Hi, I am currently bringing up a RAW camera for iMX95 Verdin Evaluation Kit and currently unable to link it properly. How to overcome this issue, if someone knows do let me know
I’d be glad to help with your RAW camera setup! To provide the most accurate guidance for your specific configuration, could you let me know:
- Which OS and version you are running on the i.MX95 Verdin Evaluation Kit?
- What type of RAW camera sensor you’re trying to connect (model/interface type)?
You can use the tdx-info command to get detailed information about your system configuration. More details about this tool are available at: Getting Device Information with Tdx-Info | Toradex Developer Center
Camera Support on i.MX95 Verdin EVK
The i.MX95 Verdin EVK has robust camera capabilities with its integrated vision pipeline (1). The system features:
Vision Pipeline Architecture
- Dual MIPI-CSI interfaces with 8 virtual channels (2)
- NXP’s proprietary ISP that enables HDR fusion, RGB-IR separation, and advanced noise reduction (2)
- 4K@60fps encoding/decoding capability (2)
Camera Interface Options
Based on the available documentation, you can connect cameras through (3):
- MIPI CSI interfaces (primary option for RAW cameras)
- USB 3.0 interface for USB cameras
- Additional expansion via M.2, mPCIe interfaces (1)
Software Support
The i.MX95 provides comprehensive software tools for camera integration (2):
- EIQ Toolkit for AI model optimization
- OpenCV & OpenVX Acceleration with hardware-optimized libraries
- Camera Tuning Tools with support for pre-tuned camera modules and custom ISP configurations
For troubleshooting camera linking issues, the specific OS version and camera sensor details will help determine the appropriate device tree configuration and driver requirements.
