i.MX8MP LVDS: Residual Image (Ghosting) and Signal "Jigging" after long S2RAM periods
Hello Toradex Team,
I am experiencing a persistent display issue on a Verdin i.MX8M Plus using a dual-channel 1080p LVDS panel (Himax HX8290-A06 TCON). The image is built using Yocto based on Torizon OS 7.2.
Software Summary
Kernel version:           6.6.84-7.2.0-devel-g87bfb710b6f1 #1-Torizon SMP PREEMPT Mon Mar 31 08:47:48 UTC 2025
Kernel command line:      root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.0/torizon/7690f4340db2981ac94792c9fe8f05860ed8bd8f18e0f718adb16b2ca4561f46/0
Distro name:              NAME=“Torizon OS”
Distro version:           VERSION_ID=7.2.0-devel-20260218083024-build.0
Distro variant:           VARIANT=“Docker”
Hostname:                 verdin-imx8mp-15601689
Hardware info
HW model:                 Toradex Verdin iMX8M Plus WB on Verdin Development Board
Toradex version:          0070 V1.1A
Serial number:            15601689
When the system enters suspend-to-RAM, the display behavior depends heavily on the sleep duration. A short sleep (under 2 minutes) allows for a successful resume, but a long sleep (exceeding 5 minutes) results in a significant “ghost image” of the last rendered frames from the Qt application appearing on the panel. Furthermore, the image “jigs” or flickers for approximately 2–3 minutes before finally stabilizing.
Current Device Tree Configuration:
	backlight_lvds_native: backlight-lvds-native {
		compatible = "pwm-backlight";
		brightness-levels = <0 60 80 110 140 170 220 255>;
		default-brightness-level = <1>;
		pwms = <&pwm1 0 50000>;
		power-supply = <&reg_3p3v>;
	panel-lvds-native {
		backlight = <&backlight_lvds_native>;
		compatible = "panel-lvds";
		data-mapping = "vesa-24";
		height-mm = <136>;
		width-mm = <217>;
		rotation = <270>;
		enable-gpios = <&gpio1 0 GPIO_ACTIVE_LOW>;
		reset-gpios = <&gpio1 1 GPIO_ACTIVE_LOW>;
		ddc-i2c-bus = <&i2c2>;
		panel-timing {
			clock-frequency = <136800000>;
			hactive = <1920>;
			hback-porch = <16>;
			hfront-porch = <38>;
			hsync-len = <12>;
			vactive = <1080>;
			vback-porch = <24>;
			vfront-porch = <20>;
			vsync-len = <5>;
			de-active = <1>;
			hsync-active = <1>;
			vsync-active = <1>;
			pixelclk-active = <1>;
		port {
			panel_lvds_native_in: endpoint {
				remote-endpoint = <&lvds_out>;
&gpu_2d {
&gpu_3d {
&lcdif2 {
&ldb {
	fsl,dual-channel;
	lvds-channel@0 {
		fsl,data-mapping = "spwg";
		fsl,data-width = <24>;
		port@1 {
			reg = <1>;
			lvds_out: endpoint {
				remote-endpoint = <&panel_lvds_native_in>;
&ldb_phy {
&mix_gpu_ml {
&ml_vipsi {
&pwm1 {
	#pwm-cells = <2>;
Given that the display works fine until it enters the suspend state, I am looking for ways to identify exactly what is failing during that transition:
  1. IO State during Suspend: Are the LVDS I/O lines on the Verdin iMX8MP put into a specific state (Hi-Z, Pull-down) during s2idle? If the lines are floating, could this be causing the DC residual buildup in the glass?
  2. Clock Stability: Is there a way in Kernel 6.6 to verify that the Video PLL is absolutely stable before the LDB PHY starts transmitting?
  3. Power-Down Sequencing: Is there a recommended procedure to ensure a full discharge of the LDB/LCDIF rails during power-down to prevent image sticking on high-resolution panels?
  4. Debugging Tools: Are there specific registers or kernel logs we can check to see the LDB PHY state immediately upon resume to see if it’s struggling to achieve link-lock?
I have attached a photo of the ghosting effect. Any guidance on how to further debug the transition into and out of suspend would be greatly appreciated.
Thank you for your help.
The “ghost image” issue you’re experiencing after suspend-to-RAM on your Verdin iMX8M Plus with dual-channel LVDS is a complex display persistence problem. Let me address your specific questions based on the available documentation.
Suspend/Resume Behavior on Verdin iMX8M Plus
For NXP i.MX 8M Plus-based modules, two sleep states are supported: Suspend-to-RAM and Suspend-to-Idle(1). The Suspend-to-RAM (deep) state can be entered using:
# echo deep > /sys/power/mem_sleep; echo mem > /sys/power/state
(1)
The system will wake up with WAKE1_MICO# (SODIMM_252, X7-24) pin or with a console keypress(1). You can also set the system to wake up with RTC alarm in 5 secs from now, for example:
# echo +5 > /sys/class/rtc/rtc1/wakealarm; echo deep > /sys/power/mem_sleep; echo mem > /sys/power/state
(1)
LVDS Interface Technical Details
According to the Verdin iMX8M Plus datasheet, the LVDS interfaces are configurable to support different color mappings and depths, ensuring compatibility with 18-bit and 24-bit displays with both kinds of color mappings(2). The dual-channel LVDS interface can support resolutions up to 1920x1080 @60fps (160MHz pixel clock maximum)(2).
Addressing Your Specific Concerns
1. IO State During Suspend
The documentation doesn’t explicitly detail the specific LVDS I/O line states during suspend modes. However, the LVDS signals are on module-specific pins and are not guaranteed to be compatible with other Verdin modules(2).
2. Clock Stability and Power Sequencing
The available documentation doesn’t provide specific guidance on Video PLL stability verification or power-down sequencing procedures for LVDS displays during suspend/resume cycles.
3. Debugging Recommendations
Since your configuration appears correct and the display works normally except after extended suspend periods, consider implementing custom systemd services to handle display-specific suspend/resume actions. The documentation shows how to create customized suspend/resume related services(1):
For taking action before suspend, you can create a service that will execute before the system enters suspend mode(1). For taking action after resume, you can create a service that will execute right after the system resumes(1).
Potential Solutions
Based on the community discussions, similar LVDS display issues have been encountered with other panels(3). Consider:
  1. Panel Reset Sequence: Ensure proper reset timing for your Himax HX8290-A06 TCON during resume
  2. Backlight Control: Verify backlight sequencing doesn’t contribute to the ghosting
  3. Clock Configuration: Double-check your 136.8MHz clock frequency matches the panel specifications exactly
Given the complexity of this display persistence issue and the specific timing requirements for dual-channel LVDS, you may need to implement custom suspend/resume handlers that properly manage the display controller state transitions.
