Problems running an Electron app with Reacjs
My project uses a Verdin Development Board iMX8 Mini with HDMI board as a host.
My goal is to have a React application running in Electron, so I’ve started from the Electron example project at Toradex IDE Extension in Visual Code.
I could be able to build and run and the demo application - the screen appeared and worked fine at the monitor.
From that base project I started changes to use Reacjs. Some files changed and others added.
Here is the result:
Dockerfile - As original from demo project - no changes
# ARGUMENTS --------------------------------------------------------------------
# Board architecture
ARG IMAGE_ARCH=
# Base container version
ARG BASE_VERSION=3.3.1
# Directory of the application inside container
ARG APP_ROOT=
# Board GPU vendor prefix
ARG GPU=
# BUILD ------------------------------------------------------------------------
FROM --platform=linux/${IMAGE_ARCH} \
    commontorizon/wayland-base${GPU}:${BASE_VERSION} AS build
ARG IMAGE_ARCH
ARG GPU
ARG APP_ROOT
# stick to bookworm on /etc/apt/sources.list.d
RUN sed -i 's/sid/bookworm/g' /etc/apt/sources.list.d/debian.sources
# for vivante GPU we need some "special" sauce
RUN apt-get -q -y update && \
        if [ "${GPU}" = "-vivante" ] || [ "${GPU}" = "-imx8" ]; then \
            apt-get -q -y install \
            imx-gpu-viv-wayland-dev \
        ; else \
            libgl1 \
        ; fi \
    apt-get clean && apt-get autoremove && \
    rm -rf /var/lib/apt/lists/*
# Install required packages
    gcc \
    g++ \
    make \
    git \
    libatspi2.0-0 \
    libgconf-2-4 \
    libglib2.0-bin \
    libgtk2.0-0 \
    libgtk-3-0 \
    libnotify4 \
    libnss3 \
    libuuid1 \
    libxcb-dri3-0 \
    xdg-utils \
    libxss1 \
    libxtst6 \
    libasound2 \
    curl \
# DO NOT REMOVE THIS LABEL: this is used for VS Code automation
    # __torizon_packages_build_start__
    # __torizon_packages_build_end__
# install the latest node js
RUN curl -fsSL https://deb.nodesource.com/setup_20.x | bash - && \
    apt-get install -y nodejs
RUN npm config set registry https://registry.npmjs.org/
COPY . ${APP_ROOT}
WORKDIR ${APP_ROOT}
# Remove the code from the debug builds, inside this container, to build the
# release version from a clean build
RUN rm -rf ${APP_ROOT}/out
RUN npm install
# build the application
RUN  if [ "${IMAGE_ARCH}" = "arm64" ]; then \
        npx electron-forge package -a arm64 -p linux; \
    elif [ "${IMAGE_ARCH}" = "arm" ]; then \
        npx electron-forge package -a armv7l -p linux; \
    else \
        npx electron-forge package -a x86 -p linux; \
    fi;
# Copy the EGL lib inside the project's directory for vivante GPU
RUN  if [ "${GPU}" = "-vivante" ] || [ "${GPU}" = "-imx8" ]; then \
        cp /usr/lib/aarch64-linux-gnu/libEGL.so ${APP_ROOT}/out/testui-linux-${IMAGE_ARCH} && \
        cp /usr/lib/aarch64-linux-gnu/libGLESv2.so ${APP_ROOT}/out/testui-linux-${IMAGE_ARCH}; \
    # If it is a armv7l, this renames the output directory with the name expected by the Deploy fase
        mv ${APP_ROOT}/out/testui-linux-armv7l ${APP_ROOT}/out/testui-linux-${IMAGE_ARCH}; \
    fi;
