LVDS clock setting IMX6 Apalis
I try to set up a dual display system with a display on both lvds channels, but I can’t get the desired frequency on my LVDS output.
fbset shows the correct frequnecy of 71.1 MHz, but the measured frequency is just 37.7MHz.
i think it might be the parent clock, because i get error message during start up and the lvds clock is obviously not on PLL5 as you can see below.
Do you have any idea why the clock isn’t 71 MHz ?
Thank you and best regards
mode "1280x800-60"
	# D: 71.104 MHz, H: 49.377 kHz, V: 59.997 Hz
	geometry 1280 800 1280 800 32
	timings 14064 0 150 0 13 10 10
	accel false
	rgba 8/16,8/8,8/0,8/24
pll2                                  1            1   528000000          0 0
   pll2_bypass                        1            1   528000000          0 0
      pll2_bus                        3            3   528000000          0 0
         periph2_pre                  1            1   528000000          0 0
            periph2                   1            1   528000000          0 0
               mmdc_ch1_axi_podf           1            1   264000000          0 0
                  mmdc_ch1_axi           2            2   264000000          0 0
                     ldb_di0_sel           1            1   264000000          0 0
                        ldb_di0_div_7           0            0    37714285          0 0
                           ldb_di0_div_sel           0            0    37714285          0 0
                        ldb_di0_div_3_5           1            1    75428571          0 0
                           ldb_di0_podf           1            1    37714286          0 0
                              ldb_di0           1            1    37714286          0 0
                                 ipu2_di1_sel           1            1    37714286          0 0
                                    ipu2_di1            1            1    37714286          0 0
                                       ipu2_pclk1_sel           1            1    37714286          0 0
                                          ipu2_pclk1_div            1            1    37714286          0 0
                                             ipu2_pclk1                   1            1    37714286          0 0
[    0.000000] ccm: invalid ldb_di0 parent clock: 174
[    0.000000] ccm: invalid ldb_di1 parent clock: 174
[    0.000000] clk: failed to reparent ldb_di0_sel to pll5_video: -38
[    0.000000] clk: failed to reparent ldb_di1_sel to pll5_video: -38
And the device tree settings:
	&ldb {
	//	split-mode;
	//	dual-mode;
		lvds-channel@0 {
			//fsl,data-mapping = "spwg"; /* "jeida";*/
			fsl,data-width = <24>;
			display-timings {
				native-mode = <&timing_xga_ol>;
				timing_xga_ol: 1280x800 {
					clock-frequency = <71100000>;
					hactive = <1280>;
					vactive = <800>;
					hback-porch = <0>;
					hfront-porch = <150>;
					vback-porch = <0>;
					vfront-porch = <13>;
					hsync-len = <10>;
					vsync-len = <10>;
					hsync-active = <0>;
					vsync-active = <0>;
					pixelclk-active = <0>;
    lvds-channel@1 {
			display-timings {
				native-mode = <&timing_xga_di>;
				timing_xga_di: 1280x800 {
					hactive = <1280>;
					vactive = <800>;
					hback-porch = <0>;
					vback-porch = <0>;
					hsync-len = <10>;
					vsync-len = <10>;
					hsync-active = <0>;
					vsync-active = <0>;
hi @delisys
Could you provide the version of the Hardware and Software of your module? Which carrier board are you using?
Regarding your issues, could you provide the full devicetree Files and the full serial boot log in a text file?
Thanks and best regards,
Hi @delisys
Is there any update here? We have a similar issue with our custom carrier board together with an Apalis IMX6Q module. The measured frequency is 37.5MHz on our board and should be 65MHz.
Patrick
Hi @delisys,
We have changed the Clock source of the LDB regarding the following paper and after that the clock was correct:
Best Regards, Patrick
Hi @patrick.morger
Could you please share the patch file. It’s been a month and We are still facing the same issue.
We’re setting 71Mhz in the device tree but getting 37 Mhz at the output.
Hello @krishnab-a , welcome to the community :partying_face:
Unfortunately @patrick.morger has not been active for quite some time.
Have you tried his solution?
Josep
I’m using the kernel version 5.15.63. I’m setting 71.11Mhz in device tree but getting 37.7Mhz at the lvds display output. I’m not sure how to make changes according to the ldb switching procedure PDF that is given above. If you a patch file for this issue. could you please share.
Hello @krishnab-a ,
At the moment we don’t have any patches, but there is a similar thread with more information. Hope that it helps.
Josep
Thanks a lot @josep.tx
You made my day. Love your brother. It’s working like a charm.
@krishnab-a , thanks for your feedback :slight_smile:
Can you please mark the most suitable answer as a solution?
Josep
