Thanks. Those are interesting and I think I will have to change the “update.sh” script provided by Toradex. Below is the part in the script that I will probably need to edit to generate the gpt partitions.
else
if [ "${MODTYPE}" = "apalis-t30" ] || [ "${MODTYPE}" = "apalis-tk1" ] || [ "${MODTYPE}" = "apalis-tk1-mainline" ] || [ "${MODTYPE}" = "colibri-t30" ] || [ "${MODTYPE}" = "co$
# Boot partition [in sectors of 512]
BOOT_START=$(expr 4096 \* 2)
# Rootfs partition [in sectors of 512]
ROOTFS_START=$(expr 20480 \* 2)
# Boot partition volume id
BOOTDD_VOLUME_ID="boot"
echo ""
echo "Creating MBR file and do the partitioning"
# Initialize a sparse file
dd if=/dev/zero of=${BINARIES}/mbr.bin bs=512 count=0 seek=${EMMC_SIZE}
${PARTED} -s ${BINARIES}/mbr.bin mklabel msdos
${PARTED} -a none -s ${BINARIES}/mbr.bin unit s mkpart primary fat32 ${BOOT_START} $(expr ${ROOTFS_START} - 1 )
# the partition spans to the end of the disk, even though the fs size will be smaller
# on the target the fs is then grown to the full size
if [ "${IMAGEFILE}" = "root.ext3" ] ; then
${PARTED} -a none -s ${BINARIES}/mbr.bin unit s mkpart primary ext3 ${ROOTFS_START} $(expr ${EMMC_SIZE} \- ${ROOTFS_START} \- 1)
else
${PARTED} -a none -s ${BINARIES}/mbr.bin unit s mkpart primary ext4 ${ROOTFS_START} $(expr ${EMMC_SIZE} \- ${ROOTFS_START} \- 1)
then I might need to change the include/configs/colibri_t30.h file in the u-boot source to modify the commands used by the bootloader to perform the update
How do I change the following section/can I change the following section of update.sh to fix that problem?
echo ""
echo "Creating VFAT partition image with the kernel"
rm -f ${BINARIES}/boot.vfat
#${MKFSVFAT} -n "${BOOTDD_VOLUME_ID}" -S 512 -C ${BINARIES}/boot.vfat $BOOT_BLOCKS
dd if=/dev/zero of=${BINARIES}/boot.vfat bs=1024 count=0 seek=${BOOT_BLOCKS_BYTES}
${PARTED} -s ${BINARIES}/boot.vfat mklabel gpt
${PARTED} -a none -s ${BINARIES}/boot.vfat unit b mkpart primary ext4
export MTOOLS_SKIP_CHECK=1
#mcopy -i ${BINARIES}/boot.vfat -s ${BINARIES}/${KERNEL_IMAGETYPE} ::/${KERNEL_IMAGETYPE}
dd if=${BINARIES}/${KERNEL_IMAGETYPE} of=${BINARIES}/boot.vfat
# Copy device tree file
COPIED=false
if test -n "${KERNEL_DEVICETREE}"; then
for DTS_FILE in ${KERNEL_DEVICETREE}; do
DTS_BASE_NAME=`basename ${DTS_FILE} .dtb`
if [ -e "${BINARIES}/${KERNEL_IMAGETYPE}-${DTS_BASE_NAME}.dtb" ]; then
kernel_bin="`readlink ${BINARIES}/${KERNEL_IMAGETYPE}`"
kernel_bin_for_dtb="`readlink ${BINARIES}/${KERNEL_IMAGETYPE}-${DTS_BASE_NAME}.dtb | sed "s,$DTS_BASE_NAME,${MODTYPE},g;s,\.dtb$,.bin,g"`"
if [ "$kernel_bin" = "$kernel_bin_for_dtb" ]; then
mcopy -i ${BINARIES}/boot.vfat -s ${BINARIES}/${DEPLOY_DIR_IMAGE}/${KERNEL_IMAGETYPE}-${DTS_BASE_NAME}.dtb ::/${DTS_BASE_NAME}.dtb
#copy also to out_dir
sudo cp ${BINARIES}/${DEPLOY_DIR_IMAGE}/${KERNEL_IMAGETYPE}-${DTS_BASE_NAME}.dtb "$OUT_DIR/${DTS_BASE_NAME}.dtb"
COPIED=true
fi
fi
done
@marcel.tx Hi Marcel, do you know who wrote the script?
I just would like to change to GPT if possible…or is it not possible to do that?