# DEPLOY -----------------------------------------------------------------------
    commontorizon/wayland-base${GPU}:${BASE_VERSION} AS deploy
ARG IMAGE_ARCH
ARG GPU
ARG APP_ROOT
        ; else \
            libgl1 \
        ; fi \
# your regular RUN statements here
    libatspi2.0-0 \
    libgconf-2-4 \
    libglib2.0-bin \
    libgtk2.0-0 \
    libgtk-3-0 \
    libnotify4 \
    libnss3 \
    libuuid1 \
    libxcb-dri3-0 \
    xdg-utils \
    libxss1 \
    libxtst6 \
    libasound2 \
    curl \
    # __torizon_packages_prod_start__
    # __torizon_packages_prod_end__
# Copy the application compiled in the build step to the $APP_ROOT directory
# path inside the container, where $APP_ROOT is the torizon_app_root
# configuration defined in settings.json
COPY --from=build ${APP_ROOT}/out/testui-linux-${IMAGE_ARCH} ${APP_ROOT}
# "cd" (enter) into the APP_ROOT directory
WORKDIR ${APP_ROOT}
# Command executed in runtime when the container starts
# FIX: In this template arm32 is not working properly with egl, so if you are
# using an arm32 remove the "--use-gl=egl" and "--in-process-gpu" arguments.
CMD [ "./testui", "--no-sandbox", "--ozone-platform=wayland", "--use-gl=egl", "--in-process-gpu" ]
Dockerfile.debug - As original from demo project - no changes
ARG IMAGE_ARCH=
ARG APP_ROOT=
# Debug port
ARG DEBUG_SSH_PORT=
# Run as
ARG SSHUSERNAME=
ARG GPU=
    commontorizon/wayland-base${GPU}:${BASE_VERSION} AS debug
ARG IMAGE_ARCH
ARG GPU
ARG DEBUG_SSH_PORT
ARG APP_ROOT
ARG SSHUSERNAME
# SSH for remote debug
EXPOSE ${DEBUG_SSH_PORT}
EXPOSE 9229
# Make sure we don't get notifications we can't answer during building.
ENV DEBIAN_FRONTEND="noninteractive"
        ; else \
            libgl1 \
        ; fi \
    gcc \
    g++ \
    make \
    git \
    openssl \
    openssh-server \
    rsync \
    file \
    curl \
    libatspi2.0-0 \
    libgconf-2-4 \
    libglib2.0-bin \
    libgtk2.0-0 \
    libgtk-3-0 \
    libnotify4 \
    libnss3 \
    libuuid1 \
    libxcb-dri3-0 \
    xdg-utils \
    libxss1 \
    libxtst6 \
    libasound2 && \
# automate for torizonPackages.json
    # __torizon_packages_dev_start__
    # __torizon_packages_dev_end__
# ⚠️ DEBUG PURPOSES ONLY!!
# THIS CONFIGURES AN INSECURE SSH CONNECTION
# create folders needed for the different components
# configures SSH access to the container and sets environment by default
RUN mkdir /var/run/sshd && \
    sed 's@session\s*required\s*pam_loginuid.so@session optional pam_loginuid.so@g' \
        -i /etc/pam.d/sshd && \
    if test $SSHUSERNAME != root ; \
        then mkdir -p /home/$SSHUSERNAME/.ssh ; \
        else mkdir -p /root/.ssh ; fi && \
    echo "PermitUserEnvironment yes" >> /etc/ssh/sshd_config && \
    echo "PermitRootLogin yes" >> /etc/ssh/sshd_config && \
    echo "Port ${DEBUG_SSH_PORT}" >> /etc/ssh/sshd_config && \
    echo "PasswordAuthentication yes" >> /etc/ssh/sshd_config && \
    echo "PermitEmptyPasswords yes" >> /etc/ssh/sshd_config && \
    su -c "env" $SSHUSERNAME > /etc/environment && \
    echo "$SSHUSERNAME:" | chpasswd -e
RUN rm -r /etc/ssh/ssh*key && \
    dpkg-reconfigure openssh-server
