Imx6dl with Iris 2.0, No Lvds display
The Colibri iMX6 does not have a native LVDS interface. However, the Iris board includes a Parallel RGB to LVDS converter. To use this, you must adjust the screen settings to match your LVDS display parameters and enable the converter as described here. For HDMI output, you need to connect the Colibri iMX6 module’s X2 connector to the corresponding connector on the Iris board using an FFC cable and configure the HDMI output as described here.
