I am using an Ixora 1.3 board with Apalis iMX8 SOM.
According to an answer in this post, we “can use the EEPROM (AT34C02D-XHM-B 2-Kbit (256 x 8)) for your own needs. However we do not recommend to use the lower half (first 128 byte) if this EEPROM”
I am able to skip the reserved block and read/write the second 128 bytes no problem using
echo -n -e "{str}" | dd of=/sys/class/i2c-dev/i2c-4/device/4-0050/eeprom bs=1 seek=128 conv=notrunc
to write and
dd if=/sys/class/i2c-dev/i2c-4/device/4-0050/eeprom bs=1 skip=128 count=128 2>/dev/null
to read. However, I am not sure how to access the eeprom beyond the first 256 bytes.
TIA