COPY --chown=$SSHUSERNAME:$SSHUSERNAME ./out/testui-linux-${IMAGE_ARCH} ${APP_ROOT}
        cp /usr/lib/aarch64-linux-gnu/libEGL.so ${APP_ROOT} && \
        cp /usr/lib/aarch64-linux-gnu/libGLESv2.so ${APP_ROOT}; \
    fi
CMD [ "/usr/sbin/sshd", "-D" ]
forge.config.js
const { FusesPlugin } = require('@electron-forge/plugin-fuses');
const { FuseV1Options, FuseVersion } = require('@electron/fuses');
module.exports = {
  packagerConfig: {
    asar: true,
  rebuildConfig: {},
  makers: [
      "config": {
        "name": "electron_quick_start"
      platforms: ['darwin'],
      config: {},
      config: {},
  plugins: [
      config: {},
      config: {
        mainConfig: './webpack.main.config.js',
        renderer: {
          config: './webpack.renderer.config.js',
          entryPoints: [
              html: './src/index.html',
              js: './src/renderer.js',
              preload: {
                js: './src/preload.js',
    // Fuses are used to enable/disable various Electron functionality
    // at package time, before code signing the application
    new FusesPlugin({
      version: FuseVersion.V1,
      [FuseV1Options.RunAsNode]: false,
      [FuseV1Options.EnableCookieEncryption]: true,
      [FuseV1Options.EnableNodeOptionsEnvironmentVariable]: false,
      [FuseV1Options.EnableNodeCliInspectArguments]: false,
      [FuseV1Options.EnableEmbeddedAsarIntegrityValidation]: true,
      [FuseV1Options.OnlyLoadAppFromAsar]: true,
package.json
  "name": "testui",
  "version": "1.0.0",
  "description": "User Interface Test",
  "main": ".webpack/main",
  "scripts": {
    "start": "electron-forge start",
    "package": "electron-forge package",
    "make": "electron-forge make"
  "repository": "",
  "keywords": [
    "Electron",
    "quick",
    "start",
    "tutorial",
    "demo"
  "author": "GitHub",
  "license": "CC0-1.0",
  "devDependencies": {
    "@babel/core": "^7.25.2",
    "@babel/preset-react": "^7.24.7",
    "@electron-forge/cli": "^7.4.0",
    "@electron-forge/maker-deb": "^7.4.0",
    "@electron-forge/maker-rpm": "^7.4.0",
    "@electron-forge/maker-squirrel": "^7.4.0",
    "@electron-forge/maker-zip": "^7.4.0",
    "@electron-forge/plugin-auto-unpack-natives": "^7.4.0",
    "@electron-forge/plugin-fuses": "^7.4.0",
    "@electron-forge/plugin-webpack": "^7.4.0",
    "@electron/fuses": "^1.8.0",
    "@vercel/webpack-asset-relocator-loader": "1.7.3",
    "babel-loader": "^9.1.3",
    "css-loader": "^6.0.0",
    "electron": "^32.0.2",
    "node-loader": "^2.0.0",
    "style-loader": "^3.0.0"
  "dependencies": {
    "@fortawesome/fontawesome-svg-core": "^6.6.0",
    "@fortawesome/free-brands-svg-icons": "^6.6.0",
    "@fortawesome/free-solid-svg-icons": "^6.6.0",
    "@fortawesome/react-fontawesome": "^0.2.2",
    "d3": "^7.9.0",
    "electron-squirrel-startup": "^1.0.1",
    "moment": "^2.30.1",
    "prop-types": "^15.8.1",
    "react": "^18.3.1",
    "react-dom": "^18.3.1",
    "socket.io-client": "^4.7.5"
  "prodRuntimeDeps": [],
  "devRuntimeDeps": [],
  "buildDeps": []
module.exports = {
     * This is the main entry point for your application, it's the first file
     * that runs in the main process.
