we made a custom carrier board with our own device tree (imx8mm-verdin-wifi-LP-11828-03.dts (5.6 KB), decompiled.txt (78.7 KB)) for a Verdin iMX8MM on BSP6.0.
Since we don’t use the SD/MMC interace (usdhc2: mmc@30b50000) I leave the node in ‘disabled’ state.
But when the system is started I get the following
$ gpioinfo 1
line 12: "SODIMM_84" "cd" input active-low [used]
line 13: "SODIMM_78" unused input active-high
line 14: "SODIMM_74" unused input active-high
line 15: "SODIMM_80" unused input active-high
line 16: "SODIMM_82" unused input active-high
line 17: "SODIMM_70" unused input active-high
line 18: "SODIMM_72" unused input active-high
$ cat /proc/interrupts
115: 33145059 0 0 0 gpio-mxc 12 Edge 30b50000.mmc cd
Although the node usdhc2 is disabled, the gpio for card detection (imx8mm-verdin.dtsi, line 789) is still used as interrupt input.
I have no idea where this function is defined. How can I disable it?
Markus
