Any ideas what could be causing this? I am using the apalis-imx8 machine definition. This is a custom distro so all I have removed is the toradex-demo layer. It is linux-toradex v6.6.54 and in u-boot the fdtfile is defined as imx8qm-apalis-v1.1-eval.dtb.
Hello Joe,
Thank you for reaching out with your question about the PCIe issue after migrating from the Kirkstone to Scarthgap BSP on your Apalis iMX8 module. Let’s explore some potential solutions to address the problem with the HSIO control registers:
Device Tree Configuration: Verify that your device tree file (imx8qm-apalis-v1.1-eval.dtb) is correctly set up for your hardware. Ensure it accurately reflects the PCIe configuration and any changes between the BSP versions.
Kernel Configuration: Check that your kernel configuration includes all necessary options for PCIe support. Look for any differences in the kernel configuration between the Kirkstone and Scarthgap versions that might affect PCIe functionality.
HSIO Control Registers: The error regarding missing HSIO control registers suggests a possible misconfiguration. Ensure that the HSIO settings are correctly defined in the device tree and that any required drivers are enabled in the kernel.
BSP Changes: Review the release notes and documentation for the Scarthgap BSP to identify any changes that might impact PCIe functionality, such as driver support or device tree bindings.
Log Analysis: Compare the boot logs from both the Kirkstone and Scarthgap builds to identify any differences in the PCIe subsystem initialization. This can provide insights into what might be missing or misconfigured.
Custom Distro Considerations: Since you are using a custom distribution, ensure that any modifications do not inadvertently disable or misconfigure PCIe support.
By following these steps, you should be able to narrow down the cause of the PCIe issue and take corrective action. If the problem persists, further investigation into specific changes between the BSP versions may be necessary.
I hope this helps resolve your issue. Please feel free to reach out if you have any more questions.
From the last two lines of your Kirkstone logs, it looks like the pcie is aslo mentioned, as not being connected. Do you have a pcie device connected to your module, or are you seeing anything not connected that should be? It could be something is configured in the device tree for pcie, but you are not using it.
-Eric
Eric Singer
Toradex
Hey Joe,
The WiFi module doesn’t seem to be detected and I believe it is connected through pcie from the kernel modules I see loaded on a module that’s still running the kirkstone based operating system.
We should first test this on a basic reference image to see if its custom software related.
Are you able to put the device in recovery mode, load our easy installer and select a reference image. Then can you share the output from lspci from cli of the module. This should list pci devices.
The mwifiex-pcie module is being automatically loaded and dmesg is showing expected pcie logs.
root@apalis-imx8-14904029:~# dmesg | grep pcie
[ 6.273628] imx8q-pcie-phy 5f1a0000.pcie-phy: phy impedance ratio is not specified.
[ 6.294134] imx8q-pcie-phy 5f180000.pcie-phy: phy impedance ratio is not specified.
[ 6.303613] imx8q-pcie-phy 5f190000.pcie-phy: phy impedance ratio is not specified.
