@bertin,
From your log output I can see that your emmc device is being detected as mmc1 instead of mmc0. In the latest versions of our BSP’s we have udev rules in place that create devices that won’t change based on the addresses of the controllers.
Here’s an example of how this looks like for a Verdin iMX8MP running BSP 6:
root@verdin-imx8mp-07330987:~# cat /etc/udev/rules.d/99-toradex.rules
ACTION=="add|change", KERNEL=="i2c-[0-9]*", ATTRS{name}=="30a50000.i2c", SYMLINK+="verdin-i2c1"
ACTION=="add|change", KERNEL=="i2c-[0-9]*", ATTRS{name}=="30a30000.i2c", SYMLINK+="verdin-i2c2"
ACTION=="add|change", KERNEL=="i2c-[0-9]*", ATTRS{name}=="DesignWare HDMI", SYMLINK+="verdin-i2c3"
ACTION=="add|change", KERNEL=="i2c-[0-9]*", ATTRS{name}=="30a40000.i2c", SYMLINK+="verdin-i2c4"
ACTION=="add|change", KERNEL=="i2c-[0-9]*", ATTRS{name}=="30a20000.i2c", SYMLINK+="verdin-i2c-on-module"
ACTION=="add|change", ATTRS{iomem_base}=="0x30860000", SYMLINK+="verdin-uart1"
ACTION=="add|change", ATTRS{iomem_base}=="0x30890000", SYMLINK+="verdin-uart2"
ACTION=="add|change", ATTRS{iomem_base}=="0x30880000", SYMLINK+="verdin-uart3"
ACTION=="add|change", KERNELS=="watchdog", SYMLINK+="verdin-watchdog"
ACTION=="add|change", SUBSYSTEM=="spidev", KERNELS=="30820000.*spi", SYMLINK+="verdin-spi-cs%n"
KERNEL=="mmcblk[0-9]", ENV{DEVTYPE}=="disk", KERNELS=="30b60000.mmc", SYMLINK+="emmc"
KERNEL=="mmcblk[0-9]boot[0-9]", ENV{DEVTYPE}=="disk", KERNELS=="30b60000.mmc", SYMLINK+="emmc-boot%n"
KERNEL=="mmcblk[0-9]p[0-9]", ENV{DEVTYPE}=="partition", KERNELS=="30b60000.mmc", SYMLINK+="emmc-part%n"
SUBSYSTEM=="iio", KERNELS=="iio:device0", RUN+="/etc/udev/scripts/toradex-adc.sh"
ACTION=="add|change", KERNEL=="mmcblk[0-9]", KERNELS=="30b50000.mmc", SYMLINK+="verdin-sd"
ACTION=="add|change", KERNEL=="mmcblk[0-9]p[0-9]*", KERNELS=="30b50000.mmc", SYMLINK+="verdin-sd-part%n"
I think you could try something like this on your device as well, add a udev rules file that creates stable emmc device names that you can then use for the mounting process. Here’s an edited example that I think should work for your case. Notice that I used the address of the mmc1 controller from your boot log file:
KERNEL=="mmcblk[0-9]", ENV{DEVTYPE}=="disk", KERNELS=="78000600.mmc", SYMLINK+="emmc"
KERNEL=="mmcblk[0-9]boot[0-9]", ENV{DEVTYPE}=="disk", KERNELS=="78000600.mmc", SYMLINK+="emmc-boot%n"
KERNEL=="mmcblk[0-9]p[0-9]", ENV{DEVTYPE}=="partition", KERNELS=="78000600.mmc", SYMLINK+="emmc-part%n"
With this file in /etc/udev/rules.d/99-toradex.rules you should be able to mount your root partition in /dev/emmc-part2 and this should eliminate this problem.
