Modify Tezi for Custom Board with Verdin-AM62-Solo
I am working on a custom board with verdin-am62 with a lvds display interface. My custom yocto image based on minimal reference image is working fine. We are using TEZI (7.3.0) to update our image.
Is it possible to modify Tezi (device tree) that LVDS-Display is working while updating to see update progress? How?
Also Tezi is activating GPIOs (SODIMM 58,60,62,64) which should not be activated on our hardware. How can I disable that in Tezi?
Another question: Is it also possible to activate LVDS display in uboot for minimal reference image (u-boot-toradex-ti in yocto bsp 7.3.0)? I would like to activate bootscreen in uboot.
Thanks for your help!!
Regards
Immanuel
Hello Immanuel,
I can help you with device tree customization for your Verdin AM62 LVDS display setup. Let me address your questions:
LVDS Display Configuration
The Verdin AM62 supports native LVDS video output through the Open LVDS Display Interface (OLDI) on the SoC (1). According to the datasheet, the LVDS interface provides 8 data lanes split into 2 channels, with single channel supporting resolutions up to 1920x1080p at 60fps (1).
For your LVDS display configuration, you can reference the device tree structure shown in the documentation. The basic approach involves (2):
  1. Define the LVDS panel node with proper timing parameters
  2. Configure the display subsystem (DSS)
  3. Set up the OLDI output connections
Device Tree Customization Process
To customize device trees for your hardware, you’ll need to (3):
  1. Choose the base device tree that matches your hardware platform
  2. Create your custom device tree by copying and modifying the base
  3. Compile the device tree using the Device Tree Compiler
The compilation process involves using the make command (3):
$ make DTC_FLAGS="-@" freescale/<custom-device-tree>.dtb
(3)
GPIO Configuration
To disable unwanted GPIO activation, you can modify the device tree to set the status property to "disabled" for the specific GPIO nodes (2). This approach prevents pins from being configured during boot.
Platform Information Needed
To provide more specific guidance for your TEZI and U-Boot customization questions, could you provide your complete platform details using the tdx-info command? You can find information about this command at: Getting Device Information with Tdx-Info | Toradex Developer Center
This will help me give you precise instructions for:
  • TEZI device tree modifications
  • U-Boot LVDS configuration
  • GPIO control in the bootloader
The customization approach will depend on your exact OS version and hardware configuration.
Hello ToradexAI,
here the output of tdx-info Command:
root@verdin-am62-15479297:~# tdx-info
Software summary
Kernel version:           6.6.94-7.3.0-devel #1 SMP PREEMPT Thu Jul  3 08:47:26 UTC 2025
Kernel command line:      root=PARTUUID=1770490d-02 ro rootwait console=tty1 console=ttyS2,115200 fsck.mode=skip fsck.repair=no
Distro name:              NAME="TDX Wayland with XWayland"
Distro version:           VERSION_ID=7.3.0-devel-20260115091437-build.0
Distro variant:           -
Hostname:                 verdin-am62-15479297
Hardware info
HW model:                 Toradex Verdin AM62 on Dahlia Board
Toradex version:          0071 V1.2A
Serial number:            15479297
I know how to modify device-tree overlays for LVDS or GPIOs. It is working on my custom image.
But how to use that Device Tree Overlay in TEZI-Image?
Immanuel
Hello Immanuel,
Thank you for providing the platform details. I can see you’re running BSP 7.3.0 on a Verdin AM62 with Dahlia Board. Now I can provide specific guidance for your TEZI customization needs.
Modifying TEZI for LVDS Display
To modify the Toradex Easy Installer (TEZI) to support your LVDS display, you’ll need to customize the TEZI image itself. The process involves modifying the device tree used by TEZI (1).
Available LVDS Overlays for Verdin AM62
For your Verdin AM62, there are several pre-built LVDS overlays available (2):
  • verdin-am62_panel-cap-touch-10inch-lvds_overlay.dtbo - for native LVDS with Capacitive Touch Display 10.1" LVDS (with Mallow Carrier Board)
  • verdin-am62_dsi-to-lvds_panel-cap-touch-10inch-lvds_overlay.dtbo - for DSI to LVDS with Capacitive Touch Display 10.1" LVDS using DSI to LVDS Adapter
TEZI Image Modification Process
The documentation indicates that you can modify TEZI images to include custom device tree configurations (1). The process involves:
  1. Extract the TEZI image components
  2. Modify the device tree or add overlays
  3. Repackage the TEZI image
Deploy to Toradex Easy Installer Image
For deploying custom device trees to a TEZI-compatible image, you can follow this process (3):
  1. Start from an existing TEZI image - Download your current TEZI image
  2. Extract the components:
$ mkdir bootfs rootfs
$ tar xvf <Machine>_<image>-Tezi_version+build.<build-number>.tar
$ tar xvf <Machine>_<image>-Tezi_version+build.<build-number>/<image>-<machine>.rootfs.bootfs.tar.xz -C bootfs
$ tar xvf <Machine>_<image>-Tezi_version+build.<build-number>/<image>-<machine>.rootfs.tar.xz -C rootfs
(3)
  1. Copy your custom device trees into the bootfs:
$ cp <linux-directory>/arch/<architecture>/boot/dts/<soc-vendor>/*.dtb bootfs/
(3)
  1. Repackage the image:
$ tar -C bootfs -cJvf <Machine>_<image>-Tezi_version+build.<build-number>/<image>-<machine>.rootfs.bootfs.tar.xz .
$ tar -C rootfs -cJvf <Machine>_<image>-Tezi_version+build.<build-number>/<image>-<machine>.rootfs.tar.xz .
(3)
GPIO Control in TEZI
To disable the unwanted GPIO activation (SODIMM 58, 60, 62, 64) in TEZI, you’ll need to modify the device tree used by the TEZI bootloader. This involves creating a custom overlay that sets these pins to disabled state or configures them appropriately for your hardware.
U-Boot LVDS Configuration
For U-Boot bootscreen support with LVDS on your Verdin AM62, you would need to modify the U-Boot device tree configuration. This is typically done by customizing the U-Boot build in your Yocto environment.
The specific implementation details would depend on your exact display specifications and timing requirements, similar to how you’ve already configured your custom image.