    entry: './src/main.js',
    // Put your normal webpack config below here
    module: {
      rules: require('./webpack.rules'),
const rules = require('./webpack.rules');
rules.push({
  test: /\.css$/,
  use: [{
    loader: 'style-loader',
    options: {
      esModule: false,
    loader: 'css-loader',
    options: {
      esModule: false,
      modules: {}
module.exports = {
  module: {
    rules,
webpack.rules.js
module.exports = [
    // Add support for native node modules
      // We're specifying native_modules in the test because the asset relocator loader generates a
      // "fake" .node file which is really a cjs file.
      test: /native_modules[/\\].+\.node$/,
      use: 'node-loader',
      test: /[/\\]node_modules[/\\].+\.(m?js|node)$/,
      parser: { amd: false },
      use: {
        loader: '@vercel/webpack-asset-relocator-loader',
        options: {
          outputAssetBase: 'native_modules',
      test: /\.(js|jsx)$/,
      use: {
        loader: 'babel-loader',
        options: {
          exclude: /node_modules/,
          presets: ['@babel/preset-react']
    // Put your webpack loader rules in this array.  This is where you would put
    // your ts-loader configuration for instance:
     * Typescript Example:
     *   test: /\.tsx?$/,
     *   exclude: /(node_modules|.webpack)/,
     *   loaders: [{
     *     loader: 'ts-loader',
     *     options: {
     *       transpileOnly: true
src/app.jsx
import React from 'react';
import ReactDOM from 'react-dom/client';
import Home from "./Home"
const root = ReactDOM.createRoot(document.getElementById("root"));
root.render(
  <React.StrictMode>ocker
    <Home />
  </React.StrictMode>
src/Home.jsx
import styles from "./Home.css";
const Home = () => {
  return (
    <div className={styles.container}>
      <h1>INSIDE REACT</h1>
    </div>
export default Home;
src/Home.css*
.container {
    height: 100%;
    width: 100%;
    margin: 0;
    padding: 0;
    display: flex;
    flex-direction: column;
    font-size: 36px;
src/index.css
    box-sizing: border-box;
    padding: 0;
    margin: 0;
    height: 100%;
    width: 100%;
  html {
    width: 100vw;
    height: 100vh;
  *, *:before, *:after {
    box-sizing: inherit;
  body {
    font-family: 'Arial'; font-size: 22px;
    margin: 0;
    padding: 0;
    font-size: 14px;
    color: white;
    background-color: red;
    margin: 0 auto;
    width: 100%;
    height: 100%;
    overflow-y: hidden;
    overflow-x: hidden;
src/index.html
<!DOCTYPE html>
<html>
  <head>
    <meta charset="UTF-8" />
    <title>UI Tester</title>
  </head>
  <body>
    <h1>UI LOADED!!!!</h1>
    <div id="root"></div>
  </body>
</html>
src/main.js
// Modules to control application life and create native browser window
const {app, BrowserWindow} = require('electron')
const path = require('path')
function createWindow () {
  // Create the browser window.
  const mainWindow = new BrowserWindow({
    width: 640,
    height: 480,
    webPreferences: {
      preload: MAIN_WINDOW_PRELOAD_WEBPACK_ENTRY
  // and load the index.html of the app.
  mainWindow.loadURL(MAIN_WINDOW_WEBPACK_ENTRY);
  // if embedded Linux set fullscreen
  if (process.arch.includes("arm")) {
    mainWindow.setFullScreen(true);
  // Open the DevTools.
  mainWindow.webContents.openDevTools()
// This method will be called when Electron has finished
// initialization and is ready to create browser windows.
// Some APIs can only be used after this event occurs.
app.whenReady().then(() => {
  createWindow()
  app.on('activate', function () {
    // On macOS it's common to re-create a window in the app when the
    // dock icon is clicked and there are no other windows open.
    if (BrowserWindow.getAllWindows().length === 0) createWindow()
// Quit when all windows are closed, except on macOS. There, it's common
// for applications and their menu bar to stay active until the user quits
// explicitly with Cmd + Q.
app.on('window-all-closed', function () {
  if (process.platform !== 'darwin') app.quit()
// In this file you can include the rest of your app's specific main process
// code. You can also put them in separate files and require them here.
src/preload.js
// All of the Node.js APIs are available in the preload process.
