel_mxt_ts 3-004a: T6 Status 0x80 RESET
[ 45.332713] atmel_mxt_ts 3-004a: message: 26 38 02 00 02 01 16 00 00 00
[ 45.349674] atmel_mxt_ts 3-004a: message: 40 18 02 00 04 00 01 00 00 00
[ 45.366634] atmel_mxt_ts 3-004a: message: 41 05 00 00 00 00 00 00 00 00
[ 45.383539] atmel_mxt_ts 3-004a: T6 Status 0x10 CAL
[ 45.420326] atmel_mxt_ts 3-004a: T6 Status 0x00 OK
[ 45.505874] atmel_mxt_ts 3-004a: message: 40 10 02 00 03 00 00 00 00 00
[ 45.566151] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 01 16 00 00 00
[ 45.756526] atmel_mxt_ts 3-004a: message: 40 10 02 00 03 00 00 00 00 00
[ 45.768723] atmel_mxt_ts 3-004a: __mxt_read_reg: i2c transfer failed (-5)
[ 45.775563] atmel_mxt_ts 3-004a: Failed to read T44 and T5 (-5)
[ 45.802931] atmel_mxt_ts 3-004a: message: 40 10 02 00 02 00 00 00 00 00
[ 45.810312] atmel_mxt_ts 3-004a: Direct firmware load for maxtouch.cfg failed with error -2
[ 45.818737] atmel_mxt_ts 3-004a: Falling back to user helper
[ 45.836749] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 01 16 00 00 00
[ 45.853784] atmel_mxt_ts 3-004a: message: 40 10 02 00 03 00 01 00 00 00
[ 45.868048] atmel_mxt_ts 3-004a: T100 aux mappings vect:0 ampl:0 area:0
[ 45.874765] atmel_mxt_ts 3-004a: T100 Touchscreen size X799Y479
[ 45.881058] input: Atmel maXTouch Touchscreen as /devices/platform/soc/30800000.aips-bus/30a50000.i2c/i2c-3/3-004a/input/input2
[ 45.894299] atmel_mxt_ts 3-004a: Family: 164 Variant: 11 Firmware V1.2.AA Objects: 41
[ 45.925860] atmel_mxt_ts 3-004a: message: 40 10 02 00 02 00 01 00 00 00
[ 45.955268] atmel_mxt_ts 3-004a: T6 Status 0x08 CFGERR
[ 46.005358] atmel_mxt_ts 3-004a: T6 Status 0x10 CAL
[ 46.031096] atmel_mxt_ts 3-004a: T6 Status 0x00 OK
[ 46.077080] atmel_mxt_ts 3-004a: message: 40 10 02 00 03 00 03 00 00 00
[ 46.104818] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 02 16 00 00 00
[ 46.138057] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 02 00 00 00
[ 46.261029] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 01 00 00
[ 46.322792] atmel_mxt_ts 3-004a: message: 40 10 02 00 07 00 02 01 00 00
[ 46.363830] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 02 16 00 00 00
[ 46.391835] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 02 01 00 00
[ 46.445941] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 01 00 00 00
[ 46.506573] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 46.568495] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 46.629330] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 02 00 00 00
[ 46.691290] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 46.813828] atmel_mxt_ts 3-004a: message: 40 10 02 00 07 00 01 00 00 00
[ 46.874322] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 46.902233] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 02 16 00 00 00
[ 46.998276] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 47.060306] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 47.121391] atmel_mxt_ts 3-004a: message: 40 10 02 00 07 00 02 01 00 00
[ 47.150791] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 01 16 00 00 00
[ 47.183944] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 47.245505] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 01 00 00 00
[ 47.308019] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 00 00 00 00
[ 47.414466] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 02 16 00 00 00
[ 47.441950] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 00 00 00 00
[ 47.492990] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 47.555149] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 01 00 00 00
[ 47.616574] atmel_mxt_ts 3-004a: message: 40 10 02 00 07 00 02 00 00 00
[ 47.679125] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 02 16 00 00 00
[ 47.698052] atmel_mxt_ts 3-004a: message: 40 10 02 00 07 00 03 01 00 00
[ 47.740501] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 01 00 00 00
[ 47.802408] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 01 00 00 00
[ 47.864055] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 01 00 00 00
[ 47.926542] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 01 00 00 00
[ 47.987964] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 48.173949] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 02 00 00 00
