I am tying to connect a 5Gbs NIC to PCIe of IMX8 module. Our hardware team made a custom carrier board per guide provided. I was able to get the NIC to communicate with module by bitbaking a custom image with the driver needed.
root@apalis-imx8-07307404:~# uname -a
Linux apalis-imx8-07307404 5.4.193-5.7.0-devel+git.f78299297185
NIC used is QNAP QXG-5G1T-111C.
NIC works on Gen3 speeds but when connected to carrier board the established connection works on Gen1 speeds and max bandwith I am able to achieve is 1.5Gbs.
Are there any other hardware limitations preventing PCIe link/speed to work on higher speeds?
Any help is appreaciated.
root@apalis-imx8-07307404:~# dmesg | grep pci
[ 0.000000] Kernel command line: pci=nomsi root=PARTUUID=b7d8e883-02 ro rootwait
[ 0.274859] imx6q-pcie 5f000000.pcie: 5f000000.pcie supply epdev_on not found, using dummy regulator
[ 1.753986] ehci-pci: EHCI PCI platform driver
[ 2.574517] imx6q-pcie 5f010000.pcie: pcie_ext clock source missing or invalid
[ 2.582036] imx6q-pcie 5f000000.pcie: 5f000000.pcie supply epdev_on not found, using dummy regulator
[ 2.604469] imx6q-pcie 5f000000.pcie: No cache used with register defaults set!
[ 2.727246] imx6q-pcie 5f000000.pcie: PCIe PLL locked after 0 us.
[ 2.949254] imx6q-pcie 5f000000.pcie: host bridge /bus@5f000000/pcie@0x5f000000 ranges:
[ 2.957338] imx6q-pcie 5f000000.pcie: IO 0x6ff80000..0x6ff8ffff -> 0x00000000
[ 2.965051] imx6q-pcie 5f000000.pcie: MEM 0x60000000..0x6fefffff -> 0x60000000
[ 3.072575] imx6q-pcie 5f000000.pcie: Link up
[ 3.077610] imx6q-pcie 5f000000.pcie: Link: Gen2 disabled
[ 3.083257] imx6q-pcie 5f000000.pcie: Link up, Gen1
[ 3.088510] imx6q-pcie 5f000000.pcie: PCI host bridge to bus 0000:00
[ 3.094880] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.100379] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 3.106572] pci_bus 0000:00: root bus resource [mem 0x60000000-0x6fefffff]
[ 3.106588] pci 0000:00:00.0: [1957:0000] type 01 class 0x060400
[ 3.120561] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x00ffffff]
[ 3.137906] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x00ffffff pref]
[ 3.144658] pci 0000:00:00.0: supports D1 D2
[ 3.148934] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
[ 3.158432] pci 0000:01:00.0: [1d6a:11b1] type 00 class 0x020000
[ 3.171044] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x0000ffff 64bit]
[ 3.177883] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 3.184705] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x003fffff 64bit]
[ 3.191539] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0003ffff pref]
[ 3.198266] pci 0000:01:00.0: enabling Extended Tags
[ 3.198468] pci 0000:01:00.0: supports D1 D2
[ 3.212344] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 3.223447] pci 0000:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x1 link at 0000:00:00.0 (capable of 7.876 Gb/s with 8 GT/s x1 link)
[ 3.235888] imx6q-pcie 5f010000.pcie: No cache used with register defaults set!
[ 3.238916] imx6q-pcie 5f010000.pcie: PCIe PLL locked after 0 us.
[ 3.269630] pci 0000:00:00.0: BAR 0: assigned [mem 0x60000000-0x60ffffff]
[ 3.279495] pci 0000:00:00.0: BAR 6: assigned [mem 0x61000000-0x61ffffff pref]
[ 3.286744] pci 0000:00:00.0: BAR 14: assigned [mem 0x62000000-0x625fffff]
[ 3.300463] pci 0000:01:00.0: BAR 4: assigned [mem 0x62000000-0x623fffff 64bit]
[ 3.307806] pci 0000:01:00.0: BAR 6: assigned [mem 0x62400000-0x6243ffff pref]
[ 3.318024] pci 0000:01:00.0: BAR 0: assigned [mem 0x62440000-0x6244ffff 64bit]
[ 3.328177] pci 0000:01:00.0: BAR 2: assigned [mem 0x62450000-0x62450fff 64bit]
[ 3.339436] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 3.344672] pci 0000:00:00.0: bridge window [mem 0x62000000-0x625fffff]
[ 3.351753] pcieport 0000:00:00.0: PME: Signaling with IRQ 568
[ 3.449288] imx6q-pcie 5f010000.pcie: host bridge /bus@5f000000/pcie@0x5f010000 ranges:
[ 3.457394] imx6q-pcie 5f010000.pcie: IO 0x7ff80000..0x7ff8ffff -> 0x00000000
[ 3.465089] imx6q-pcie 5f010000.pcie: MEM 0x70000000..0x7fefffff -> 0x70000000
[ 4.472957] imx6q-pcie 5f010000.pcie: Phy link never came up
[ 4.478719] imx6q-pcie 5f010000.pcie: failed to initialize host
[ 4.484711] imx6q-pcie 5f010000.pcie: unable to add pcie port.
