How can I install QNX using microSD
Hi.
I bought Apalis iMX8QN 4GB + Ixora Carrier board.
I want to install QNX to the Board.
Bun I cannot install.
When I insert microSD card into my board, The board can’t detect files from microSD card.
I used TEZI(Tordex esay intaller).
When I boot up the board, I’ll see the screen below.
It’s the same when you insert microSD.
according guide document, it should appear as below, but even if I insert microSD, the screen as below does not appear.
How do I install QNX on the board.
Hi @hgko, are you extracting the image in the SD card? it should look like this: SD/folder/contents
Just in case, can you share with us where did you get the image? (Download link is OK)
Kind regards,
Alvaro.
The SD card has a file as shown below.
I did build this files for QNX.
File link is : 네이버 MYBOX
Pls extract that .zip inside a folder in the SD card. That should be recognized by Toradex Easy Installer
