I’m trying to use an iMX8MP on a Mallow carrier board, but it seems as if the bootloader doesn’t detect the carrier boar correctly.
As a result I’m not able to use the UserLEDs for a simple HelloWorld ![]()
Mike
U-Boot 2022.04-6.5.0+git.28dc906f6107 (Jan 01 1970 - 00:00:00 +0000)
CPU: i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 28C
Reset cause: POR
DRAM: 4 GiB
Core: 89 devices, 23 uclasses, devicetree: separate
WDT: Started watchdog@30280000 with servicing (60s timeout)
MMC: FSL_SDHC: 1, FSL_SDHC: 2
In: serial
Out: serial
Err: serial
Model: Toradex 0063 Verdin iMX8M Plus Quad 4GB IT V1.1B
Serial#: 15230479
MISSING TORADEX CARRIER CONFIG BLOCKS
SEC0: RNG instantiated
Software summary
Bootloader: U-Boot
Kernel version: 5.15.129-6.5.0+git.6f8fd49366db #1-TorizonCore SMP PREEMPT Fri Dec 22 11:15:52 UTC 2023
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/fe091cbe7b665ff6d9d5d618cb20c42c90c242fffeaceccf204eacd186b2f597/0
Distro name: NAME="TorizonCore"
Distro version: VERSION_ID=6.5.0-build.8
Distro variant: VARIANT="Docker"
Hostname: verdin-imx8mp-15230479
Hardware info
HW model: Toradex Verdin iMX8M Plus on Verdin Development Board
Toradex version: 0063 V1.1B
Serial number: 15230479
Processor arch: aarch64
