SATA Support in U-Boot
Unfortunately, SATA access from U-Boot on the Apalis iMX8 modules is not currently supported(1). According to the community discussions, mainline U-Boot doesn’t support video displays on i.MX8-based modules, and similar limitations exist for SATA functionality(1).
The Apalis iMX8QM does include SATA-III connectivity(2), but this is primarily accessible from the Linux kernel, not from U-Boot. The SATA interface is available once Linux boots, as documented in our SATA support guide(3).
U-Boot Environment Variable Customization
For modifying U-Boot environment variables, you have several approaches:
1. Build-Time Customization
You can modify environment variables at compilation time by editing the board-specific configuration files(4). The default environment variables are set during compilation and built into the U-Boot binary(4).
2. Runtime Modification
You can modify variables using U-Boot commands(5):
> setenv myvar myvalue
> saveenv
(5)
3. TorizonCore Builder Integration
Since you’re using Torizon, you can potentially use TorizonCore Builder to customize the U-Boot environment. However, this would still be subject to the same hardware limitations regarding SATA access.
Important Considerations
When working with U-Boot environment variables, be aware that:
- Using
setenv only changes values in RAM(4)
- You must use
saveenv to make changes permanent(4)
- When the environment is saved, it can have unexpected consequences as the entire environment is saved, not just the changed variable(4)
Alternative Approach
Since SATA access from U-Boot isn’t available, consider:
- Early Linux Boot: Configure your system to access the SATA SSD immediately after Linux kernel initialization
- Custom Boot Script: Create a boot script that handles your requirements once Linux has loaded and SATA is available
- Network Boot: If you need early access to external storage, consider network-based solutions
The SATA functionality works well once Linux is running, with good performance characteristics on the Apalis iMX8 platform(3).
