We are experiencing a problem with our display touch panel that is connected to a Verdin AM62 SoM and a mallow carrier board through native LVDS which flickers constantly. We tried fixing it by changing the device tree panel timings according to the touch panel datasheet. We also measured the DCLK frequency but no matter what we set in the device tree it always showed a lower frequency than the one that was set (e.g. the .dts file had DCLK freq set to ~50MHz and the measurement showed ~20MHz). We also noticed that these problems do not occur when connecting the display through a DSI-to-LVDS connector (on Dahlia carrier board).
I’m sending you the device tree that we use for the native LVDS interface:
verdin-am62_panel-cap-touch-5inch-lvds_ilitek-inverted_overlay.dts (4.4 KB)
Tdx Info:
Software summary
Bootloader: U-Boot
Kernel version: 6.6.84-7.3.0-devel-g9d1f86864908 #1-Torizon SMP PREEMPT Thu May 29 10:29:09 UTC 2025
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/d4be0d9fcde4ef75b9f04279ca846b85dd668cde5b3c8a8a92e3bd87f973ba02/0
Distro name: NAME="Torizon OS"
Distro version: VERSION_ID=7.3.0-devel-202506-build.9
Distro variant: VARIANT="Docker"
Hostname: verdin-am62-15380640
Hardware info
HW model: Toradex Verdin AM62 WB on Mallow Board
Toradex version: 0076 V1.1C
Serial number: 15380640
Processor arch: aarch64