// It has the same sandbox as a Chrome extension.
window.addEventListener('DOMContentLoaded', () => {
  const replaceText = (selector, text) => {
    const element = document.getElementById(selector)
    if (element) element.innerText = text
  for (const type of ['chrome', 'node', 'electron']) {
    replaceText(`${type}-version`, process.versions[type])
src/renderer.js
// This file is required by the index.html file and will
// be executed in the renderer process for that window.
// No Node.js APIs are available in this process because
// `nodeIntegration` is turned off. Use `preload.js` to
// selectively enable features needed in the rendering
// process.
import "./app.jsx";
import './index.css';
console.log('👋 This message is being logged by "renderer.js", included via webpack');
So, what is the problem I’m facing:
The build process works fine until the end - final logs:
  [+] Running 2/2
 ✔ Container torizon-weston-1         Started        3.2s
 ✔ Container torizon-testui-debug-1  Started        4.8s
 *  Executing task in folder testui: ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -p 2228 torizon@192.168.0.118 /home/torizon/app/testui --no-sandbox --remote-debugging-port=9222 --inspect-brk=0.0.0.0:9229 --ozone-platform=wayland --use-gl=egl --in-process-gpu >out.log 2>err.log &
Warning: Permanently added '[192.168.0.118]:2228' (ED25519) to the list of known hosts.
From that moment, the blue color at the VS Code bottom status bar does not appear (showing that container is running).
The Torizon Building/Deploying with the circle spinner keeps running forever, and the screen gets a blue color and stucks.
Seens that the process freezes.
ssh`ed to Verdin board and docker logs from container shows nothing.
Entered in the container:
docker run -i -t 192.168.0.115:5002/testui:arm64 bash
Went to /home/torizon/app - the application is there:
  root@de96398bf44a:/home/torizon/app# ls
  LICENSE			 icudtl.dat	       resources
  LICENSES.chromium.html	 libEGL.so	       resources.pak
  chrome-sandbox		 libGLESv2.so	       snapshot_blob.bin
  chrome_100_percent.pak	 libffmpeg.so	       v8_context_snapshot.bin
  chrome_200_percent.pak	 libvk_swiftshader.so  version
  chrome_crashpad_handler  libvulkan.so.1        vk_swiftshader_icd.json
  core.10			 locales
  core.11			 testui
No log and no outputs found.
Need help to find out what’s going on.
Edit: I have checked the electron bundle and it runs fine on my host machine (Ubuntu 22.04):
npx electron-forge start
And the application runs fine.
It looks like you’ve done a thorough job setting up your Dockerfile and project structure for running a React application within Electron on a Verdin iMX8 Mini module. However, the issue you’re facing seems to be related to the application freezing and not providing any logs or outputs.
Here are a few steps and suggestions to help you debug and resolve the issue:
  1. Check Electron Logs:
    Since the application is not providing any logs, you might want to add some logging to your Electron main process to see where it might be getting stuck. Modify your src/main.js to include more detailed logging:
    const { app, BrowserWindow } = require('electron');
    const path = require('path');
    const fs = require('fs');
    function createWindow() {
      console.log('Creating window...');
        width: 640,
        height: 480,
        webPreferences: {
      mainWindow.webContents.openDevTools();
      mainWindow.webContents.on('did-finish-load', () => {
        console.log('Window finished loading');
      mainWindow.on('closed', () => {
        console.log('Window closed');
    app.on('ready', () => {
      console.log('App is ready');
      createWindow();
    app.on('window-all-closed', () => {
      if (process.platform !== 'darwin') {
        app.quit();
    app.on('activate', () => {
      if (BrowserWindow.getAllWindows().length === 0) {
        createWindow();
    process.on('uncaughtException', (error) => {
      console.error('Uncaught Exception:', error);
      fs.writeFileSync('/home/torizon/app/error.log', `Uncaught Exception: ${error.message}\n${error.stack}`);
    This will help you see if the Electron app is starting correctly and where it might be failing.