[ 48.206425] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 02 16 00 00 00
[ 48.297625] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 02 00 00 00
[ 48.358945] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 48.421199] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 02 00 00 00
[ 48.470859] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 02 16 00 00 00
[ 48.498893] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 01 00 00 00
[ 48.545066] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 48.606231] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 48.668929] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 48.730290] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 48.749221] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 02 16 00 00 00
[ 48.853560] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 02 00 00 00
[ 48.916501] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 00 00 00 00
[ 49.039752] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 49.101105] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 00 00 00 00
[ 49.163626] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 02 00 00 00
[ 49.224972] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 00 00 00 00
[ 49.262495] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 02 16 00 00 00
[ 49.411180] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 49.526026] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 02 16 00 00 00
[ 49.553943] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 02 01 00 00
[ 49.596087] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 02 00 00 00
[ 49.658575] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 02 00 00 00
[ 49.719889] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 00 00 00 00
[ 49.789116] atmel_mxt_ts 3-004a: message: 27 80 00 00 00 00 00 00 00 00
[ 49.816894] atmel_mxt_ts 3-004a: message: 26 12 02 00 02 02 16 00 00 00
[ 49.838629] atmel_mxt_ts 3-004a: message: 27 81 00 00 00 00 00 00 00 00
[ 49.889708] atmel_mxt_ts 3-004a: [0] type:1 x:613 y:226 a:00 p:01 v:00
[ 49.917779] atmel_mxt_ts 3-004a: message: 40 12 02 00 05 00 00 00 00 00
[ 49.938546] atmel_mxt_ts 3-004a: message: 27 00 00 00 00 00 00 00 00 00
[ 49.989408] atmel_mxt_ts 3-004a: [0] release
[ 50.014601] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 01 00 00 00
[ 50.042225] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 00 00 00 00
[ 50.102958] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 50.131051] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 02 16 00 00 00
[ 50.165416] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 02 00 00 00
[ 50.351445] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 02 00 00 00
[ 50.379105] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 01 16 00 00 00
[ 50.476136] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 50.537652] atmel_mxt_ts 3-004a: message: 40 10 02 00 07 00 01 00 00 00
[ 50.599801] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 50.638229] atmel_mxt_ts 3-004a: message: 26 10 02 00 02 02 16 00 00 00
[ 50.665841] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 50.788687] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 01 00 00 00
[ 50.859001] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 50.928254] atmel_mxt_ts 3-004a: message: 26 12 02 00 02 02 16 00 00 00
[ 50.955875] atmel_mxt_ts 3-004a: message: 40 10 02 00 07 00 01 00 00 00
[ 51.001809] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 01 00 00 00
[ 51.069977] atmel_mxt_ts 3-004a: message: 40 10 02 00 06 00 00 00 00 00
[ 51.132432] atmel_mxt_ts 3-004a: message: 40 10 02 00 05 00 01 00 00 00
[ 51.160503] atmel_mxt_ts 3-004a: message: 27 80 00 00 00 00 00 00 00 00
[ 51.216316] atmel_mxt_ts 3-004a: [0] type:1 x:561 y:238 a:00 p:01 v:00
[ 51.233181] atmel_mxt_ts 3-004a: message: 27 81 00 00 00 00 00 00 00 00
Things I have tried:
- Lowering the i2c frequency from 100kHz to 10kHz => only made it worse
- Increasing the pull-up on the INT & RST pins to 47k (from 100k) => No change in behaviour
- Adding debug traces to the driver (atmel_mxt_ts.c), but I can only see that it stops getting interrupts suddenly
Can you give me some pointers on how to proceed with debugging this?
Best regards
Pedro
