Using the pin tool i have selected
UART A - Pin tool shows pins as uart1.TX & uart1.RX
UART C - Pin tool shows pins as uart5.TX & uart5.RX
UART D - Pin tool shows pins as uart6.TX, uart6.RX, uart6.CTS_B & uart6.RTS_B
UART E - Pin tool shows pins as uart3.TX & uart3.RX
My dtsi file (to replace imx6ull-colibri-eval-v3.dtsi) has
&uart1 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_uart1>;
fsl,dte-mode;
&uart3 {
pinctrl-0 = <&pinctrl_uart3>;
fsl,dte-mode;
&uart5 {
pinctrl-0 = <&pinctrl_uart5>;
fsl,dte-mode;
&uart6 {
pinctrl-0 = <&pinctrl_uart6>;
fsl,uart-has-rtscts;
fsl,dte-mode;
and
&iomuxc {
imx6ull-colibri {
pinctrl_uart1: uart1-grp {
fsl,pins = <
MX6UL_PAD_UART1_TX_DATA__UART1_DTE_RX 0x79 /* SODIMM 33 */
MX6UL_PAD_UART1_RX_DATA__UART1_DTE_TX 0x79 /* SODIMM 35 */
pinctrl_uart3: uart3-grp {
fsl,pins = <
MX6UL_PAD_UART3_RX_DATA__UART3_DTE_TX 0x79 /* SODIMM 77 */
MX6UL_PAD_UART3_TX_DATA__UART3_DTE_RX 0x79 /* SODIMM 135 */
pinctrl_uart5: uart5-grp {
fsl,pins = <
MX6UL_PAD_GPIO1_IO04__UART5_DTE_RX 0x79 /* SODIMM 19 */
MX6UL_PAD_GPIO1_IO05__UART5_DTE_TX 0x79 /* SODIMM 21 */
pinctrl_uart6: uart6-grp {
fsl,pins = <
MX6UL_PAD_CSI_PIXCLK__UART6_DTE_TX 0x1b0b1 /* SODIMM 96 */
MX6UL_PAD_CSI_MCLK__UART6_DTE_RX 0x1b0b1 /* SODIMM 75 */
MX6UL_PAD_ENET1_TX_EN__UART6_DTE_CTS 0x1b0b1 /* SODIMM 73 */
MX6UL_PAD_ENET1_TX_DATA1__UART6_DTE_RTS 0x1b0b1 /* SODIMM 30 */
}; /* End of imx6ull-colibri */
if i then run ‘dmesg | grep tty’ i get
root@colibri-imx6ull:~# dmesg | grep tty
[ 0.000000] Kernel command line: user_debug=30 ubi.mtd=ubi root=ubi0:rootfs rw rootfstype=ubifs ubi.fm_autoconvert=1 console=tty1 console=ttymxc0,115200n8 consoleblank=0 video=mxsfb:640x480M-16@60
[ 0.004808] console [tty1] enabled
[ 0.560957] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 21, base_baud = 5000000) is a IMX
[ 1.384890] console [ttymxc0] enabled
[ 1.395225] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 67, base_baud = 5000000) is a IMX
[ 1.414431] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 68, base_baud = 5000000) is a IMX
[ 7.508690] systemd[1]: Created slice system-serial\x2dgetty.slice.
There are only three ports listed.
Question : Looking a the online documentation ,i am concerned that even thou the pin designer app let me configure all the ports , that the module only supports three uarts. Is this the case ?
Additionally i am a bit confused as UARTA = uart1, UARTB = uart2 etc , is not the case
