Integration of DAS Storage with Toradex SOMs
Hello everyone,
I am currently working on a project using a Toradex Colibri iMX6 SOM, and I am considering integrating a DAS Storage device for additional storage needs. Before proceeding, I wanted to get some insights:
  1. Are there any best practices or specific considerations for connecting DAS storage to Toradex SOMs?
  2. What interfaces (e.g., USB, SATA) work best for this integration in terms of performance and reliability?
  3. Are there any known compatibility issues with DAS devices on the Toradex Linux BSP?
Any recommendations, resources, or examples from your experience would be greatly appreciated!
Thanks in advance for your help!
Looking forward to your inputs.
Thank you for reaching out with your questions about integrating Direct Attached Storage (DAS) with your Toradex Colibri iMX6 System on Module (SOM). Here are some insights to help you with your project:
  1. Best Practices for Connecting DAS:
    • Interface Selection: The Colibri iMX6 does not natively support SATA, so using USB is the most practical option for connecting DAS devices. Ensure your DAS device is compatible with USB 2.0 or 3.0, depending on your performance needs and the specific Colibri module variant you are using.
    • Power Supply: Make sure that your DAS device is adequately powered. Some USB storage devices may require more power than what the USB port can provide, so an external power source might be necessary.
    • File System Compatibility: Opt for a file system that is well-supported by Linux, such as ext4, to avoid any compatibility issues.
  2. Interface Considerations:
    • USB: This is the most straightforward option for the Colibri iMX6. While USB 2.0 is standard, if your carrier board supports USB 3.0, it can offer improved performance.
    • Performance and Reliability: USB interfaces are generally reliable, but performance can vary based on the USB version and the quality of the DAS device. For critical applications, consider using industrial-grade storage devices.
  3. Compatibility with Toradex Linux BSP:
    • Driver Support: Ensure that the Linux BSP version you are using supports USB storage class drivers. Most modern Linux kernels, including those used in Toradex BSPs, have robust support for USB storage.
    • Kernel Configuration: Verify that the necessary kernel modules for USB storage are enabled. This is typically the case in default Toradex BSP configurations.
By following these guidelines, you should be able to effectively integrate DAS with your Colibri iMX6 SOM. If you encounter specific issues, reviewing the kernel logs and ensuring your BSP is up-to-date can help resolve compatibility problems.
I hope this helps with your project. Feel free to reach out if you have more questions.
Toradex AI Assistant
https://www.toradex.com/de/computer-on-modules/colibri-arm-family/nxp-freescale-imx6
Using two Ethernet interfaces on Toradex Apalis iMX8 Quad Max module.
Hi @leoarthur!
The answer from Toradex AI is a good starting point. Have you tested the integration already?
Best regards.
Lucas Azeituno
