Looking for a High-Brightness 7-Inch LVDS Display Compatible with Ixora LVDS Connector and Apalis i.MX8 for Automotive Use
Hi Toradex Community,
I am currently working on a project using the Apalis i.MX8 module with the Ixora carrier board. I am searching for a 7-inch display that meets the following requirements:
  • Interface: LVDS, compatible with the Ixora LVDS connector.
  • Brightness: High brightness suitable for outdoor/automotive environments (e.g., >800 nits).
  • Purpose: Designed for automotive use, ensuring readability in direct sunlight and wide temperature range.
If anyone has experience with a compatible display or can recommend models/vendors that work seamlessly with the Ixora and Apalis i.MX8, I’d greatly appreciate your input.
Thank you in advance for your suggestions!
Thank you for reaching out with your inquiry about finding a suitable 7-inch LVDS display for your project using the Apalis i.MX8 module and Ixora carrier board. Ensuring compatibility and meeting your specific requirements for high brightness and automotive use is crucial.
When selecting a display, here are some key considerations:
  • LVDS Interface Compatibility: Ensure that the display has an LVDS interface that matches the connector on the Ixora carrier board. This involves checking the pin configuration and ensuring that the signal levels are compatible.
  • Brightness: For outdoor and automotive environments, a display with a brightness level of over 800 nits is recommended. This ensures readability in direct sunlight.
  • Automotive Grade: Look for displays that are rated for wide temperature ranges and are specifically designed for automotive applications. This ensures reliability under varying environmental conditions.
  • Electrical and Mechanical Compatibility: Verify that the display’s power requirements and physical dimensions are compatible with your setup. This includes ensuring that the display can be securely mounted and connected to the Ixora board.
While I cannot recommend specific models or vendors, focusing on these technical aspects will help you identify a display that meets your needs. If you have further questions about integration or need more detailed technical guidance, feel free to ask.
Toradex AI Assistant
Issue with displaying 2 different application on 2 different screens (LVDS and HDMI).
Hi, @wissemyakoubi!
Have you already checked Toradex’s Partners website?
https://www.toradex.com/support/partner-network
Here is the list with partners related o displays: Toradex - Partner Network Services
Hi @wissemyakoubi !
Do you have any updates here?
Hi @wissemyakoubi !
Could you please share some update related to this topic?
Is this already solved?
