IMX8M-MINI + Mallow : No HDMI Output, Easy Installer is not working
I am currently using the iMX8M-MINI SOM and Mallow boards.
I am facing two issues:
  1. When connecting an HDMI cable to the Mallow board, the monitor does not display anything. The monitor shows a “No Signal” message.
  2. When I check the system through SSH, I can log in without any issues, so I believe the board is functioning properly.
  3. To resolve this problem, I tried reinstalling the image using the Toradex Easy Installer.
    (Reference: Toradex Easy Installer Recovery Mode Documentation)
During the first attempt, I was able to connect using VNC Viewer. However, after installing the image and re-entering Recovery Mode to connect with VNC Viewer again, it failed to connect.
Upon checking, I noticed that only the POWER LED on the Mallow board was lit. LEDs 3 and 4 were not lit, and there was no Ethernet link activity. This makes me suspect that the system is not booting properly.
  1. My assumption is that the system is failing to boot properly in Recovery Mode.
Questions:
  1. What could be the possible causes for HDMI output not working?
  2. If the Toradex Easy Installer does not function properly, is there an alternative method to rewrite the image using an SD card or another medium? (I tried searching on the developer site but could not find the relevant information.)
Thank you for reaching out with your questions about the iMX8M-MINI SOM and Mallow boards. Let’s address each of your concerns:
  1. HDMI Output Issue:
    • First, ensure that the HDMI cable is connected to the Mallow board before powering it on, as HDMI hotplug is not supported. The board needs to detect the monitor at boot time.
    • Verify that both the HDMI cable and the monitor are functioning correctly by testing them with another device.
    • Check the monitor’s input settings to ensure it is set to the correct HDMI input.
  2. Toradex Easy Installer and Recovery Mode Issues:
    • When using the Toradex Easy Installer, make sure to follow the recovery mode steps precisely. This involves connecting the board to a host computer via USB OTG and running the recovery script to load the installer into RAM.
    • If the Easy Installer does not function properly, ensure that all connections are secure and that the USB cable is properly connected. Try using a different USB port or cable if necessary.
    • Use a serial console to access the Easy Installer’s shell for debugging. You can view logs at /var/volatile/tezi.log to diagnose issues.
    • Ensure that the board’s power supply is stable and that all necessary connections are secure.
By following these steps, you should be able to resolve the HDMI output issue and successfully use the Toradex Easy Installer. If problems persist, consider reviewing your setup and connections.
I hope this helps you get your system up and running smoothly.
Easy Installer problem on AM62 D, IT with Mallow V1.1 board.
I found that IMX8M-MINI doesn’t support HDMI output
“Note that tha Mallow carrier board HDMI is only compatible with Verdin iMX8M Plus modules”
So only Toradex Easy Installer is the only issue left.
I followed AI suggestions but it doesn’t solve the issue.
there’s no /var/volatile/tezi.log.
torizon@verdin-imx8mm-14839014:/var/volatile$ uname -a
Linux verdin-imx8mm-14839014 5.15.148-6.8.0+git.8c5c2dcbf6ba #1-TorizonCore SMP PREEMPT Tue Aug 6 10:01:59 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux
torizon@verdin-imx8mm-14839014:/var/volatile$ ls
log tmp
I solved the issue myself and am sharing my experience for anyone who encounters the same problem.
I was unable to recover the Toradex Easy Installer on Windows OS because the recover-windows.bat script didn’t work properly, as Windows couldn’t detect the driver correctly. However, I was able to detect the “NXP Semiconductor SE Blank M845” and successfully recover the Easy Installer using Ubuntu.
Hi @eziya76
Happy to know that you were able to solve your problem and thanks for sharing how you managed to “workaround” it.
First, you should always be able to put the device on recovery mode, so the problem is mostly likely on loading the Toradex Easy Installer (Tezi) image.
We have a Troubleshoot on Windows section at the end of this page for common issues. The solution for the missing driver issue is listed here.