  2. Check Docker Container Logs:
    Ensure that you are checking the correct logs. You can use the following command to see the logs of the running container:
    docker logs <container_id>
    Replace <container_id> with the actual container ID of your running container.
  3. Verify Dependencies:
    Ensure that all the necessary dependencies for running Electron and React are correctly installed in your Docker container. Sometimes missing dependencies can cause the application to freeze.
  4. Check for GPU Issues:
    Since you are using GPU acceleration, ensure that the GPU drivers and libraries are correctly installed and configured. You might want to try running the application without GPU acceleration to see if that resolves the issue. Modify the CMD in your Dockerfile to remove the GPU-related flags:
    CMD [ "./testui", "--no-sandbox", "--ozone-platform=wayland" ]
  5. Debugging Electron:
    You can also try running Electron in a more verbose mode to get more information. Modify your CMD in the Dockerfile to include the --enable-logging flag:
    CMD [ "./testui", "--no-sandbox", "--ozone-platform=wayland", "--enable-logging" ]
  6. Check Network and SSH Configuration:
    Ensure that the SSH configuration and network settings are correctly set up. Sometimes network issues can cause the application to hang.
  7. Simplify the Application:
    Try simplifying your application to the bare minimum and see if it runs. Gradually add back components to identify what might be causing the issue.
If none of these steps resolve the issue, you might need to provide more specific logs or error messages to further diagnose the problem.
Visual Studio Code IDE Extension | Toradex Developer Center.
Following the AI hints, tried to run directly from my Ubuntu 22.04 host machine:
I did 2 tries:
$ ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -p 2228 torizon@192.168.0.118 /home/torizon/app/testui --no-sandbox --remote-debugging-port=9222 --inspect-brk=0.0.0.0:9229 --ozone-platform=wayland --use-gl=egl --in-process-gpu --enable-logging
[399:0913/203645.343610:WARNING:wayland_object.cc(165)] Binding to zwp_linux_dmabuf_v1 version 3 but version 4 is available.
[399:0913/203645.346493:WARNING:wayland_drm.cc(107)] Drm prime capability is not supported
[399:0913/203645.835491:ERROR:bus.cc(407)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[399:0913/203645.835736:ERROR:bus.cc(407)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[399:0913/203645.844094:ERROR:bus.cc(407)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[399:0913/203645.844378:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[399:0913/203645.845357:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[399:0913/203645.845446:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[399:0913/203645.845498:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[399:0913/203645.845543:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[399:0913/203645.865404:ERROR:gl_factory.cc(113)] Requested GL implementation (gl=egl-gles2,angle=none) not found in allowed implementations: [(gl=egl-angle,angle=opengl),(gl=egl-angle,angle=opengles),(gl=egl-angle,angle=swiftshader)].
[399:0913/203645.938701:ERROR:socket_posix.cc(147)] bind() failed: Address already in use (98)
[399:0913/203645.939514:ERROR:devtools_http_handler.cc(319)] Cannot start http server for devtools.
[399:0913/203645.969982:WARNING:wayland_surface.cc(197)] Server doesn't support zcr_alpha_compositing_v1.
[399:0913/203645.970055:WARNING:wayland_surface.cc(212)] Server doesn't support overlay_prioritizer.
[399:0913/203645.970076:WARNING:wayland_surface.cc(228)] Server doesn't support surface_augmenter.
[399:0913/203645.970095:WARNING:wayland_surface.cc(243)] Server doesn't support wp_content_type_v1
[399:0913/203645.970114:WARNING:wayland_surface.cc(262)] Server doesn't support zcr_color_management_surface.
[399:0913/203646.206651:WARNING:bluez_dbus_manager.cc(234)] Floss manager service not available, cannot set Floss enable/disable.