[ 6.306124] imx6q-pcie 5f000000.pcie: host bridge /bus@5f000000/pcie@5f000000 ranges:
[ 6.306178] imx6q-pcie 5f000000.pcie: IO 0x006ff80000..0x006ff8ffff -> 0x0000000000
[ 6.306197] imx6q-pcie 5f000000.pcie: MEM 0x0060000000..0x006fefffff -> 0x0060000000
[ 6.323170] imx6q-pcie 5f010000.pcie: host bridge /bus@5f000000/pcie@5f010000 ranges:
[ 6.335434] imx6q-pcie 5f010000.pcie: IO 0x007ff80000..0x007ff8ffff -> 0x0000000000
[ 6.359641] imx6q-pcie 5f010000.pcie: MEM 0x0070000000..0x007fefffff -> 0x0070000000
[ 6.392676] imx8q-pcie-phy 5f190000.pcie-phy: PHY PLL is locked
[ 6.418956] imx8q-pcie-phy 5f180000.pcie-phy: PHY PLL is locked
[ 6.616722] imx6q-pcie 5f010000.pcie: iATU: unroll F, 6 ob, 6 ib, align 4K, limit 4G
[ 6.616775] imx6q-pcie 5f010000.pcie: eDMA: unroll F, 1 wr, 1 rd
[ 6.640822] imx6q-pcie 5f000000.pcie: iATU: unroll F, 6 ob, 6 ib, align 4K, limit 4G
[ 6.640918] imx6q-pcie 5f000000.pcie: eDMA: unroll F, 1 wr, 1 rd
[ 6.716837] imx6q-pcie 5f010000.pcie: PCIe Gen.1 x1 link up
[ 6.727960] imx6q-pcie 5f010000.pcie: Link: Only Gen1 is enabled
[ 6.727965] imx6q-pcie 5f010000.pcie: Link up, Gen1
[ 6.827535] imx6q-pcie 5f010000.pcie: PCIe Gen.1 x1 link up
[ 6.828086] imx6q-pcie 5f010000.pcie: PCI host bridge to bus 0000:00
[ 7.021612] pcieport 0000:00:00.0: PME: Signaling with IRQ 592
[ 7.028036] pcieport 0000:00:00.0: AER: enabled with IRQ 592
[ 7.640855] imx6q-pcie 5f000000.pcie: Phy link never came up
[ 8.640569] imx6q-pcie 5f000000.pcie: Phy link never came up
[ 8.648819] imx6q-pcie 5f000000.pcie: PCI host bridge to bus 0001:00
[ 8.756617] pcieport 0001:00:00.0: PME: Signaling with IRQ 593
[ 8.763319] pcieport 0001:00:00.0: AER: enabled with IRQ 593
[ 8.940469] imx8q-pcie-phy 5f1a0000.pcie-phy: PHY PLL is locked
[ 8.941844] imx8q-pcie-phy 5f1a0000.pcie-phy: PHY calibration is done
[ 9.051229] mwifiex_pcie 0000:01:00.0: no quirks enabled
[ 9.059624] mwifiex_pcie 0000:01:00.0: enabling device (0000 -> 0002)
[ 9.079255] mwifiex_pcie: PCI memory map Virt0: 000000004d3ea244 PCI memory map Virt2: 00000000bea98574
[ 10.174083] mwifiex_pcie 0000:01:00.0: info: FW download over, size 639044 bytes
[ 10.940538] mwifiex_pcie 0000:01:00.0: WLAN FW is active
[ 11.001936] mwifiex_pcie 0000:01:00.0: info: MWIFIEX VERSION: mwifiex 1.0 (16.68.10.p159)
[ 11.011925] mwifiex_pcie 0000:01:00.0: driver_version = mwifiex 1.0 (16.68.10.p159)
I’ll keep searching through what’s missing but I have been operating thus far without making kernel file changes so it must be something included or configured through the toradex layers I must not have carried over properly in kirkstone.
I have not had time to get back to this yet. I can say the problem is not with the toradex reference images (even 7.1 builds did not have this issue). I haven’t isolated what the cause is yet but As far as layer differences I believe I am only missing the demo layer as far as layers pertaining to nxp boards is concerned.
I was finally able to get back to this. The issue appears that my version of U-Boot on the board needed to be updated. I was able to reflash my board with uuu with the tdx 7.x version of u-boot and pcie came back. I am doing my migration and updates using RAUC so I will need to write the u-boot binary manually to migrate devices. Is there documentation about where it should be written? On our other systems we write to the MMC Boot Partitions and I know the env variables are stored there but I couldn’t see evidence if the u-boot binary was stored there.
Edit/Update:
It was apparently a device-tree change that I must not have been updating properly or changed from the kirkstone branches. I was updating the imx8qm-apalis-v1.1-ixora-v1.2.dtb file instead of imx8qm-apalis-v1.1-eval.dtb which u-boot was loading.
