i rudhi,
I have made progress on this issue with the help of NXP.
I confirm, model on Eiq use classification Model Mobilenet_v2 ( input Size 224,224,3)
My environment
- Hardware: Verdin iMX95
- BSP: Toradex Linux
- Kernel:
Linux 6.6.94-7.4.0-devel
- Neutron driver: built into kernel
- Neutron delegate:
libneutron_delegate.so
Confirmed with NXP
NXP confirmed to me:
- neutron-converter is not required for Linux 6.6
- It is only mandatory starting from Linux 6.12
- Running a standard
.tflite model with libneutron delegate should work on i.MX95
- They successfully run inference on their i.MX95 EVK
- But if i use neutron converter (C:\nxp\eIQ_Toolkit_v1.17.0\bin\neutron-converter\Linux_6.6.36_2.1.0) i have the same problem ( error 442)
I successfully exported my model in INT8 PTQ from eIQ Portal and ran Neutron converter using:
neutron-converter.exe --input <model>.tflite --target imx95
The conversion completes, but the report shows:
Number of operators imported = 65
Number of operators optimized = 90
Number of operators converted = 81
Number of operators NOT converted = 9
Neutron graphs = 4
Operator conversion ratio = 0.9
So 9 operators are not converted by Neutron.
What is working on my side
- Standard TFLite model runs correctly on CPU
- Neutron delegate loads correctly
- TFLite tensors are correct (INT8)
- Graph is delegated successfully:
NeutronDelegate delegate: 62 nodes delegated out of 65
Issue on Verdin iMX95
When inference is executed on NPU:
fail to create neutron inference job
internal fault 442
Node number XX (NeutronDelegate) failed to invoke
This happens:
- after delegate loading,
- after graph partition,
- at first inference execution.
Fallback to CPU works immediately.
Since NXP confirms that Neutron works on i.MX95 EVK without neutron-converter on Linux 6.6, this seems specific to the Toradex BSP integration.
Could you please advise:
- Is Neutron officially validated on Verdin iMX95 with Linux 6.6?
- Which Neutron version / firmware / BSP combination is supported?
- Is there any known issue with Neutron runtime on Toradex BSP?
- Is a microcode / firmware update required?
If i use converted neutron tflite or not converted, there is the same error 442.
log error
[BACKEND] AUTO mode: NPU if available, fallback to CPU on error
[NPU] Attempting to load Neutron delegate…
**[NPU] :check_mark: Neutron delegate loaded successfully.**
**INFO: NeutronDelegate delegate: 62 nodes delegated out of 65 nodes with 2 partitions.**
INFO: Created TensorFlow Lite XNNPACK delegate for CPU.
[TFLITE] Backend actif : NPU
[TFLITE][Tensor] input0: idx=0 shape=[ 1 224 224 3] dtype=<class ‘numpy.int8’> quant_scale=0.007843137718737125 quant_zp=-1
[TFLITE][Tensor] output0: idx=172 shape=[ 1 16] dtype=<class ‘numpy.int8’> quant_scale=0.00390625 quant_zp=-128
[TFLITE] Ops délégués : 0 / 68
Track 0
**[TFLITE][Invoke:NPU] shape=(1, 224, 224, 3) dtype=int8**
**fail to create neutron inference job**
**Error: component=‘Neutron Driver’, category=‘internal fault’, code=442**
** [TFLITE ERROR] backend=NPU, exception=/usr/src/debug/tensorflow-lite-neutron-delegate/2.16.2/neutron_delegate.cc:261 neutronRC != ENONE (113203 != 0)Node number 65 (NeutronDelegate) failed to invoke.**
→ Fallback CPU : réinitialisation de l’interpréteur sans delegate.
[TFLITE] Backend actif : CPU
[TFLITE] Ops délégués : 0 / 66
[TFLITE][Invoke:CPU] shape=(1, 224, 224, 3) dtype=int8
other,
Even the official Toradex TensorFlow Lite example using
mobilenet_v1_1.0_224_quant.tflite fails on our i.MX95 board with :
- Neutron internal fault 442
- fail to create neutron inference job
The delegate loads correctly and nodes are delegated, but inference fails at runtime.
root@verdin-imx95-12594079:/usr/bin/tensorflow-lite-2.16.2/examples# python3 label_image.py -i grace_hopper.bmp -m mobilenet_v1_1.0_224_quant.tflite -i grace_hopper.bmp -l labels.txt -e /usr/lib/libneutron_delegate.so
Loading external delegate from /usr/lib/libneutron_delegate.so with args: {} INFO: NeutronDelegate delegate: 29 nodes delegated out of 31 nodes with 1 partitions. INFO: Created TensorFlow Lite XNNPACK delegate for CPU. fail to create neutron inference job Error: component=‘Neutron Driver’, category=‘internal fault’, code=442 Traceback (most recent call last): File “/usr/bin/tensorflow-lite-2.16.2/examples/label_image.py”, line 120, in interpreter.invoke() File “/usr/lib/python3.12/site-packages/tflite_runtime/interpreter.py”, line 941, in invoke self._interpreter.Invoke() RuntimeError: /usr/src/debug/tensorflow-lite-neutron-delegate/2.16.2/neutron_delegate.cc:261 neutronRC != ENONE (113203 != 0)Node number 31 (NeutronDelegate) failed to invoke.
