Hello world,
I’m using IMX6DL and I’m using yocto reference multimedia reference image, now i want to include apt package manager in this Image, which will be included in production also so, how to include this package manager in yocto Image?
Nolan
Hi @Nolan_Maverick,
First, you need to configure YP to use Debian package management to create the package feeds. For that set PACKAGE_CLASSES = "package_deb" in build/conf/local.conf.
Second, you need add the package manager to your images. For that set package-management to the IMAGE_FEATURES variable in build/conf/local.conf.
Cheers,
:rjs
Thanks @RudolfStreif , apt package manger is installed, this my sources.list file.
# deb http://snapshot.debian.org/archive/debian/20220509T000000Z bullseye main
deb http://deb.debian.org/debian bullseye main
# deb http://snapshot.debian.org/archive/debian-security/20220509T000000Z bullseye-security main
deb http://security.debian.org/debian-security bullseye-security main
# deb http://snapshot.debian.org/archive/debian/20220509T000000Z bullseye-updates main
deb http://deb.debian.org/debian bullseye-updates main
deb https://feeds.toradex.com/debian/snapshots/20220512T021145Z testing main non-free
and when I try to update using
apt-get update
This is the error I’m getting how to solve this issue
Get:1 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
Get:2 http://deb.debian.org/debian bullseye InRelease [116 kB]
Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
Err:1 http://security.debian.org/debian-security bullseye-security InRelease
gpgv, gpgv2 or gpgv1 required for verification, but neither seems installed
Err:2 http://deb.debian.org/debian bullseye InRelease
Err:3 http://deb.debian.org/debian bullseye-updates InRelease
Get:4 https://feeds.toradex.com/debian/snapshots/20220512T021145Z testing InRelease [13.0 kB]
Err:4 https://feeds.toradex.com/debian/snapshots/20220512T021145Z testing InRelease
Reading package lists... Done
W: GPG error: http://security.debian.org/debian-security bullseye-security InRelease: gpgv, gpgv2 ord
E: The repository 'http://security.debian.org/debian-security bullseye-security InRelease' is not si.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: GPG error: http://deb.debian.org/debian bullseye InRelease: gpgv, gpgv2 or gpgv1 required for verd
E: The repository 'http://deb.debian.org/debian bullseye InRelease' is not signed.
W: GPG error: http://deb.debian.org/debian bullseye-updates InRelease: gpgv, gpgv2 or gpgv1 requiredd
E: The repository 'http://deb.debian.org/debian bullseye-updates InRelease' is not signed.
W: GPG error: https://feeds.toradex.com/debian/snapshots/20220512T021145Z testing InRelease: gpgv, gd
E: The repository 'https://feeds.toradex.com/debian/snapshots/20220512T021145Z testing InRelease' is.
Nolan
For pulling from remote repositories you need the GNU Privacy Guard signature verification tools. Add them to your image by adding gnupg to IMAGE_INSTALL.
You need of course also create a key, sign the packages on the server and install the key on your target.
BR,
:rjs
it worked, now update is happening good, but while running
$apt-get upgrade
I’m facing this issue
root@colibri-imx6-10909128:~# apt-get upgrade
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
The following packages have been kept back:
attr automake base-files base-passwd bash-completion bonnie++ cpp evtest file g++ gawk gcc hostapd libattr1 libcap-dev libcrypt-dev libgmp-dev libgmp10 libice-dev libice6 libpci3 libprocps8 libsm-dev
libsm6 libwrap0 libx11-6 libx11-dev libx11-xcb1 libxext-dev libxext6 libxi-dev libxi6 libxinerama1 libxrandr-dev libxrandr2 libxtst-dev libxtst6 libxv1 mime-support mtd-utils openssh-sftp-server
pciutils procps ptpd python3-numpy xwayland
The following packages will be upgraded:
busybox ethtool liborc-0.4-0 libusb-1.0-0 libxaw7 libxmu6 lrzsz usbutils
8 upgraded, 0 newly installed, 0 to remove and 46 not upgraded.
Need to get 1183 kB of archives.
After this operation, 2996 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://deb.debian.org/debian bullseye/main armhf busybox armhf 1:1.30.1-6+b3 [424 kB]
Get:2 http://deb.debian.org/debian bullseye/main armhf ethtool armhf 1:5.9-1 [170 kB]
Get:3 http://deb.debian.org/debian bullseye/main armhf liborc-0.4-0 armhf 1:0.4.32-1 [157 kB]
Get:4 http://deb.debian.org/debian bullseye/main armhf libusb-1.0-0 armhf 2:1.0.24-3 [54.6 kB]
Get:5 http://deb.debian.org/debian bullseye/main armhf libxmu6 armhf 2:1.1.2-2+b3 [52.7 kB]
Get:6 http://deb.debian.org/debian bullseye/main armhf libxaw7 armhf 2:1.0.13-1.1 [167 kB]
Get:7 http://deb.debian.org/debian bullseye/main armhf lrzsz armhf 0.12.21-10 [85.0 kB]
Get:8 http://deb.debian.org/debian bullseye/main armhf usbutils armhf 1:013-3 [72.3 kB]
Fetched 1183 kB in 1s (1937 kB/s)
tar: error while loading shared libraries: libselinux.so.1: cannot open shared object file: No such file or directory
dpkg-deb: error: tar subprocess returned error exit status 127
dpkg: error processing archive /tmp/apt-dpkg-install-gxWgHi/0-busybox_1%3a1.30.1-6+b3_armhf.deb (--unpack):
dpkg-deb --control subprocess returned error exit status 2
dpkg: error processing archive /tmp/apt-dpkg-install-gxWgHi/1-ethtool_1%3a5.9-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-gxWgHi/2-liborc-0.4-0_1%3a0.4.32-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-gxWgHi/3-libusb-1.0-0_2%3a1.0.24-3_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-gxWgHi/4-libxmu6_2%3a1.1.2-2+b3_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-gxWgHi/5-libxaw7_2%3a1.0.13-1.1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-gxWgHi/6-lrzsz_0.12.21-10_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-gxWgHi/7-usbutils_1%3a013-3_armhf.deb (--unpack):
Can you give some solution on how to solve this problem
Warm regards,
Nolan
It’s looking for libselinux. It’s kind of strange as it is not a regular dependency. You can try to add meta-selinux to your layers and then add libselinux to IMAGE_INSTALL.
