Hi @tonyjones ,
I recommend having a look at this community post here on how to disable or remove wayland. There’s no out-of-the-box solution for including X.org in BSP5, as Toradex has switched to Wayland per default.
Did you try something like weston --tty=1 on the command line? This for example is printing the output to tty1.
Kevin
