I’m trying to build a custom Open Embedded image, based on the iMX8 Console Image. I’ve found that the console image is actually based on Wayland; I will eventually be running an EGLFS-based Qt application, so I don’t want Wayland included in the build.
Can you please clarify the process for removing Wayland as part of the OE-Core build? I note that in the meta-toradex-distro layer, there are wayland and x11 options; can I simply add DISTRO_FEATURES_remove = “x11 wayland” and IMAGE_INSTALL_remove = “eglinfo-x11” to my build/conf/local.conf file and then remove any packages causing issues?
I’ve previously built an image for an Apalis iMX6Q and from my notes I did use the DISTRO_FEATURES_remove and IMAGE_INSTALL_remove local.conf options, but I just wanted to confirm if this is how you’d recommend building a console image without Wayland or X11.
Thanks!