root@apalis-imx8-07307404:~# lspci
00:00.0 PCI bridge: Freescale Semiconductor Inc Device 0000 (rev 01)
01:00.0 Ethernet controller: Aquantia Corp. AQC111 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion] (rev 02)
modprobing the driver shows no output. Tried modprobing other drivers aswell and got no output aswell.
root@apalis-imx8-07307404:~# lspci -x
00: 57 19 00 00 07 01 10 00 01 00 04 06 00 00 01 00
10: 00 00 00 60 00 00 00 00 00 01 ff 00 f1 01 00 00
20: 00 62 50 62 f1 ff 01 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 38 01 02 00
00: 6a 1d b1 11 06 00 10 00 02 00 00 02 00 00 00 00
10: 04 00 44 62 00 00 00 00 04 00 45 62 00 00 00 00
20: 04 00 00 62 00 00 00 00 00 00 00 00 aa 1b b3 87
30: 00 00 00 00 40 00 00 00 00 00 00 00 38 01 00 00
root@apalis-imx8-07307404:~# lspci -vv
00:00.0 PCI bridge: Freescale Semiconductor Inc Device 0000 (rev 01) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 568
Region 0: Memory at 60000000 (32-bit, non-prefetchable) [size=16M]
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: 62000000-625fffff [size=6M]
Prefetchable memory behind bridge: [disabled]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
Expansion ROM at 61000000 [virtual] [disabled] [size=16M]
BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/16 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [70] Express (v2) Root Port (Slot-), MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0
ExtTag- RBE+
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x2, ASPM L0s, Exit Latency L0s unlimited
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 128 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s (ok), Width x1 (downgraded)
TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
RootCap: CRSVisible-
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, NROPrPrP+, LTR-
10BitTagComp-, 10BitTagReq-, OBFF Not Supported, ExtFmt-, EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS-, LN System CLS Not Supported, TPHComp-, ExtTPHComp-, ARIFwd-
AtomicOpsCap: Routing- 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
AtomicOpsCtl: ReqEn- EgressBlck-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
RootCmd: CERptEn- NFERptEn- FERptEn-
RootSta: CERcvd- MultCERcvd- UERcvd- MultUERcvd-
FirstFatal- NonFatalMsg- FatalMsg- IntMsg 1
ErrorSrc: ERR_COR: 0000 ERR_FATAL/NONFATAL: 0000
Capabilities: [148 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn-, PerformEqu-
LaneErrStat: 0
Capabilities: [168 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=10us
L1SubCtl2: T_PwrOn=10us
Kernel driver in use: pcieport
Subsystem: QNAP Systems, Inc. AQC111 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
Region 0: Memory at 62440000 (64-bit, non-prefetchable) [size=64K]
Region 2: Memory at 62450000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at 62000000 (64-bit, non-prefetchable) [size=4M]
Expansion ROM at 62400000 [virtual] [disabled] [size=256K]
Capabilities: [40] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
LnkCap: Port #0, Speed 8GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 unlimited
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
LnkSta: Speed 2.5GT/s (downgraded), Width x1 (ok)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+, NROPrPrP-, LTR-
FRS-, TPHComp-, ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
Capabilities: [80] Power Management version 3
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [90] MSI-X: Enable- Count=32 Masked-
Vector table: BAR=2 offset=00000000
PBA: BAR=2 offset=00000200
Capabilities: [a0] MSI: Enable- Count=1/32 Maskable- 64bit+
Capabilities: [c0] Vital Product Data
Product Name: Atlantic
Read-only fields:
[PN] Part number: 3290495095
[EC] Engineering changes: 0
[FG] Unknown: 61 62 63
[LC] Unknown: 64 65 66
[MN] Manufacture ID: AFDSWEWEBSFD
[PG] Unknown: 49 49 49
[SN] Serial number: CPL5938TLKMY
[V0] Vendor specific: wfewfe
[V1] Vendor specific: fwewfe
[V2] Vendor specific: SDFWI
[RV] Reserved: checksum good, 0 byte(s) reserved
Read/write fields:
[YA] Asset tag: 9495829
[V0] Vendor specific: f34ge4rsg
[V1] Vendor specific: ger35g5rthghgsa3
[Y0] System specific: bsdfvbxcz
[Y1] System specific: fwefewwfe
[RW] Read-write area: 11 byte(s) free
End
Capabilities: [150 v1] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [180 v1] Secondary PCI Express
LaneErrStat: 0
Kernel driver in use: atlantic
Kernel modules: atlantic
