here my equipement :
-Ixora board V1.1A
-Apalis iMX6Q 2GB IT V1.1B
-Apalis iMX6Q 2GB IT V1.1C
-Pin for recovery mode
My problem was when i want to install TorizonCore i got this error (screenshot)
I try with toradex easy installer 5.7 with and without constainer, and image torizon core docker 5 and 6
I also try with 3 different usb stick
Part of the error from your picture states; " Read only file system." We do have a known issue with some IMX6 where the eMMC goes into a forced read only state. We have a write up for it here:
Would you mind downloading and running the script to see if this is an issue that pertains to your setup?
Last night, after several error messages,
I tried to connect the ixora card via ethernet,
Some image appeared including the one I wanted and the installation went perfectly!