Edit: I should say that I have already started to change the update.sh in the extract above. you can see that in the commented out lines. I call PARTED instead of MKFSVAT
thanks for chiming in here. I appreciate your contributions to this thread.
I hope so as well. I hope they help out here, I would like that as well. It is clear that specifying partitions with UUIDs is the way forward. As long as the SOC supports it, I am not sure why it is not possible
If I am not mistaken, should you still be using NVIDIA’s ancient downstream Linux kernel it may have some GPT-specific patches which only work with their proprietary partitioning.
Our later BSPs for any of our later SoMs do, of course, support UUID based handling. But NVIDIA’s T30 is rather obsolete at this point, at least when used with their ancient downstream Linux kernel.
Hi Marcel, Ok that sounds great. So because we are using kernel 6.1.8, I modded the BSP to use 6.1.8, we can use GPT as well?
How do we create the image? Should I just use the WKS file or what? How can I package the device tree and pass the address to the kernel? Are there any examples you can point to?
Can we just change the wks file and use wic to create this image and finish this up?
I don’t understand what is going on in certain parts of the update.sh script. Specifically in the excerpt below. I can find no documentation about what this syntax is really doing. Is this really necessary if we can use the wks file to create the boot partition for the 6.1.8 Kernel?
Not yet, but another year with this old BSP and I might. To say that we have our backs against the wall to get our T30 based systems to Linux doesn’t do the situation justice.
I don’t know about you, be we were using WinCE before…
Never touched WinCE. CAT was the only company with management shortsighted enough to use that abomination as far as I knew. Last I heard they were deleting huge chunks of WinCE itself during the build just to get enough room for the app.
Agile is how you end up with disasters like that because Agile is not Software Engineering.
Can Captain Obvious ask a stupid question at this point?
Have you reached out to NVIDIA itself? @marcel.tx made mention that this is an ancient downstream kernel. If you could actually reach the engineering support people at NVIDIA, they might have something “newer” that supports UUID and simply hasn’t bubbled out to the rest of the world. With Heritage hardware that is still selling this is common. The “retail channels” for lack of a better phrase only care about “the new stuff.”
You might have to find a UseNet group for NVIDIA or a mailing list. Probably won’t be any direct communication options with the group you need from the Web site. Might be a directly link to one of those things though. The real problem I have with every vendor on the Internet is they never put dates on pages like these. Unless you are up on Linux Kernel numbers, there is no way to know if that is from 1986 or 2023.
I’m sorry @bertin but I don’t have an answer to you at the moment. I’ll try to look into the changes you’re trying to do and see if I can find some way to help you.
@bertin, I found one reason that maybe your image creation with a GPT partition table is failing. As you can see on the update.sh script, right after the partitions are created the file is truncated to 512 bytes:
echo ""
else
fi
${PARTED} -s ${BINARIES}/mbr.bin unit s print
# get the size of the VFAT partition
BOOT_BLOCKS=$(LC_ALL=C ${PARTED} -s ${BINARIES}/mbr.bin unit b print \
| awk '/ 1 / { print int(substr($4, 1, length($4 -1)) / 1024) }')
# now crop the file to only the MBR size
IMG_SIZE=512
truncate -s $IMG_SIZE ${BINARIES}/mbr.bin
This is done because the MBR occupies only one block. However, GPT occupies 35 blocks at the beginning of the disk and 35 more at the end for the backup GPT, as you can see here:
So by letting the script truncate the file to 512 bytes you’ll essentially remove all the GPT partitions that were previously created. I would suggest that you at least remove the truncation on your script. Because this is a change in the layout that’s written on the disk, you should also take a look at what the update script is doing in u-boot, just to make sure it’s not truncating something there as well, or otherwise overlapping parts of the GPT partition table with other pieces of information.
As for the :: syntax you referred to before, this is from mcopy and it’s what they call in the documentation the : drive (hence the second :, imagine that the first one would be normally something like a or c in windows speak). This : drive is substituted with the contents of the file being inserted with the -s option.
Sorry, I haven’t had chance to try it. This place is chaotic right now and I have been working with wince again now. I should get a chance in a few weeks I think.
Nice to know you aren’t dangling from a ceiling fan in the office . . . though WinCE can make that seem a good option for anyone. What a tragic abomination!
It really is close to that man. I had to drop our linux development and go back to WinCE and the last traces of information on WinCE are being deleted as we speak.
Not to mention that some of the APIs we are using for communications on WinCE… I am not sure if they ever were or will be stable. At this point it feels like a page out of a Kafka novel.
