LTE communication with Verdin i.mx8mm
I want to use LTE communication with Verdin i.mx8mm + Ivy.
I found this page from the following post:
But there is nothing written there.
Where can I find out about proven LTE modules?
Hello! Thank you for your question regarding LTE communication with your Verdin i.MX8MM + Ivy setup.
To find LTE (cellular) modules that are tested and proven to work with Toradex hardware, please refer to the Toradex Peripheral Database, specifically filtered for cellular modules:
https://developer.toradex.com/hardware/hardware-resources/peripherals/peripheral-database/?type=cellular
As of now, the following LTE modules are listed as tested and compatible:
Sierra Wireless:
  • AirPrime MC7354: Supports LTE, GNSS, GSM/GPRS/EDGE, and UMTS/HSPA with a PCIe interface.
  • AirPrime MC7455: Supports LTE, GNSS, GSM/GPRS/EDGE, and UMTS/HSPA, also with a PCIe interface.
Fibocom:
  • FM160-EAU: A 5G-capable module that supports LTE (as well as GNSS, GSM/GPRS/EDGE, UMTS/HSPA) with USB and PCIe interfaces.
To see the complete compatibility and details for each device, click on their names in the Peripheral Database. The list is maintained and updated as new devices are validated.
If you don’t see any modules listed on the page, please refresh or revisit the link, as it should display a table of compatible devices. You can also explore other peripheral types if needed.
Here is the direct link again:
If you have specific requirements or further questions about module selection or integration, let me know!
Sorry, The reason I couldn’t see it was because I had it open in Chrome.