[399:0913/203646.233067:FATAL:check.cc(376)] Check failed: false. NOTREACHED log messages are omitted in official builds. Sorry!
Trace/breakpoint trap (core dumped)
Repair that the process crashes at the end
Another try, now removing the egl and in-process-gpu:
$ ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -p 2228 torizon@192.168.0.118 /home/torizon/app/testui --no-sandbox --remote-debugging-port=9222 --inspect-brk=0.0.0.0:9229 --ozone-platform=wayland  --enable-logging
[462:0913/203729.745829:ERROR:bus.cc(407)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[462:0913/203730.336400:WARNING:wayland_object.cc(165)] Binding to zwp_linux_dmabuf_v1 version 3 but version 4 is available.
[462:0913/203730.338892:WARNING:wayland_drm.cc(107)] Drm prime capability is not supported
[462:0913/203730.826310:ERROR:bus.cc(407)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[462:0913/203730.826583:ERROR:bus.cc(407)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[462:0913/203730.835143:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[462:0913/203730.835266:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[462:0913/203730.835333:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[462:0913/203730.835384:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[462:0913/203730.835426:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[462:0913/203730.929155:ERROR:socket_posix.cc(147)] bind() failed: Address already in use (98)
[462:0913/203730.929372:ERROR:devtools_http_handler.cc(319)] Cannot start http server for devtools.
[462:0913/203730.960525:WARNING:wayland_surface.cc(197)] Server doesn't support zcr_alpha_compositing_v1.
[462:0913/203730.961221:WARNING:wayland_surface.cc(212)] Server doesn't support overlay_prioritizer.
[462:0913/203730.961596:WARNING:wayland_surface.cc(228)] Server doesn't support surface_augmenter.
[462:0913/203730.961915:WARNING:wayland_surface.cc(243)] Server doesn't support wp_content_type_v1
[462:0913/203730.962226:WARNING:wayland_surface.cc(262)] Server doesn't support zcr_color_management_surface.
EGL: Warning: No default display support on wayland
[497:0913/203730.987833:ERROR:gl_display.cc(801)] Initialization of all EGL display types failed.
[497:0913/203730.988969:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[497:0913/203730.997371:ERROR:gl_display.cc(801)] Initialization of all EGL display types failed.
[497:0913/203730.998185:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[497:0913/203731.012694:ERROR:viz_main_impl.cc(166)] Exiting GPU process due to errors during initialization
[462:0913/203731.237476:WARNING:bluez_dbus_manager.cc(234)] Floss manager service not available, cannot set Floss enable/disable.
[525:0913/203731.352682:ERROR:gl_display.cc(801)] Initialization of all EGL display types failed.
[525:0913/203731.353900:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[525:0913/203731.363114:ERROR:gl_display.cc(801)] Initialization of all EGL display types failed.
[525:0913/203731.363798:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[525:0913/203731.379525:ERROR:viz_main_impl.cc(166)] Exiting GPU process due to errors during initialization
[532:0913/203731.467328:ERROR:gl_display.cc(801)] Initialization of all EGL display types failed.
[532:0913/203731.467839:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[532:0913/203731.474934:ERROR:gl_display.cc(801)] Initialization of all EGL display types failed.
[532:0913/203731.475322:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[532:0913/203731.486420:ERROR:viz_main_impl.cc(166)] Exiting GPU process due to errors during initialization
At that second try I got a full white screen with no crashes, but nothing more than that.
No idea of what’s going on…
Hi, @renatom!
I apologize for the delayed response.
You said that you could run the demo application using our IDE Extension, and, as far as I understood from your project, your issue is application-related.
Unfortunately, we currently don’t have much expertise about Reacjs and, because of that, I’m afraid that we will not be able to help you, but we can recommend to you our Partner Network, where you can find people who are capable of helping with this issue.
If you have any trouble finding a partner, please feel free to ask for our help, and we can connect you with them.
Best regards.
Lucas Azeituno
