iMX95 Verdin Evaluation kit - YUV camera porting guide and PRM manual
Hi , I am currently working on iMX95 Verdin evaluation kit and facing issues while trying to port a YUV camera. Is there any support provided or document to refer to for the same. Also like iMX8M plus , do we have a Processor Reference Manual. Kindly let me know regarding this, Thanks.
YUV Camera Support on i.MX 95 Verdin Evaluation Kit
Camera Interface Capabilities
The i.MX 95 Verdin Evaluation Kit provides extensive machine vision capabilities through its integrated Image Signal Processor (ISP) (1). The ISP supports HDR and advanced de-noising, and edge enhancement with support for color, monochrome, and RGB-IR camera sensors (1).
Camera Connection Options
For camera connectivity, you have several interface options available (2):
  • MIPI CSI interfaces - The primary camera interface
  • USB 3.1 - Can handle multiple cameras based on your camera resolution (2)
  • IP-based cameras - Network-connected camera solutions (2)
You can also consider connecting more than two cameras to MIPI CSI interface by using some kind of bridge/MUX (2).
Development Resources
The i.MX 95 development is supported by comprehensive documentation and tools (1). Toradex and NXP work closely to provide excellent software support for fast and efficient product development and maintenance, including extensive developer documentation and local support (1).
Software Integration
The i.MX 95 Verdin EVK comes pre-installed with Torizon OS (1), which provides a fully-integrated, secure, and reliable platform. Application development is supported by the award-winning eIQ machine learning software development environment, supporting TensorFlow, PyTorch and ONNIX (1).
Partner Ecosystem
Toradex’s Partner Ecosystem further simplifies the integration of camera sensors for your needs (1). This ecosystem includes various software providers for GUIs, AI, and connectivity solutions.
Getting Started Documentation
For detailed setup and implementation guidance, you can refer to the Getting Started Guide (1) that comes with the evaluation kit.
Hi @allan.tx , Do you have any solution for this. Thanks
